Recall parts availability next week
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dansm, May 10, 2017.
  1. May 10, 2017 at 9:19 PM
    Dansm
    Dansm [OP] Active Member
    2016 TRD 2 wheel drive
    Went to dealer today they owed me an air filter, while there they checked my differential no leaks - so they tightened the bolts to specified torq. Thankfully that's the end of my recall.
    Dealer said they should start receiving the parts for recall repair next week for the leaky differentials
  2. May 10, 2017 at 9:24 PM
    InfernoTonka
    InfernoTonka Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    Sweet! Good to know...Toyota is ahead of the curve on this issue :thumbsup:
  3. May 10, 2017 at 9:25 PM
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    So if it leaks after being retorqued it's exempt from the recall?
  4. May 10, 2017 at 9:27 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Parts list!
    Just in case there is more to this then just a leak... :spy:
    smitty99 likes this.
  5. May 10, 2017 at 10:24 PM
    prowl647
    prowl647 Well-Known Member
    Mine didn't show up on recall list
    anthony250f likes this.
  6. May 11, 2017 at 4:05 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    It would still be covered under warranty.
    0210 likes this.
  7. May 11, 2017 at 9:01 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    ^^^^^ what he said.
  8. May 11, 2017 at 9:24 AM
    .jake
    .jake Ex-Lion Tamer
    OK, makes sense, but let's just say, if you had 32000 miles on your truck and when you took it in for the recall, they saw no seeping, retorqued studs and sent you on your way. Then at 37000, your standard warranty is up, but now it's seeping. Do you own this issue now? Does the recall no longer apply to you because it was already seen for it and deemed unaffected?
  9. May 11, 2017 at 9:29 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    I'm not a lawyer but it seems to me if the recall is still active he would fall under the three criteria, check and tighten if not leaking, replace gasket and hardware if leaking, if additional damage during gasket replacement is found replace diff.
  10. May 11, 2017 at 9:31 AM
    .jake
    .jake Ex-Lion Tamer
    Ya, that's pretty much the recall as it's written. Maybe a better way to ask: Is Toyota treating this like floor mats where every visit it gets re-evaluated?
  11. May 11, 2017 at 9:34 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    I think if hardware is just checked and tightened, they would be obligated to continue that practice for any truck subjected to the recall until the gasket and hardware is replaced or the recall is rescinded. After that you'd probably be on your own.
    .jake[QUOTED] likes this.
  12. May 11, 2017 at 11:06 AM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    I haven't looked into the standard warranty much, but isn't the diff part of the power train? Should have more miles on the warranty. But hypothetically I think it is up to your dealer past the warranty. If it wasn't seeping, then the warranty expires and it is seeping 5k miles later, I think you are on the hook. Some dealers might do it out of "good will" that close to the warranty ending, but I think that is just to keep you coming back.
  13. May 11, 2017 at 11:08 AM
    .jake
    .jake Ex-Lion Tamer
    Good catch. Yes that is powertrain.
  14. May 11, 2017 at 11:11 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    A recall is not a warranty item, its a recall. I wouldn't think there is any mileage attached to the recall
  15. May 11, 2017 at 11:15 AM
    aero90
    Yes but if they inspect it once and deem it ok and then later down the line it starts seeping, the line gets blurred. It isn't uncommon for diffs to start seeping fluid so at some point the line has to be drawn. Follow any chevy/gmc/ford/ram, etc with a few years on it down the road and look at the rear diff. Chances are it will be soaked.
  16. May 11, 2017 at 11:18 AM
    .jake
    .jake Ex-Lion Tamer
    More or less what I was getting at. Maybe they don't print an end date and instead send a notice to terminate the recall down the line?
  17. May 11, 2017 at 11:18 AM
    Clearwater Bill
    Billy
    Largo Florida
    Usually from a leaking/worn pinion seal. Not a gasket.
  18. May 11, 2017 at 11:20 AM
    Cr250jumper
    The moon
    50 shades of tan©
    That would be true except you have an active recall for that item. While I agree it is common for a seep it will be tough for Toyota to deny an item especially if this is listed with the NHTSA as a safety recall. From what I can tell they cannot put a cap or end on true safety recall once listed with NHTSA
  19. May 11, 2017 at 12:08 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Hard to say, the head gasket recall for the 3.0 V6 was capped at 100k miles. Pretty sure it was a safety item but I think the recall itself had the mileage cap when it was first released.
  20. May 11, 2017 at 12:11 PM
    Cr250jumper
    The moon
    50 shades of tan©
    There are a lot of different types of recall but I would think the head gasket was not safety. If its a true safety recall it has different rules. This would apply more to something like an airbag recall. But I don't know for sure this is a true safety recall, just going on what people here have labeled it
