Reciprocal range of motion for valves 1GR-FE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Aug 31, 2022.
  1. Aug 31, 2022 at 12:10 PM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    Just out of curiosity, does anyone know the exact range of motion of valves on 1GR-FE, assuming that the cam-tapet clearance is in the dead center of the recommended range?
    My guess is somewhere around 1/4" but I can't be sure.
  2. Aug 31, 2022 at 1:21 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Are you asking how far the valve will stick out of the head when the valve is fully open?
    foampile[OP] likes this.
  3. Aug 31, 2022 at 1:49 PM
    foampile
    Mid-Atlantic
    Yes, exactly
  4. Aug 31, 2022 at 1:53 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Can find out for you tonight as my heads are off.
    TnShooter likes this.
  5. Aug 31, 2022 at 2:00 PM
    foampile
    Mid-Atlantic
    Mine are too but it's not exactly easy to simulate the motion by the cam unless the camshafts are on and you spin them with a ratchet. even then, how do you measure?
  6. Aug 31, 2022 at 3:09 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    considering the aftermarket cams have a lift around 9.5mm Id imagine the stock cams are around the 8-9mm mark of total lift.
    TnShooter and foampile[OP] like this.
  7. Aug 31, 2022 at 6:28 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I got too excited to go through all that. Heads been off since August 1st, so they went on today. I'd measure with a set of calipers.
  8. Aug 31, 2022 at 6:45 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    Measure cam lobe height from base circle . Since cam lobe is directly over shim bucket the is no exaggeration of motion that a rocker arm could impart. Measure base circle of cam at 90° from lobe center ( across smallest diameter) then measure bottom base to top of lobe. (Now the largest diameter) The difference would be your valve lift.
    (Not 1gr-get spec, just where to measure)
    SR-71A, TnShooter and foampile[OP] like this.
  9. Aug 31, 2022 at 6:48 PM
    foampile
    Mid-Atlantic
    @Blkvoodoo -- so take the lobe lift and subtract from it the clearance between the cam and the tapet when it's not opening the valve and that's the opening.
    I'm surprised the lobe lift isn't more than 0.22". I would have guess it was.
  10. Aug 31, 2022 at 6:57 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    First off that image wasn’t for a Toyota cam, just an image to show where to measure.
    second, valve lash clearance isn’t subtracted, that measurement is a minimum spec to allow parts to grow/expand from heat and still allow everything to seat and seal, that’s why the measurement is taken cold.
    This is what happens when valve adjustment is to tight and run hard
    foampile[QUOTED][OP] likes this.
  11. Aug 31, 2022 at 7:58 PM
    Dirty Dude
    Dirty Dude Well-Known Member
    2004 Tacoma SR5 Xtra cab 5-lug
    Dirt, miles, and wear.
    That's true if the running lash closes down to zero in operation, which it typically should not do. Lash is always subtracted from theoretical valve lift in order to arrive at the net valve lift.
  12. Sep 1, 2022 at 4:43 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    You could measure with a dial indicator and base. If you dont have one you should, very handy for random stuff like this and not too expensive.
    SR-71A likes this.
  13. Sep 1, 2022 at 4:57 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Is 0.22" what you got following the method above?
