Reciever Hitch Pin Lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pster, Aug 26, 2009.
  1. Aug 26, 2009 at 7:52 AM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Has anyone found a locking hitch pin for the Tacoma 2nd Gen reciever that fits? I bought a Trimax locking unit but the locking head would not seat - I discovered that the receiver on the Tacoma is built up and the outside diameter is slightly wider by about 1/4" than most 2" recievers.
  2. Aug 26, 2009 at 8:35 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    Does the lock itself have rubber on the end of it where it contacts the hitch? Pull it off. Been a while but I recall having to do this with mine.
  3. Aug 26, 2009 at 8:37 AM
    shootermcgavinyo
    shootermcgavinyo Well-Known Member
    Rockford, IL
    '08 double cab 4x4 v6 trd off road
    That's what I had to do. I forget which model of lock I have, but it's some sort of Masterlock.
  4. Aug 26, 2009 at 8:41 AM
    monrad
    monrad Coprolite
    B'wood, SC
    09 DC short box TRD Sport, TM
    Avid light bar+RBG, Lightforce 140s, fog mod, FSM badges, Bobcatoshi grille + Stampede, JDM DRLs, TRD cat-back, rear spring TSB, AccessLE
    Master 1469. Then add two 5/8" ID garden hose washers to remove the side-to-side slack.
  5. Aug 26, 2009 at 8:44 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Excellent, thanks guys, this is exactly what I was looking for!
  6. Aug 26, 2009 at 8:48 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
  7. Aug 26, 2009 at 8:49 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    No, the Trimax I have doesn't have my rubber on the ends. I had to file down the locking lip on the shaft to get the keyed end to lock onto it, but it really compromised the integrity of the lock, afraid I ruined it......
  8. Aug 26, 2009 at 9:01 AM
    monrad
    monrad Coprolite
    B'wood, SC
    Yep. The lock has a rubber cover, and rotates on the pin so you can get at. Squirt some Teflon powder in the keyhole to make it work smoothly.
    WalMart has it for less $$.
  9. Aug 26, 2009 at 9:24 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Excellent, I researched it and ordered it on Ebay, $24 including shipping. You are correct, it is actually designed for later model hitch receivers that are wider than 2" O.D. (like the Tacoma). Perfect solution. I appreciate your suggestion Monrad.......!!!
  10. Aug 26, 2009 at 9:33 AM
    monrad
    monrad Coprolite
    B'wood, SC
    My pleasure.
    Next time you're south on I-77, give a shout and wave at Exit 27.
  11. Aug 26, 2009 at 9:48 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Wilco!
  12. Aug 26, 2009 at 1:54 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    sweet. i needed this thread. :) I need to buy a hitch lock to keep my winch from disappearing.
  13. Aug 26, 2009 at 2:21 PM
    kbp68
    kbp68 hey...I can change this!
    B.C.
    TRD Off Road DC/SB
    3" Pro Comp Lift/Level, ARB Winch Bumper, Superwinch UT3000,White Sport Grille, Bedliner'd rocker panels, Draw-Tite brake controller
    I thought I was the only one!!! I had to trim about 1/8" from the plastic handle on the head from the masterlock pin at wal-mart. It works fine now.
  14. Mar 28, 2010 at 10:44 AM
    thoward
    thoward New Member
    I have a master lock, took the rubber washers off and the lock fit just barely with some force. Now, i can't get the lock off and the key won't turn becasue it's too tight and not enough slack. Any ideas how to get it off?
  15. Mar 29, 2010 at 8:39 PM
    05SuperChrg
    05SuperChrg Well-Known Member
    SF Bay Area
    TRD Supercharger, TRD Air Filter,Rancho 9000's, Old Man,Fumoto Oil Drain Valve,Kenwood Sub, Sony HU,Wet Okole, debadged,satoshi,Slee Sliders
    Interesting--I have a Master lock pin used it on my Lexus, I tried to take the boat out this weekend and....nogo the pin would not lock. I looked around and tried to find a longer pin---nope. My bicycle carrier lock would not work either....
    So I cranked up the air compressor and dremmel and removed metal from the holes on the receiver end, now it fits minus the rubber bushing.
  16. Mar 30, 2010 at 12:51 AM
    09TRDSpt
    09TRDSpt African Light Infantry
    Atlanta, GA
    09 TRD Sport DC 4x4
    I had the same one from my prior Jeep. It won't work on the Taco, its about 1/4 too wide for the lock to seat. I can still use it on my other vehicles though. I guess when I need a lock I'll have to get one of the other model's, been just using a regular pin for now.
  17. Mar 30, 2010 at 1:01 AM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Masterlock. Towing a 3500lb bass boat, no problems.
  18. May 17, 2010 at 5:37 PM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    Have one just like genxer36... I bought it about an hour ago at a U-Haul dealer. Same thing. Fits perfectly.
