Recirc. Air Noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fiend13, Feb 25, 2014.
  1. Feb 25, 2014 at 2:13 PM
    Fiend13
    Fiend13 [OP] Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    I came home from work today and right when I pulled into my driveway I heard a noise and noticed that it only happened when the recirculate air was on. It's like a click/tap noise. I could feel the noise when I touched under the glove box. Not sure what it is. But I check the wiring and everything was plugged in and in tact. Any ideas?
  2. Jun 25, 2014 at 9:06 PM
    gozar
    gozar Well-Known Member
    Arizona
    2010 TRD Off-Road 4x4
    Fiend, did you ever figure it out?
  3. Jun 26, 2014 at 4:45 PM
    Fiend13
    Chad
    Yeah, it's the recirculating air motor under the glove box. Have to replace it because the screws they use to balance the fan come loose over time. The new tacoma's have ball bearings in the fan motors so it eliminated the problem. Just have to get a new model motor and replace it. It's only a few screws and a wire harness.
  4. Jun 26, 2014 at 6:42 PM
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    Before you replace it, you might try balancing it. Or greasing the bearings. There are a couple threads here that can walk you through it.
  5. Jun 26, 2014 at 7:52 PM
    Fiend13
    Chad
    That's if you have the motor with the bearings. Mine has the one that has the fan balanced with screws. You can take the fan out of the housing and tighten/loosen screws as needed with a lot of testing by turning it on to find the right balance, but even then it doesn't fix it for very long.
  6. Jun 27, 2014 at 5:07 AM
    braik
    Louisville, KY
    2006 4.0L 4x4 BASE
  7. Jun 27, 2014 at 5:51 AM
    Fiend13
    Chad
    Oh ok, I gotcha. I looked through this thread and must have overlooked that part. I thought the old motors were screws only to balance it. Thanks for the info!
  8. Jun 27, 2014 at 6:09 AM
    braik
    Louisville, KY
    2006 4.0L 4x4 BASE
    No problem
  9. Oct 1, 2014 at 1:55 PM
    Fiend13
    Chad
    So I got my truck in the shop to have the LCA's changed and the blower motor since they're under the extended warranty and it's free and they changed the blower motor but when you hit the recirculate air button it still had a constant tick. Any other suggestions outside of the blower motor?
  10. Oct 1, 2014 at 4:11 PM
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
    Are you sure they used the new/OEM motor? Otherwise check your cabin air filter for leaves and other crap.
  11. Oct 1, 2014 at 4:31 PM
    Fiend13
    Chad
    They told me what it was but I forget the name, it has something to do with when you hit the recirculate air button. If recirculate air is off then theres no noise, but when one it starts to tick after a while
  12. Oct 1, 2014 at 10:18 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  13. Oct 2, 2014 at 5:02 AM
    Fiend13
    Chad
  14. Oct 2, 2014 at 5:05 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Easy to replace yourself.
  15. Oct 2, 2014 at 5:08 AM
    Fiend13
    Chad
    The truck is still under the extended warranty so I may have a shop do it since it's all free. I'm gonna look into it more though and see what needs to be done since I've never replaced one before.
