recomendations for seafoming
Discussion in '1st Gen. Tacomas (1995-2004)' started by MCRANEY, Mar 5, 2009.
  1. Mar 5, 2009 at 7:50 PM
    MCRANEY
    MCRANEY [OP] WARTHOG
    CRESTVIEW FL
    03 Tacoma 4WD SR5 TRD
    3" Lift 285/75 16R Tires Aries Stainless Steel Grille Guard, KC Lights
    Not going to start a poll. I just want to see how many people recomend seafoaming. I want to try it, just a little nervous.
  2. Mar 5, 2009 at 7:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i highly recommend it man. been doing it on quite a few vehicles and lawn mowers for a good while now........always good results...never any problems from my end.
    go thru the brake booster line.............easy as pie.
  3. Mar 5, 2009 at 9:33 PM
    bpiersma
    bpiersma Member
    Solvang, CA
    2001 PreRunner TRD Lunar Mist
    I did mine a few days ago. Hard to tell if there is any difference in the idle...maybe slight. I'm trying to improve gas mileage, so that will take time to determine. If nothing else, it's fun. Fill your whole neighborhood with white smoke.
    If you do, while it's billowing white smoke out the tail pipe, put a white cloth over/under it to catch whatever comes out (be careful not to breath the exhaust...just do it for a few seconds and then run away). Check the cloth to see if any black chunks came out from your valves.
  4. Mar 5, 2009 at 9:54 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    I was nervous as hell the first time too. Just follow the directions on the can and you'll be good.
  5. Mar 5, 2009 at 10:30 PM
    BUK 0H5
    BUK 0H5 Still For Sale
    Queen Creek, AZ
    Silver 09 2.7L Manual AccessCab SR5 PreRunner
    Removed Mud Flaps, Suspension TSB, 5100's all around, JVC KW-AVX710 Head Unit with Metra surround.
    Seafoam makes the baby Jesus cry.
  6. Mar 5, 2009 at 10:43 PM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    '01 Limited DoubleCab 4x4
    3" SL, Nerf Bars, 33" BFGs, K&N, Deckplate, Royal Purple
    I just did mine today for the first time. It blew out a lot of smoke for about 10-15 minutes and then cleared right up. The truck wasn't running bad or anything before, but I just rolled over 65K mi and decided to do a little routine maintenance. I also flushed and filled the coolant system w/ some new Toyota Red coolant. $30/gal ouch!
  7. Mar 6, 2009 at 10:35 AM
    2004Taco
    2004Taco Well-Known Member
    Long Beach,CA
    04 PreRunner SR5 Trd
    Magnaflow and Deckplate Mod Billet grille
    hahaha x2
  8. Mar 6, 2009 at 10:54 AM
    Racinkid13
    Racinkid13 Problem Child
    Kent,WA
    SR5 TRD debadged and beaten
    many
    Aint bad, seems to get rid of most of that carbon build up. Ive got a nice exhaust leak right in front of my cat, and i can watch that black crap just dribble out.
  9. Mar 6, 2009 at 11:13 AM
    gonzo6up
    gonzo6up Well-Known Member
    Middle Tn
    09 tacoma SR5 4x4 sport
    tint/ vent visors/ seatbelt chime mod/ DTRL Mod
    seafoam is the best stuff on hte market for cleaning out the engine and fuel system. It will look a little scary when you start your truck up but that's normal and hte difference is unbelieveable
  10. Mar 6, 2009 at 3:40 PM
    dustinuhls
    Manhattan, KS
    I was told that if I put it in my gas tank that I should change the fuel filter soon after... Is this true? Does it do any damage to the fuel filter? I would think it would help clean it out also. I thought putting it in your gas tank was just to help clean the injectors and such.
  11. Mar 6, 2009 at 5:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    nah.....you can put some in your gas tank.....no real need to worry about the filter.
