Recirculate Button
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRD Larry, Jan 8, 2017.
  1. Jan 8, 2017 at 5:34 PM
    TRD Larry
    TRD Larry [OP] trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    I have a 2008 Tacoma access cab and when I depress the recirculate button the light does not come on. I pulled the climate control panel out and looked at the connections and everything looked OK. The little icon on the button lights with the other panel lights, the light that shows the recirculate button is depressed does not light. Don't use this very often, I just like things to work the way then should. Looking for suggestions on how to go about finding out what the problem is.
  2. Jan 8, 2017 at 5:36 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    With blower motor on?
    ChemDawg likes this.
  3. Jan 8, 2017 at 5:38 PM
    TRD Larry
    Larry
    South Park, PA
    Tried with blower motor on and with motor off. Tried with AC on and AC off. The button was working last week.
  4. Jan 8, 2017 at 5:39 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    You should check continuity of the lamp itself.
    inwood customs likes this.
  5. Jan 8, 2017 at 5:41 PM
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    Recirculate won't come on if you have it on defrost. Put it on the vent setting and see if it comes on
    File IFR and Mush Mouse like this.
  6. Jan 8, 2017 at 5:43 PM
    PvilleJohn
    Powdersville SC
    SVT Raptor
    It should also come on even if the blower is off. This stops all air flow into the cab while driving. If you've ever noticed air still coming through the vents even with the blower is off, that's why. Gotta have recirculate on and it closes those fresh air vents and stops all air flow
  7. Jan 8, 2017 at 5:46 PM
    inwood customs
    Dave
    Thanks, i was gunna try..... but its pretty cold out
    PvilleJohn[QUOTED] likes this.
  8. Jan 8, 2017 at 5:50 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    I have the opposite problem my a/c light doesn't light up
  9. Jan 8, 2017 at 5:52 PM
    TRD Larry
    Larry
    South Park, PA
    I will try taking if off defrost. I know I usually have the setting on defrost/air. I will try that tomorrow morning. It is too dark and cold now to mess with it. Thanks.
    PvilleJohn likes this.
  10. Jan 8, 2017 at 5:53 PM
    TRD Larry
    Larry
    South Park, PA
    My AC lights works just fine.
  11. Jan 8, 2017 at 5:54 PM
    File IFR
    Central MA
    Check to see if the recirc doors actually open and close.
    Pull the glove box off and observe the 2 doors above the filter housing moving up or down.... no tools required for this.
    PzTank likes this.
  12. Jan 8, 2017 at 5:55 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    so does your recirculation button. just take it off defrost
  13. Jan 8, 2017 at 5:55 PM
    TRD Larry
    Larry
    South Park, PA
    That is easy to do. I have had my glove box out many times. While I am at it I might as well change the cabin filter.
  14. Jan 8, 2017 at 6:14 PM
    PvilleJohn
    Powdersville SC
    SVT Raptor
    Yes sir! That's prob what's wrong. Hope that's it!
  15. Jan 8, 2017 at 6:30 PM
    TRD Larry
    Larry
    South Park, PA
    Could not wait until tomorrow, had to check it out. It was on the defrost setting. I never use the defrost, my wife was the last to use the truck and she must have put it on defrost. Took if off defrost and everything is working like it should. Damm wife, she has her own car to drive. Guess she does not want to use up her gas. I guess the next mod will be a kill switch. When it doesn't start she will use the car.
    Thanks again guys for all the help. I also learned about the recirculate button and defrost mode. Thanks everyone.
    mbennett27 and PvilleJohn like this.
  16. Jan 8, 2017 at 6:44 PM
    File IFR
    Central MA
    Good to hear!
    It is funny that you tore into your HVAC panel to see what was wrong. I've done shit like that too :oops:
  17. Jan 8, 2017 at 6:47 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    same thing happened to me today glad I found this thread, but I noticed the recirc light didn't work on defrost and defrost/floor I think
  18. Jan 8, 2017 at 6:49 PM
    PvilleJohn
    Powdersville SC
    SVT Raptor
    Glad to help buddy;) :thumbsup:
  19. Apr 22, 2021 at 1:55 PM
    Kaleeth97
    Kaleeth97 Active Member
    Keegan
    2006 dcsb trd off road tacoma
    Headlights/fog lights. Straight pipe exhaust? Hopefully more mods to come
    Does anyone know the voltage for the little LED on the AC and recirculating button? I’m curious
