Recently bought a 23 TRD Sport and want to front level the truck.
Discussion in 'North West' started by Rebuildtoy, Jan 8, 2025.
  1. Jan 8, 2025 at 10:40 PM
    Rebuildtoy
    Rebuildtoy [OP] New Member
    2009 tacoma
    I'm looking to level the front end of my truck. Currently the front and rear, center hub to bottom of hub measure at 22". If I get a 2" level kit for the front, will that make it obvious that my front is higher than the rear? Thanks
  2. Jan 8, 2025 at 10:43 PM
    Bishop84
    Bishop84 Well-Known Member
    The 3rd gens sag in the rear and leveling it always shows, and if you put more than 50lbs you'll be headlight high, its why most recommend keeping 1" of rake, so 2" front 1" rear or 1" front only.
  3. Jan 9, 2025 at 9:31 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're already level. Haul anything in the bed, you will be squatted. Add anything to the front suspension, you will be squatted.
    Squat is very obvious. Both headlight aim was noted, as well as visually. I'd say 0.25in to 0.50in squat is pretty noticeable.
    I did my suspension in stages as the parts arrived at different times. 3.0in of rake with the new leafs looked pretty silly. Getting it to 1.5in with the new coilovers looked right, to me.
  4. Feb 7, 2025 at 7:28 AM
    1cleanFG
    1cleanFG DialsGarage
    DialsGarage
    PNW
    2023 Sport 4x4 DCLB
    Toytec Alumaseries Coilovers OME El111R Camburg UCAs Scs sr8 17” 285/70/17 KO2
    2” front Bilstein 5100 and 1” block in the rear. Cheap. Easy to do. (And yes. A small rear block is OK and won’t harm anything you’ll ever do with that truck).
  5. Feb 7, 2025 at 8:48 AM
    Clearwater Bill
    Billy
    Largo Florida
    Do you do truck stuff like haul or tow?
    Lifting the nose will make that worse.
