rebuilt rear differential
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4421.frank, Feb 24, 2010.
  1. Mar 1, 2010 at 5:10 AM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    you would need to buy a limited slip rear out of a TRD or buy a locker kit and have it installed. They will have it opened any way so lockers could be put in, but you would have to buy the locker kit, and they are not cheap
    Buying a TRD rear you could put it in yourself ( saving on labor) and you could find a low mileage one thru the data base the yards keep. They ship them from all over the USA to the yard close to you
  2. Mar 2, 2010 at 9:47 AM
    4421.frank
    4421.frank [OP] Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    I just talked to the shop owner and he didn't have good news for me :(.
    The rear end is pretty much shot, they took it apart, and found all types of bad news. :(
    Then he told me it would be around $1800 to have it totally rebuilt :eek:
    fuck, that expensive! :eek:
    It was difficult to go ahead with such a costly repair, but I went ahead with it.
    Sadly though, the repair ate any extra money for the pro comp all black series 8069 rims :(, and the installation of the TRD 7th injector kit :(
    but all that will come in good time
    meanwhile I have to wait around until next monday for the truck to be done :(
    looks like plenty of walking going on until then :D
  3. Mar 2, 2010 at 8:10 PM
    ywen
    ywen Well-Known Member
    Hey I'm facing the same type of vibration.. I just got the truck about 2 months ago.. vibration can be felt from the driver side floor board.. it's a rumble strip type vibration but sometimes goes to a constant low rumble from 20mph to 30mph.. now it seems to be even noticeable all the way up to 35mph. Slowing down thru that speed range results in the same vibration. Shifting into N makes no difference. However if I pop into 4Hi, the vibration goes away immediately. Was your symptom similar?
  4. Mar 2, 2010 at 8:13 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    I'm in the middle of getting rid of similar vibes. Remove your rear drive shaft and drive FWD to see if it goes away. If so, it's your shaft. Get a CV drive shaft and pitch the rear diff so it's facing the transfer case.
  5. Mar 2, 2010 at 8:19 PM
    ywen
    Ha.. don't know what you said in that sentence? can you clarify for a noob? :eek:
    So your issue is identical in that once you pop it into 4Hi it goes away?
  6. Mar 2, 2010 at 8:30 PM
    drew02a
    San Antonio, TX
    Yeah, 4wd gets rid of the symptoms, becauseit keeps constant pressure on the driveshaft
    Read this
    http://www.4xshaft.com/driveline101.html
  7. Mar 3, 2010 at 10:17 AM
    ywen
    Hmm still not fully understanding your theory on what the issue is.. you think it's an drive shaft angle issue?
  8. Mar 18, 2010 at 3:19 AM
    4421.frank
    Southside chicago
    I picked her up a week or so ago. The vibration is gone in the 25-30 mph range but there is still some slight vibration at higher speeds. :(
    I know I have knobby old tires and was expecting to grab some all black procomp 8069 series wheels soon so I stopped by a trusted tire dealer today. Hopefully by the end of this week or perhaps the beginning of next week off road will get those rims to them and then we can get them and the new tires on this truck.
    The shop owner told me he rotated my tires because of teh wear and vibrations issue. Now the vibration that occurs at high speeds is felt more so in the front of the truck. I am guessing some new shoes for her will do some wonders, hopefully :)
    I was told that if this didn't do anythign to the vibration that the only remedy may be a whole new drive shaft. but we'll wait to see what some new shoes do for her in the mean time.
    I will post pics with it's new wheels and tires.
  9. Mar 19, 2010 at 3:09 AM
    4421.frank
    Southside chicago
    I talked to the shop owner the other day.
    He said if there is still any vibration after the new tires and wheels to let him know.
    He suspects the "lift threw off the geometry of the drive line
    I had heard of this but never thought it would be an effect of such a nominal lift.
    (bilsteins 5100's in the front set at 2.5, new bilsteins in the back, and a Toytec AAL with a 1.5" block)
    I have seen some talk on here about shims under the carrier bearing. could this be a potential remedy to some of the drive line vibration?
    Anybody dealt with these shims before? Where does one get these shims, what is the install like?, something I can do on my own in the garage?
