Recharging a/c
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Mar 18, 2019.
  1. Mar 19, 2019 at 4:53 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    How you do that?
  2. Mar 19, 2019 at 4:53 PM
    pinktaco808
    You did it yourself or a shop?
  3. Mar 19, 2019 at 4:56 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Shop. Wasn't expensive.
  4. Mar 19, 2019 at 5:16 PM
    08RC
    08RC Well-Known Member
    Vacuum pump for about 45 min should do it and you can also check for leaks with it .Thats if you are recharging like in an empty system. I only have a cheap harbor freight one but its done the job many times along with their AC Manifold Gauge set.
  5. Mar 19, 2019 at 5:23 PM
    pinktaco808
    Vehicle on engine running?
  6. Mar 19, 2019 at 5:33 PM
    08RC
    engine off
  7. Mar 21, 2019 at 8:09 AM
    pinktaco808
    I gotta remember to watch vid.
  8. Mar 21, 2019 at 10:07 AM
    pinktaco808
    May have
    Dam hopefully today
  9. Mar 21, 2019 at 10:16 AM
    pinktaco808
    Gotta charge mines. Was full blast ac on hardly cold. I dont know if my vent are stuck setting cause I put it on window or feet and still comes from front vent. Any help?
  10. Mar 21, 2019 at 10:18 AM
    pinktaco808
    I dont know if my vent are stuck setting cause I put it on window or feet and still comes from front vent. Any help? I still feel air coming out the vent each side on the driver side.
  11. Mar 21, 2019 at 10:30 AM
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    Pretty close. But don’t turn on the system on empty. You have to put as much as it takes (but less than full charge) through high side. A little bit through low side. Then, if it didn’t take all charge you do it while it’s running. Having a scale to weight it in is the ideal method.
  12. Mar 21, 2019 at 12:16 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    agreed on an older vehicle this would be sound advice....however based on the assumptiom he does not knownmuch about AC I decided to tell him to play it safe and let the AC system pressure switch do the thinking for him....if he starts the truck and starts to fill from the low side the pressure switch will do the work for him assuming the pressure switch is properly working. (Yes, IF the pressure switch is not working it could damage the system) however givin the history of our trucks its likely his compressor needs to be replaced and the switch is fine.
  13. Mar 21, 2019 at 12:19 PM
    kidthatsirish
    No its true true....thats why you need to put a vaccum on the system. If its only a tiny bit of mostiure than the dessecant pack will likely take care of it, but its best to put a good vaccum on the system to remove moisture and check for leaks.
    pinktaco808[OP] likes this.
  14. Mar 21, 2019 at 4:51 PM
    pinktaco808
    Low side first
  15. Mar 21, 2019 at 4:56 PM
    #35
    08RC
    both high and low get vacuumed at the same time
    kidthatsirish likes this.
  16. Mar 21, 2019 at 4:57 PM
    #36
    pinktaco808
    That why need the 2 cans?
  17. Mar 21, 2019 at 4:58 PM
    #37
    08RC
    system holds 20-22oz. most cans are 12oz ? Im no expert at this at all but I did stay in a Holiday Inn Express and watched You Tube videos on this topic
    bobsuruncle and kidthatsirish like this.
  18. Mar 23, 2019 at 11:05 PM
    #38
    pinktaco808
  19. Mar 24, 2019 at 5:22 AM
    #39
    08RC
    To begin with that is to" add" 134a like in "topping off" a system , you asked to recharge which makes it sound to me as if the system is empty, like maybe you replaced a part or two. Second you will be hard pressed to find an experienced AC person to recommend 134a with a sealant in it unless they are selling the stuff.
  20. Apr 15, 2019 at 7:19 PM
    #40
    undersc0re
    undersc0re Well-Known Member
    BC Canada
    exhaust and k@n filter setup.
    Does anyone know if I were to just swap out compressors with a new one if this works, and if I would have to add oil or drain oil out of the new compressor?
    The old compressor in the truck stopped working for about a year and then the belt screeched one day when I turned on the ac, so I pulled the fuse, I assume the thing is seized and needs replacing. Would I be best to just swap it out then go to an ac shop?
    UAC CO 10835C A/C Compressor https://www.amazon.ca/dp/B00JJXIV0U/ref=cm_sw_r_sms_tai_.ptTCbWFQSKJP
