recessed lighting
Discussion in 'Garage / Workshop' started by coffeesnob, May 23, 2013.
  1. May 23, 2013 at 2:31 PM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    I have recessed lights in my kitchen one goes off on its own as if the bulb blew then may come back on in a few minutes or a few hours. It makes a click when this happens. Is this a bad can light, connection or what? Thanks
  2. May 23, 2013 at 2:35 PM
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    most likely the lamp isn't making good contact with the tab at the bottom of the lamp holder. turn the light off and bend the tab out slightly.
  3. May 23, 2013 at 2:38 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    thermal overload ?
  4. May 23, 2013 at 2:41 PM
    Saskquatch11
    come to think of it this is the more likely scenario.
    there should be a max watt rating sticker inside the can.
  5. May 23, 2013 at 2:49 PM
    coffeesnob
    VA
    I never considered that. is
  6. May 23, 2013 at 4:29 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    This is thermal protection, I believe those recess light that the electrician put in have not clear the insulation around the light, so when it start hot, it will shut the light off, and when it cool down it will turn back on.
    Like the guy above me said, may be you or someone put in a light bulb that max out the recess light, usually 50 or 55w
    May be you can try some dim LED light bulb.
  7. May 23, 2013 at 5:36 PM
    Saskquatch11
    got er figured?
  8. May 24, 2013 at 3:23 AM
    coffeesnob
    VA
    I'LL check on it tonight when I get home
