recessed grille
Discussion in '1st Gen. Tacomas (1995-2004)' started by garetcurry, Dec 29, 2010.
  1. Dec 29, 2010 at 12:00 AM
    garetcurry
    garetcurry [OP] Well-Known Member
    Garet
    West Virginia
    5vz Turbo Taco
    Engine: CX Racing Turbo Kit (.70 A/R Compressor, .68 A/R Turbine, 61.3 /82 mm Compressor Wheel, 62 /67.8 mm Turbine Wheel), TiAL F38 Wastegate (8.7 psi spring) Go Fast Bits T9301 Diverter Valve, 31" x 11" x 3" Intercooler w/3" piping & T-Clamps, 4" Air Filter & Aluminum tube w/1" & 5/8" bungs, EVAP Delete, Catch Can, URD Underdrive Pulley, 170 Degree Thermostat, GM SU1075 Knock Sensors, Turbo Blanket Electronics: AEM FIC-6, Innovate SCG-1: Solenoid Boost Controller Wideband O2, Innovate MTX-D: Vacuum / Boost & Shift Light, Exhaust Cut-Out Switch Exhaust: All V-Band & Stainless Steel, 3" Downpipe, 3" Magnaflow Hi-flow Catalytic Converter, Granatelli 4" Exhaust Cut-Out, Magnaflow 2.5" 11246 & 12646 Chassis: 4 Link w/QA1 Coilovers Front & Rear Wheels & Tires: XXR 968's Continental Extreme Contact 18" front DWS 06 245/40, 17" rear Sport 285/40 Body: KBD Valance, RaceMesh Grille, Rollpan Interior: 2000-2005 Toyota Celica Seats, Craven Dual Gauge Mount, Custom Subwoofer Fiberglass Box, Pioneer GM-D8601 & GM-D8604 Amps Kenwood Deck, 8" Kicker 40CWRT82 Sub, Alpine Tweeters, MTX TX68 Front & Kenwood KFC-C6894P Rear Speakers
  2. Dec 29, 2010 at 12:13 AM
    garetcurry
    Garet
    West Virginia
    5vz Turbo Taco
    Oh... and in the video I noted that you needed to make something special in order to access your hood latch. This is actually untrue and I feel like an idiot, ha... I even made a little cable for mine. You can still free your hood by simply getting your hand under the hood and pushing the latch to the left. I guess I got hung up on having always lifted it from under -- go figure. I also stated that I would be cutting the latch, I did not, but rather just bent it downward.
  3. Dec 29, 2010 at 12:27 AM
    tacomarotto
    tacomarotto "Change is inevitable, but growth is optional."
    Jon
    New Orleans, LA
    FJ Cruiser 07'
    Bilstein 5100 (2.5") aFe short ram intake KC light bar PIAA halogen Lights Hella Lights on top Yakima Load Warrior
    do you have an up close of how you dealt with the hood latch?
    great vid and pics! its inspiring...
