Receiver hitch for '10 Tacoma reg cab?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 10taco, Sep 21, 2009.
  1. Sep 21, 2009 at 11:14 AM
    10taco
    10taco [OP] Well-Known Member
    Massachusetts
    '10 4WD reg cab
    fog lights (with OEM switch), skid plate, stainless exhaust tip, Curt receiver hitch, Exact-Fit seat covers, AFE air filter, intermittant wipers, EGR in-channel vent visors, door sill protectors, Autocraft Platinum AGM battery.
    I want to install a 2" receiver hitch on '10 Tacoma 4CYL reg cab 4WD. I will be pulling a 1500 lb (loaded weight) snowmobile trailer occasionally. I am considering Curt, Hidden, OEM, and Draw-Tite; class III or class IV. I will be installing this hitch myself (second time installing one for me) so I want to get a kit, not go to U-Haul. At this point the Curt #13323 looks pretty good. My last hitch was a Hidden Hitch; it rusted pretty quickly so I may pass on them this time. I would like to hear from other Tacoma owners on their experiences on installation and usage. All replies encouraged and welcome! :D
  2. Sep 21, 2009 at 3:22 PM
    EricS76
    EricS76 Well-Known Member
    Central Texas
    08 DC SR5 Prerunner Black,08 AC 4x4 SR5 White
    I've installed 2, both made by Ridgid Hitch Co. I haven't noticed a problem with either. One has been on for 2 years and the other 11 months. Installation is simple. Remove the bumper and bumper brackets, install the hitch b/t the brackets and frame, install bumper to brackets with supplied spacers b/t bumper and bracket.
  3. Sep 21, 2009 at 3:23 PM
    JKD
    JKD Well-Known Member
    Installation of my Valley hitch was a breeze, and I like the design. Hasn't been on long enough to judge corrosion resistance though.
    Installation of my Hoppy (Hopkins) trailer adapter was mostly a breeze.
  4. Sep 21, 2009 at 6:18 PM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    I got my valley hitch from Uhaul, it was the cheapest around and had free shipping to my door (plus lifetime warranty). Very happy with it, and it's the only one that installs like the OEM one (does not require removing the bumper, but does require bolting to the bumper). It looks like it will rust eventually, but I haven't seen one not rust anywhere there's salt! Another good site to try is etrailer.com, has instructions for all the major brands.
  5. Sep 21, 2009 at 6:32 PM
    jpg366
    jpg366 Well-Known Member
    TX
    09 Prerunner SR5
    I ordered a hitch from U-Haul. A couple of days and $120 later, I had a Class-IV Valley drop-shipment, and it fit perfectly. They did not list one for my '09 so I just used the part number for an '08. Very satisfied. Got the wiring kit from Toyota (wanted the relays, not just the jumpers from a tail light). You'll need to measure 150 ft-lbs torque for a couple of the bolts.
  6. Sep 24, 2009 at 1:12 PM
    10taco
    Massachusetts
    '10 4WD reg cab
    I am hoping that one of the Tacomaworld users can provide a picture of an installed Curt Trailer Hitch on their Tacoma. I would like to install one on my '10 Tacoma but would like to see how it looks on the truck first. Thanks in advance! :D
  7. Sep 24, 2009 at 6:25 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    I got the Curt hitch (and a T-One plug & play wiring harness) from eTrailer.com for my '09 reg. cab 2WD and my brother & I installed it. I don't think I'd want to do the install alone. That hitch is heavy - and you have to hold it up against the frame just right on both sides (at the same time) for the bolt holes to align so you can get the bolts started. I can't imagine doing that by yourself - but I guess you could do it with a floor jack or something. Much easier with a helper though. Anyway... I'll try to get a pic for you. The Curt has a MUCH thicker, more durable finish on it than the HiddenHitch I put on my last vehicle. I'm very pleased with it... would definitely buy it again.
