Recent experience with Solo Motorsports
Discussion in 'Long Travel Suspension' started by Vitalzone, Jul 20, 2021.
  1. Jul 20, 2021 at 12:18 PM
    Vitalzone
    Vitalzone [OP] Well-Known Member
    Arizona
    2016 TRD OR 4x4 DCSB 6 spd manual
    -ADS coil overs with RR, and compression adjusters -ADS triple bypass rear shocks -Mcm UCAs -Deaver U402 stage 1 leaf packs -ADS bumps in the rear with Icon U bolt flip striker plates -Relentless Offroad U bolts -Wheeler superbumps in front -SCS 17" Ray 10s -285/75/17 BFG KM2s -Nitro 5.29 gears -Pelfteybilt armor front to back with HC rear bumper. T- case skid cut to fit Spec U exhaust. -RCI diff skid -Avid bed bars with basket holding spare. Poison Spyder 3-way strap. Hi-lift jack,and shovel mounted to basket. - SDHQ ditch light brackets with BD Squadron Pro spots. -BD Squadron Pro wide cornering in F. bumper. -BD S8 30" bar in F. bumper -Smittybilt 10k X20 winch -Factor 55 fairlead, and prolink -Switch pro 9100, with custom machined aluminum switch bezel. -BAMF grille insert -URD short throw shifter -URD Spec U exhaust cut over axle. Exhaust looks like it was fabricated by a blind child. -Suntek carbon XP 18% tint all around -ARB single compressor, mounted on Slee bracket. Lines to front, and rear bumper. -Rear diff breather mod,ran to bed cubby. -Ovtune 1.05 FOB 91 -Sprint-booster -Clutch accumalator delete mod -Hella Sharptone horns -Crown +4” extended brake lines, with modified factory brackets to fit lines. -Hypertech speedo calibrator -Custom pinstripes, and trail rash done by the beautiful AZ desert.
    Anybody have any recent experience with Solo? Specifically their XLT kit. I’m on the fence with purchasing their kit. Paul, and Bobby have been for the most part great on the phone answering most of the questions I have had. However I have been reading alot of negative feedback about fitment issues, and poor after sale support. People don’t seem to get into details about fitment problems. I have questioned them about fitment issues, but they seem to dance around the subject, blaming problems on bent rails, and lower arm mounts. I’m not feeling 100% confident yet dropping 10k + on the kit.
  2. Jul 20, 2021 at 12:46 PM
    Vitalzone
    Arizona
    I’m looking at Solo to achieve 19” of travel to compliment what will be a backhalved, and 4 linked rear. Plus the strength of the Dana 44 hubs will handle a 37” tire vs a unit bearing. LSK is currently developing a 4x4 race kit, but from what I understand it will be released end of year, if at all.
  3. Jul 22, 2021 at 7:54 AM
    Nickgbmx
    Nickgbmx Well-Known Member
    Nick
    2010 Tacoma Trd
    I would have zero hesitation purchasing from Solo Motorsports, excellent product and great customer support both before and after purchasing. Bobby has always answered every question I’ve ever had and taken the time to explain in detail his explanation. If your wanting to achieve 17”+ of travel XLT kit is the only way to go, is it a direct bolt on kit like TC, Dirt King or JD? No. It does require modification to your vehicle to achieve the additional travel that you are buying the kit for in the first place. I’m sure most of these “fitment issues” people are talking about are from people expecting to bolt a kit on and that’s it, we’re in a aftermarket industry where modifications to your vehicle and the parts purchased may be needed to gain full potential from your product. Buy with confidence and have a qualified fabricator install your kit if you are not up to the task and you will have success
    Wwjvd, dira1987 and Canks like this.
  4. Jul 22, 2021 at 8:24 AM
    Vitalzone
    Arizona
    My particular truck is getting the complete inner fender structure removed, and shocks tied into the engine cage. So no problems there. Doing it right to maximize all available travel, and clear a 37.
  5. Jul 22, 2021 at 9:10 AM
    Canks
    Canks Well-Known Member
    San Diego
    08 DCSB in pieces; 04 Tundra Access cab also in pieces
    I will second this. Its not a bolt on kit and requires additional work to make fit right. I am in the middle of installing mine on my '08, plating the lower mounts, chopped the upper shock tower and arm mounts etc. Its slow going but will be worth it.
  6. Aug 7, 2021 at 2:37 AM
    zwalker16
    zwalker16 Well-Known Member
    I bought a used solo setup a couple years ago and had several questions. the guys at solo had several phone conversations with me and were helpful even though I wasn't buying from them. I would purchase through them again
  7. Sep 9, 2024 at 11:52 AM
    Nalpak99
    Nalpak99 Booty Hunter
    Kyle
    2005 Toyota Tacoma pre-runner
    mid travel
    OP, did you end up getting the Solo kit? I am saving up right now. I was going to go with JD fab but 19" of travel sounds worth it and will complement links much nicer. Im at 11.5" with my current setup so not sure JD is worth it for 2.5"
  8. Nov 25, 2024 at 11:28 AM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    With that much front travel, you pretty much need to link the rear.
    10-14” Travel up front can easily keep up with 17” inch travel out back (spring under 62” leaf setup). In other words, if you had even a mid travel set up upfront with a secondary bypass and rear 62 inch springs with a bed cage…. your rear might still be the limiting factor. So with your gnarly solo front long travel kit, you’re gonna be limited by the rear and will not be able to use the full potential unless you link it and go for gobs of up travel back there .
