Receiver door control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by muddog321, Dec 3, 2019.
  1. Dec 3, 2019 at 10:36 AM
    muddog321
    muddog321 [OP] Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Anyone have a failed receiver door control - small white box inside and above the glove box mounted on a metal bracket to the front of the dash and in the airbag wire harness there. Your key remote FOB talks to this box to open/close door locks. Toyota part # 89741-04010 and they are list at $700 and low at 400 but even ebay has none.
    Is there any other reason the FOBs randomly work as both have new batteries and it started at 10 years old on a 2009. Key in door still works on all lock/unlock functions. Thanks.
    Dronepilot likes this.
  2. Dec 5, 2019 at 1:51 PM
    muddog321
    FL
    Anyone - Bueller, Bueller...……...
  3. Dec 5, 2019 at 4:14 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    If you find the receiver is at fault, I still have the one from my 05' part out - keys as well.
    Was toying with putting in power locks/windows/mirrors in the RC, but decided against it. Manual all the things!
  4. Dec 11, 2019 at 11:11 AM
    muddog321
    FL
    Put a new battery in the remote that was flakey and no improvement. Got my old more used spare remote same thing.
    So wondered why no one had reported bad receivers so ordered a used Toyota remote for $14 with new battery from eBay, did the long ridiculous add a remote, and it works now.
    So both of my remotes had the unlock function fail! You can see the reprogram instructions for FCC ID: GQ43VT20T at (one site of many out there):
    https://northcoastkeyless.com/2009-toyota-tacoma-keyless-entry-remote-programming-instructions/
    Thanks My50cal for the offer of parts and Hony Badger for the remote idea. Guess Keep It Simply Stupid applies to me on this one!
    HONY BADGER and MY50cal like this.
  5. Oct 31, 2020 at 1:10 PM
    JimmyJ
    JimmyJ Member
    2010 white Tacoma prerunner
    MY50cal do you still have the receiver I am trying to find one
  6. Nov 1, 2020 at 9:44 AM
    muddog321
    FL
    Sorry mine was OK and I never did find one on ebay.
    I tried to find Tacoma's that were wrecked by looking for used mags and if they had a wrecked truck pic sent them an email and still no unit.
    Good luck in your search.
