receiver drop question
Discussion in 'Towing' started by OffroadToy, Jul 16, 2022.
  1. Jul 16, 2022 at 9:36 AM
    OffroadToy
    OffroadToy [OP] pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Tow a 15" Smoker Craft Alaskan aluminum fishing boat with a tongue weight of 250lbs. Truck is lifted and the measurement shows i need a 5" drop receiver. They seem to be hard to find around here... can I get by with a 4" drop? Got the rxt leaf pack (at option 2)... there's no sag of back end when trailer is hooked up.
  2. Jul 16, 2022 at 9:49 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    You can try it see how it pulls .
    I have found to much weight on the trailer can be like dragging an anchor .
    Worse case have someone make you a 5" drop I have made a few custom receiver inserts over the years.
  3. Jul 16, 2022 at 9:56 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I see it just about every day.
    I live 2 miles from a public boat ramp.
    I’d say 60% of all the trucks pulling a boat here are not level.
    The front of the trailer is high.
    Mostly for the same reason as you. Lifted
    I wouldn’t worry about an inch. If you are that worried about it. Load all your fishing gear in the bed to help sink the rear a bit. But 1”, no. I wouldn’t worry about it.
    OffroadToy[OP] likes this.
  4. Jul 17, 2022 at 7:33 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    Link to Amazon
    Link to Walmart
    Link to Lowes
    Plenty of options out there. If you are in a smaller town and don't have Lowes or a Wally World or a couple of Auto Parts stores you may need to wait on shipping but most big box auto parts stores carry the 5 inch drop hitches (Autozone, Advanced, O'Reilly). If you know 5 inches is exactly what you need (that's what she said) I would go with exactly what I needed for my trailer to sit level. That is just me though - being off by an inch on the height probably will not kill you as long as you are within the 10 - 15% golden rule for ball mounted hitches.
    OffroadToy[OP] and Eckho like this.
  5. Jul 18, 2022 at 7:55 AM
    OffroadToy
    mic_sierra and Eckho like this.
  6. Jul 18, 2022 at 8:32 AM
    OffroadToy
    Quick question. I see some receiver's are slanted back and some are straight down... any advantages/disadvantages between the two towing wise?
  7. Jul 18, 2022 at 8:43 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Assuming they are rated the same, not really. The only real difference is distance from ball to receiver pin. Some people like me want that distance to be as short as possible to lessen the lever effect of weight-behind-rear-axle. Others want a long distance to keep their ass-end out of the water when launching. In real world practicality, the couple of inch difference between an angled drop and straight drop is negligible.
  8. Jul 18, 2022 at 8:49 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    What was the max tongue weight stated on the receiver. Also what is the trailer weight?
  9. Jul 18, 2022 at 10:22 AM
    OffroadToy
    The ball mount says class III/IV and "capacity TW (lb) 500." I've never weighed the boat/trailer but think maybe around 1,500-2,000 lbs. I've checked the tongue weight... it comes out to 260lbs. It's a 15' aluminum Smoker Craft Alaskan with a 9.8hp and 4hp Tohatsu outboards on back, Minnkota Powerdrive up front, 2 batteries, 2 external gas tanks, 2 down riggers, and around 200 lbs of gear. I could probably get by going with class 2 but figured if my weight is off class 3 should take care of it.
  10. Jul 18, 2022 at 11:39 AM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Oh you would be perfectly fine with that reciever. That trailer wouldn't have close to that tongue weight.
