Rebuilt my 3rz!!! SHES A RUNNER
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98_3RZ_NIC, Jan 5, 2025.
  1. May 23, 2025 at 7:09 PM
    #361
    98_3RZ_NIC
    98_3RZ_NIC [OP] Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    @t0p_d0g so I just did an oil change on my truck and I’m driving it out of the neighborhood and all is fine and I get down the road to a stop sign and when I take off it kind of made a screeching noise but only once. Hasn’t done it since…..weird.
  2. May 23, 2025 at 7:16 PM
    #362
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    That’s a hard call without hearing it. Did it sound like a belt?
  3. May 23, 2025 at 7:17 PM
    #363
    98_3RZ_NIC
    i couldn’t really tell. I wasnt expecting it. I had the radio on so I muted that then it didn’t happen again so I’m not sure. I’ll listen on my drive home.
  4. May 23, 2025 at 7:18 PM
    #364
    t0p_d0g
    Did you spill any oil up front by any chance?
  5. May 23, 2025 at 7:22 PM
    #365
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    How tall are those uprights, and how high does your forklift reach? You're under utilizing a lot of your vertical space if your forklift can reach the top of those frames plus 2" for lift off
    (I design and sell pallet rack to big warehouses)
  6. May 23, 2025 at 7:22 PM
    #366
    98_3RZ_NIC
    nope. Used a funnel lol. Usually I don’t use a funnel but I wasn’t feeling frisky enough haha
    t0p_d0g[QUOTED] likes this.
  7. May 23, 2025 at 7:22 PM
    #367
    98_3RZ_NIC
    not my shop so it really doesn’t matter to me. It’s a fairly small company. Only 3 employees. They make it work so it’s fine lol.
  8. May 23, 2025 at 7:23 PM
    #368
    kairo
    kairo >_>
    Nor Nev
    Then I will gracefully depart and browse the rest of the posts on the front page
  9. May 23, 2025 at 7:23 PM
    #369
    t0p_d0g
    When you get home check the belts. If it’s not that I wouldn’t worry about it.
    98_3RZ_NIC[OP] likes this.
  10. May 24, 2025 at 6:14 AM
    #370
    98_3RZ_NIC
    so there was no noise yesterday after it happened and then today at the SAME stop sign it made the noise at yesterday, it made it again today. I was like what’s going on! It’s so hard to explain because I’m not expecting it and the radio is on lol. But other than the noise all seems good.
  11. May 24, 2025 at 9:01 AM
    #371
    t0p_d0g
    Just keep your ears tuned in if it is an issue it will poke its head up again.
  12. May 24, 2025 at 9:10 AM
    #372
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    As he stated, need to try & isolate & can be tough....
    Belts seem plenty tight?
    Could be the u joints haunting you again...
    A cure all which really isnt going to hurt anything if it continues,
    Dont use belt dressing...
    Put a tiny dollop of brake caliper slide grease on the each belt, on the front & back sides & even the sides.
    Just a tiny bit, using your finger, dollop no bigger than a dime.
    Not going to hurt anything.
    We use it alot to resolve belt squeeks when they get contaminated with coolant or other issues were trying to resolve.
    If you here the noise & do that, all of a sudden you no longer can reproduce the noise, you somewhat isolated the area you need to focus on.
    Or, you fixed it...
    As long as the belts are tensioned correctly.
  13. May 24, 2025 at 9:15 AM
    #373
    t0p_d0g
    The belts were my first thought and I suggested OP to check them but not sure he has yet.
    From what OP is describing I think he has a tension problem on one of the belts.
  14. May 24, 2025 at 11:00 AM
    #374
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    My 1st gen Tacoma's A/C compressor would make a funny noise for just an instant, but only when it was cold. I feel engine accessories and their tensioner pulley bearings might be worth looking into here if you didn't already replace/rebuild/check over that stuff during your rebuild.
  15. May 24, 2025 at 11:11 AM
    #375
    98_3RZ_NIC
    yeah I didn’t replace any accessory tensioners. So that might need to happen and see if I can get that noise away. Only happened once yesterday and once today so far.
  16. May 24, 2025 at 11:35 AM
    #376
    98_3RZ_NIC
    I did check the belts and they all seem tight as far as I can tell. There really isn’t any way to check “how tight” they are but they aren’t loose that’s for sure.
  17. May 24, 2025 at 11:45 AM
    #377
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    my guess is the fan clutch.....which doesnt mean a thing most likely
    might want to make sure its kicking in correctly......dont how to safely do that
    replaced mine 4 yrs ago as a preventative
  18. May 24, 2025 at 12:14 PM
    #378
    98_3RZ_NIC
    alright I’ll do some research on that as well.
  19. May 24, 2025 at 5:30 PM
    #379
    slater
    San Diego
    Not sure how a fanclucth is going to cause a momentary quick screeching sound....
    Yes, if FC is locked up it will sound like a 747 taking off, roaring away but not a quick intermittent concern...
  20. May 24, 2025 at 5:34 PM
    #380
    slater
    San Diego
    As I stated, they may seem tight & them may be tight, truly aren't going to hurt anything by putting a dab of "translucent brake caliper slide grease" on the belts as I suggested...
    Especially if it does continue, you cant isolate, & youre chasing your tail..
    If it goes away, you found it...
    Dont use ANYTHING but caliper slide grease in translucent clear.
    no belt dressing, no spray lube, no wheel bearing grease, etc...
    t0p_d0g likes this.
