Rebuild parts for 3td Gen 4WD Crew Cab Short Bed rear driveshaft
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MECGuy, Jul 25, 2025 at 4:00 PM.
  1. Jul 25, 2025 at 4:00 PM
    MECGuy
    MECGuy [OP] Member
    Michael
    SC
    2016 Tacoma Limited
    Dana driveshaft 10023638
    where do i find the part numbers for the u joints and the center support bearing ?
  2. Jul 25, 2025 at 4:04 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Seems like most of the autos use 5-1330x u-joints and the manuals have 5-1350x. I don’t know that that is a hard fast rule.
    For my manual truck with 1350 joints, the parts were:
    37230-09080 - Bearing set, center support
    04371-04101 - Spider kit, universal (u-joint) x3
    I imagine the center support bearing is the same on all 3Gs, but I don’t know for sure. For u-joints, I’d just measure what you have, figure out if it’s 1330 or 1350, and buy the corresponding spicer non-greasable parts.
  3. Jul 25, 2025 at 4:47 PM
    MECGuy
    MECGuy [OP] Member
    Michael
    SC
    2016 Tacoma Limited
    I think you are correct regarding the 5-1330-1X U Joints. I noted that the Dana 10023638 driveshaft specs indicate it is a 1330 series driveshaft.
  4. Jul 25, 2025 at 4:49 PM
    BLtheP
    Plano, TX
    I have to imagine it’s either transmission based or trim based. Maybe 1330 matches the 8” diff and 1350 matches the 8.75” diff? Since all the manuals have the 8.75”. So maybe the offroad and Pro autos also have 1350, but everything else auto is 1330. I really don’t know, we’d need a poll to find out. Not much good info out there.
  5. Jul 26, 2025 at 3:20 AM
    MECGuy
    MECGuy [OP] Member
    Michael
    SC
    2016 Tacoma Limited
  6. Jul 26, 2025 at 6:17 AM
    BLtheP
    Plano, TX
    Why not just order the OEM? I would not go aftermarket personally.
  7. Jul 26, 2025 at 8:12 AM
    MECGuy
    MECGuy [OP] Member
    Michael
    SC
    2016 Tacoma Limited
    If i could determine the Spicer part number that would be the preferred option.
    Might be 211431X based on the Spicer catalog as it is the only center bearing with a 32mm (1.260”) bore.
    the OEM Center Support Bearing Set Part #37230-09080 lists for an MSRP $325.79 on the Toyota Parts Website.
    This product fits 261 vehicle variants.
    TOYOTA : 1 model, 261 variants between 2016 and 2023
    BLtheP likes this.