  8. Sep 24, 2009 at 6:41 PM
    kagrimm
    kagrimm Member
    Colorado
    09 double cab 4.0-V6 6sp MT
    I installed a Curt that I bought at Camping World on the way home from the dealer for my 09 when new. All the holes matched up with the frame and stock bumper without any issues. Probably easier to install with 2 people but definitely doable by yourself with some metric tools. You just remove 6 (or was it 8) bolts that hold the bumper on and slip the hitch between the frame and the bumper mounting brackets. Tighten and/or tourque the bolts and it is good to go.
    I couldn't find a T-connector for the wiring in stock anywhere in town so I just bought the generic four point plug at the local Checker (for less than $10) and installed it myself by splicing into the rear tailight wiring. Tailights are simple to remove (I remember 2 bolts and 3 plastic tabs) to get to the wiring. Would buy a Curt again.
  9. Sep 28, 2009 at 6:41 PM
    10taco
    Massachusetts
    '10 4WD reg cab
    Also got the Curt T-connector for the lights, and a mounting plate for my 4-lead light connector (dealer told me I have to drill into the receiver to mount it). This Curt receiver has a THICK powdercoat finish that looks bulletproof! Haven't removed the wrapping so I will wait on the install comments but JEEZ this thing looks heavy duty! Hope it fits nice & tight up and out of the way cuz I don't want any extra STUFF hanging down in the way!! :eek:
  10. Sep 28, 2009 at 6:56 PM
    Raven65
    Camden, SC
    I just loosely zip-tied my connector to the top of the receiver. Pulls out easy when I need to use it - and just rides on top of the receiver when I don't.
  11. Sep 28, 2009 at 7:01 PM
    tex
    tex Well-Known Member
    Aaron
    Arlington, TX
    2015 4 Runner Trail
    if you give me a few min I can get pics of mine. I think it is a Curt. It is on a 08 reg cab pre runner
  12. Sep 28, 2009 at 7:56 PM
    tex
    Aaron
    Arlington, TX
    2015 4 Runner Trail
    Here are some pics of mine I just took. It was dark out side so some of the pics are only so so.
    My bumper did have to come off for this to be put on. Hope this helps with your decision.
  13. Sep 29, 2009 at 6:04 AM
    10taco
    Massachusetts
    '10 4WD reg cab
    Great pics, thanks a bunch. Actually bought a Curt hitch yesterday from a local dealer, as well as a Curt T-Connector wiring setup (4-pole). The finish on these hitches are amazing. Will hopefully get this thing mounted in a week or so. ;)
  14. Nov 15, 2009 at 5:44 PM
    10taco
    Massachusetts
    '10 4WD reg cab
    And it took A LOT more work than I thought. First, I removed the bumper and I'm glad I did, made the installation much easier. I bolted the hitch to the frame and went to re-install the bumper...BUT THE HITCH HOLES DID NOT LINE UP WITH THE BUMPER BRACKETS!! So, off came the hitch and out came the grinder. Had to remove approx 1/8" from the two holes where the bolts go vertically up into the frame; this allowed the hitch to slide rearward enough for the bumper brackets to line up. Now that it fit it was just a matter of tightening up all the fasteners and lining up the bumper to get it to look right. After installing the T-connector for trailer wiring (easy!) I located and attached the L-shaped 4-pole connector bracket to the frame. The Curt hitch fits up high and out of the way; really don't like the safety chain attachment loops but the finish on this hitch looks very nice and will (hopefully) stand up to more than a few New England winters. :D
  15. Nov 15, 2009 at 8:36 PM
    Raven65
    Camden, SC
    Hmmm... the holes in my Curt lined up just fine. It's a TIGHT fit... at first I was afraid they WERE off, but after shifting it around some (with the help of my brother) we got it to line up perfectly. We left the bumper on too... if I remember correctly, you remove all but one of the bolts from the bumper bracket and the hitch just slides in between the frame and the bumper brackets. It would have been significantly more difficult to do alone.
  16. Apr 16, 2011 at 11:21 AM
    Ezriderga
    Ezriderga Well-Known Member
    Georgia
    '06 Tacoma xtracab BB
    Thanks for the pics as they were helpful. Installed mine yesterday and took a few pics today. Curt hitch is very well built and easy to put on. Highly recommend. Thanks again for your pics.
