Recharge a/c
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Aug 4, 2020.
  1. Aug 4, 2020 at 8:13 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    What options do I have for doing it myself ?
    Was gonna just refill the freon . Or should I follow something else? Buy the one with the dye in it? I pretty sure the compressor still good and turns on. It just doesnt get cold
    2006 tacoma 2.7 4 cylinder. Thanks
  2. Aug 5, 2020 at 6:32 AM
    Haole Toy
    Haole Toy Well-Known Member
    Mauna Kea, AZ
    '21 SR 4x4
    My '06 was the same. I looked into it and decided to let the dealership do it. It was only $150 and they replaced the valves and tested for leaks. I figured if something went wrong it was on their backs to re-do...but then I have a really good dealership here.
  3. Aug 5, 2020 at 7:02 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Dye is ok, leak stop is bad juju. The best, most accurate way to recharge the AC is start from empty, weigh in 22 ozs.
  4. Aug 5, 2020 at 7:57 AM
    GP_spence
    GP_spence Well-Known Member
    AL
    2013 DCSB TRD Off-Road 4x4
    Have you checked your cabin air filter or cleaned the condenser coil recently?
    pinktaco808[OP] likes this.
  5. Aug 5, 2020 at 10:32 AM
    Slum Lord
    Slum Lord Well-Known Member
    Not a DIY typically but you can do it for cheap now with some basic stuff from Amazon. Ie. Manifold set and can adapters.
    You will want to use straight R134, DO NOT use stuff that has additives as mentioned. Be careful because this is like pretty much all of them. Usually the plain white cans are straight refrigerant.
    Youll need to hook up the manifold, read pressures, and add refrigerant accordingly. All of this can be found online so it's nothing new.
    Another part is where did it go. If you see staining around lines or components it's because a leak occurred. This absolutely needs to be fixed before recharging. It also requires recovering. All can be done but is more complicated.
    Some refrigerant slowly leaks out over time. I think rule of thumb is a half ounce per year on average. At some point you will lose cooling and/or compressor stops coming on.
    So if it just needs a top off no big deal. If it leaked out due to a fault seal it's a lot more in depth.
    I bought a gauge set, all the fittings, and a vacuum pump online for under $150. This will do everything except recover old refrigerant. This requires a significantly more expensive professional grade machine. You could just vent it to atmosphere but it's illegal. Of course when your vehicle naturally vents it to atmosphere it isn't illegal. Difference? Only by law...
  6. Aug 5, 2020 at 11:30 AM
    UncleRick
    UncleRick Well-Known Member
    Rick
    2012 Tacoma Prerunner
    First. It's a sealed system. It shouldn't leak AT ALL. It leaks FIX IT. It won't get "used up" or magically make it way out of the system.
    Second. When you "vent" 22oz of refrigerant 134a its equivalent of releasing 2 tons of Carbon Dioxide into the ozone. The 134 last upwards of 20 years in the ozone which eats away at the ozone and has a global warming potential. So that's why its illegal. And actually EPA says that a system leaks over a certain percentage per year, that it must be fixed or condemned. Comfort cooling is 10% so that's 2.2 oz of a 22 oz system. Obviously you can't fine the equipment but the EPA will fine the owners up to $10,000 per violation.
    Source: EPA 608/609 Certified and Chiller Technician working on 134 systems with thousands of pounds of 134 in them.
    But OP, you do what you want.
  7. Aug 5, 2020 at 11:35 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    It hilarious that some people make it sound like venting R134a into the air is worse than killing a baby.
  8. Aug 5, 2020 at 11:54 AM
    UncleRick
    Rick
    I didn't say anything about killing babies. Lol. I'm just stating what the EPA says on venting the refrigerant. Last time I checked it's a free country and the government lies. So OP can do what he wants.
  9. Aug 5, 2020 at 11:56 AM
    Slum Lord
    Pretty sure R134 was created to not eat the ozone or people's brain but it may have in your case.
    Yeah, it's a sealed system and refrigerant doesn't get used up. But it permeates through the hose. Yes, barrier hoses prevent this but it still will drop slightly over time. If it didn't, why would compare is sell those kits in Autozone to top it off.
    Now I speak from being Master ASE certified and having a refigerant license to perform work, plus I'm not stupid. So I do have something going for me.
    You should really stop what you are doing and tell all the shops that are topping off cars to blow cold air it is a waste of time. They are totally sealed systems...
  10. Aug 5, 2020 at 12:06 PM
    UncleRick
    Rick
    I appreciate the hate and the personal attack. I will keep doing what I do. You just reminded me why I don't get on social media or the forums often.
  11. Aug 5, 2020 at 12:18 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Play nice in the sandbox children...
    TheDirtyMike and T-Rex266 like this.
  12. Aug 5, 2020 at 12:36 PM
    mea4dxl
    mea4dxl Well-Known Member
    NY/NJ
    2012 Access cab 2wd
    get the kit and be done
  13. Aug 5, 2020 at 2:09 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    But but I I wanted to chime in!!! :D
    Jimmyh likes this.
  14. Aug 5, 2020 at 2:18 PM
    pinktaco808
    Where the condenser coil? Not that the cabin filter just did that last week
  15. Aug 5, 2020 at 2:22 PM
    pinktaco808
    It is a 06
  16. Aug 5, 2020 at 3:06 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    The condenser is in front of the radiator. Soak it with soapy water, then flush with a garden hose. Do not use a pressure washer as it may flatten the fins on the condenser.
    UncleRick likes this.
  17. Aug 5, 2020 at 6:57 PM
    pinktaco808
    The front top and back of the outside of the condenser? What kind of soapy water? Sorry never done this before
  18. Aug 5, 2020 at 7:00 PM
    pinktaco808
    There a leak somewhere?
  19. Aug 5, 2020 at 7:01 PM
    pinktaco808
    Wat exact stuff from Amazon?
  20. Aug 5, 2020 at 7:39 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Jimmyh likes this.
