Recirculating air button help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reece315, Feb 29, 2016.
  1. Feb 29, 2016 at 3:22 PM
    Reece315
    Reece315 [OP] Member
    Reece
    League City, TX
    05 PreRunner
    Hello, I have a 2005 Toyota Tacoma TRD Sport and the recirculating air button keeps turning OFF and ON by itself. Any ideas?? Thanks!
  2. Feb 29, 2016 at 6:43 PM
    Reece315
    Reece
    League City, TX
    05 PreRunner
    image.jpg image.jpg I should probably also add that I can only run my fan on high because the plug burnt up. I'm not sure if that helps at all.
  3. Feb 29, 2016 at 9:34 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Once you rectify the plug problem make sure you tweak the terminals on the blower motor resistor. The reason they cause high resistance issues is due to poor contact on the plug. Tweaking the terminals will provide much better contact to the plug and will keep those issues you have at bay.
  4. Feb 29, 2016 at 10:20 PM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    Fire hazard. It's either arcing and sparking due to poor connection, or you have another issue ie: high current draw through motor/resistor
  5. Mar 1, 2016 at 8:39 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Loose connection = high resistance = heater = burned wiring.
    You need to replace that connector. Period. Unless you like fire.
    Parts needed:
    Connector: P/N 82141-04M40
    Resistor Assy: P/N 87138-04052
    Clearwater Bill likes this.
  6. Mar 8, 2016 at 10:04 AM
    Reece315
    Reece
    League City, TX
    05 PreRunner
    I replaced the resistor and cleaned up the resistor connector and it works good as new! Thanks guys!
  7. Mar 8, 2016 at 10:04 AM
    Reece315
    Reece
    League City, TX
    05 PreRunner
    He recirculating air would come on when my truck would try to overheat also.
