rebuilding or putting in gears
Discussion in '1st Gen. Tacomas (1995-2004)' started by makikid808, Oct 10, 2011.
  1. Oct 10, 2011 at 11:20 PM
    makikid808
    makikid808 [OP] They call me unko
    Kamaki
    Kula,Maui
    98 Tacoma sr5 4x4 5VZ-FE 3.4 manual
    fabtech 6" lift, all-pro 5" rear lift springs, 17x9 ATX slot, 295/70/17 nitto trail grapplers, Borla catback exhaust system, K&N FIPK, bully nerf bars, wet okole seat covers, tints (factory tint plus 5 on back 35 on front), sounds(kenwood deck, kenwood IE speakers all around,kenwood 720W amp for mids, kenwood 1000W amp pushing orion 12" sub), LED dome map and door lights
    i need help idk if this is the same thing or two different things. i was planning on putting in some gears, but i wanted to also rebuild my transmission. its had it time and has its miles on it. so i was wondering if putting in gears would be like rebuilding or if i still would need to rebuild it after putting the gears in.
  2. Oct 10, 2011 at 11:31 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    The gears that we all talk about are in the differential. Rebuilding the tranny is just like refreshing it with a few new gears and some special bushings and such. If you re gear your truck, you have to buy new differential gears for the front and rear diffs. Not cheap to do anything that you are thinking about doing
  3. Oct 10, 2011 at 11:50 PM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    Also if you are rebuilding your tranny, you can have it built a little needier depending on your needs. Stage 1,2,3. Better tow, beefier internals.
  4. Oct 11, 2011 at 12:27 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ^^exactly.
    You could send it to Martin Crawler and really have her overhauled :cool: cost like 2 grand..
  5. Oct 11, 2011 at 12:36 AM
    makikid808
    Kamaki
    Kula,Maui
    dang two grand huh
    haha nah thats ok for that one. its just that i would like it to be a little fresher though. its got about 251k on it now so now u could have and idea of how much shes been through.
  6. Oct 11, 2011 at 12:38 AM
    makikid808
    Kamaki
    Kula,Maui
    i know im soo gonna sound like a freaking mental case when i ask this but isnt the differential help for off roading. i was wondering if i was to put bigger tires and run some 4.88 on them wouldnt that help
  7. Oct 11, 2011 at 12:48 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea most guys re gear to help with bigger tires. 4.88s would be for like 35s witha V6 or 33s with a 4cly i think.
    and yea its pricey..http://www.marlincrawler.com/transmission/rebuilt-complete/r150f
    Can also order a rebuild kit from them if you can do it yourself..
  8. Oct 11, 2011 at 1:05 AM
    makikid808
    Kamaki
    Kula,Maui
    yea ive got a 3.4 v6 and was planning on running some 285/75/16. how do you think that would be. plus yea i got some friends who are really good with that kind of stuff just need to find the time with work and all. what do you think
  9. Oct 11, 2011 at 6:39 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lots of ppl run 285s without re gearing.(basicly a 32.6'' tire i think) I am pretty sure you wont have to re gear. And if you want to 4.88 is to short, i think 4.56 puts you closer back to stock gearing.
  10. Oct 13, 2011 at 8:41 AM
    pikuptruk
    pikuptruk Well-Known Member
    Vallejo
    01 4x4 2.7 Lifted
    6" Fabtech Lift 33" Tires Flowmaster Cold Air Intake
    I'm running the same tires on my 2.7L. I have noticed a slight loss in power, but generally you don't need to regear for this. If you were going to 35s, the forums have suggested a regear for this. You will be fine without rehearing for your 285s. Just keep in mind the wear and tear that may occur during daily use...