  10. Mar 19, 2010 at 3:46 AM
    Mondwa
    Mondwa Well-Known Member
    Michael
    Phoenix, AZ
    08 V6 Tacoma
    remote start, Allpro bumper, Slimchubby HID, MetalMiller custom Emblem
    Its already been posted in here :D
  11. Mar 19, 2010 at 5:00 AM
    98tacoma27
    Ben
    Not Beech Creek
    Those are axle shims and not for the carrier bearing. I would go the axle shim route before dropping the carrier bearing IMHO.
  12. Mar 19, 2010 at 7:39 AM
    drew02a
    San Antonio, TX
    For the axle shims to work, you MUST get a CV driveshaft too.
  13. Mar 19, 2010 at 11:38 AM
    4421.frank
    Southside chicago
    alright then, what's that and what do they ? Are there any pics of these Where do you get one? I was searching "drive shafts" and the like just incase this was my last ditch but came up with nothing. Do I have to get a drive shaft( if needed) from Toyota, or is there another reputable manufacturer?
  14. Mar 19, 2010 at 11:50 AM
    drew02a
    San Antonio, TX
    I can't speak for the quality of their product, but their explanation is about the best I've found:
  15. Mar 19, 2010 at 2:32 PM
    #35
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    it might be worth a shot to try a carrier bearing drop.It takes only but a few minutes to do it. Its better to go with an "actual carrier bearing drop" say by toytec, but you could simply stick a few washers in instead. try a 1/4 '' worth of washers. If you dont like it or it didnt change nothing,try maybe a 1/2'' worth of washers or you could take them back out. For just a couple minutes of work its definitly worth a shot. IMO
  16. Mar 24, 2010 at 3:19 AM
    #36
    4421.frank
    Southside chicago
    alright a little update on my ,never ending quest to end my truck of this incessant drive line vibration :mad:
    My wheels and tires and are in! Tomorrow I will have them balanced and put on the truck :D
    I don't think the effect the old, knobby tires had on the vibration were that great but new tires were needed and what the hell?
    I also ordered an axle shim kit from toytec yesterday ( ). I asked them for a carrier bearing drop kit as well but they said they don't have 'em for 02 tacomas. I figure I will go with one of the recommendations posted earlier. First try a 1/4" of spacers, if nothing then try a 1/2". If the combination of the new tires and the washers on the carrier bearing then I will go ahead with the axle shim kit.
    I was in the dark as to the installation of the axle shim but, a tech at toytec said it can go either on top of the 1.5" lift block on the rear or under it.
    Is either one any better? Is there anything else I would need to install the shim? Take in mind the the lift hardware has only been on for a couple months. So it should be alright.
    BTW, when I spoke to the tech at toytec, I told them the lift in the back I had, Toytec AAL and a 1.5" block. The tech made a sighing sound and said "u-huh". I asked him what was up. He said they don't recommend using the add a leaf and 1.5" block in conjunction with each other. I found this odd, no one said anything when i bought them together last winter. I guess if bothe carrier bearing with some washers and\ or the axle shim doesn't do anything then I would be forced to take out either the AAl or the block but I am hoping this can be remedied with with out removing any part of the lift, i like it :D
    I should get a lull between gigs here soon. This will give me acouple days to mess around the home and truck and do some trouble shooting. I will let those interested know how it works out.
    I f you have any ideas or suggestions please let me know,
    thank you and good night
  17. Mar 24, 2010 at 4:46 AM
    #37
    98tacoma27
    Ben
    Not Beech Creek
    If it comes down to the need to remove the block or AAL, ditch the block.
  18. Mar 24, 2010 at 5:39 AM
    #38
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    so what was wrong with the rear? New Gears and Parts only cost about 450$ not sure how much he charged you for labor.
  19. Mar 24, 2010 at 8:55 AM
    #39
    BRP27
    04 4X4 Tacoma SR5
    X2 ditch the block.
  20. Mar 24, 2010 at 12:32 PM
    #40
    4421.frank
    Southside chicago
    why ditch the block? Won't this cause the back to sag? Or is the AAL enough to keep it up? Just curious. I don't want the front end higher than the back end if non of the solutions work. I am keeping my fingers crossed I don't have to remove anything, I like the way it sits now.
