Recomendations on wood stoves
Discussion in 'Garage / Workshop' started by motorcycle07, Aug 15, 2013.
  1. Aug 15, 2013 at 7:03 PM
    motorcycle07
    motorcycle07 [OP] Well-Known Member
    Middle of somewhere
    '13 Acc 4X4 V6 TRD Tow
    I am in the market for a wood stove for the first time and I was looking for recommendations for stove brands and models. I am looking for an indoor stove, that doesn't tie into central heating duct, has a glass front loading door and is capable of heating at least 2000sq ft. As far as the other stove qualifications I am open to recommendations, (e.g. cast vs/steel, size of logs accepted, perceived ease of use, ash tray location, etc.). I am replacing what I am going to call a freestanding (cast iron) fireplace that was abused to provide partial heat to said house while running wide open all the time during a southern Iowa winter.
    Thanks for any advice
  2. Aug 17, 2013 at 8:07 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
  3. Aug 17, 2013 at 8:58 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
  4. Aug 18, 2013 at 5:38 AM
    motorcycle07
    Middle of somewhere
    I have browsed through this thread, but was looking for more specific info. I have read mixed reviews on the Lopi's on other websites.
    In response to OZ's post: I see some stoves listed as having a cooktop. Are stoves that do not have a cook top capable of cooking? Are the stove internals different to allow more heat to reach the top surface of the stove?
    Also the brands I know I can get locally are Drolet, U.S. Stove, Vogelzang, Pleasant Hearth, and Jotul. Any recommendations on these?
    Edit: I can also get the pacific energy local so I will check out your recomendation OZ. How many sq. ft. does this stove heat for you? I know it says 2000, and that you surely encounter much harsher winters in BC, but I am just trying to wrap my head around the seemingly arbitrary numbers.
    Thanks
  5. Aug 18, 2013 at 9:12 AM
    OZ-T
    Peter North
    British Columbia
    The Alderlea T5 heats our main and upper floor which total approx 2000 sqft
    The size a stove can heat is fairly dependent on the layout of the building as well
    The T5 is a cool " hybrid " stove as it uses a steel inner firebox but is wrapped in cast iron panels , so it heats up fairly quickly but holds and emits heat for quite a while after it has gone out due to the thermal mass of the cast iron
    The cook top on this particular model has a split grate , so you can swing either side of the top outwards away from the centre of the stove to regulate the heat for whatever you are cooking
    The other think I like about the T5 is it is deep enough that you can put 18" logs in front to back
  6. Aug 18, 2013 at 9:25 AM
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
  7. Aug 20, 2013 at 10:47 PM
    OZ-T
    Peter North
    British Columbia
    Might be personal preference but I think a fire built with the logs front to back burns better
  8. Sep 7, 2013 at 10:23 AM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    My brother just bought a used stove with a 240cfm blower kit on it. It also has a lil tube 1/2 inch or so that goes out the back of the stove through the wall so the stove takes the oxygen from outside rather than Inside the home. He said that he woke up everyonce and awhile a lil light headed and that fancy lil tube will eliminate oxygen being taken from inside the house.
  9. Sep 7, 2013 at 10:52 AM
    OZ-T
    Peter North
    British Columbia
    Sounds more like carbon monoxide is getting in the house versus oxygen being depleted which is pretty much impossible
    Does he have a carbon monoxide detector ? If not , he should get one
  10. Sep 7, 2013 at 11:05 AM
    amadougrand
    amadougrand Well-Known Member
    Southwestern Idaho
    Tacoma TRD Off-Road
    I just installed a Blaze King in my new cabin and love it. With the new energy compliance regs they cut down what size heat pump and AC I could put in so I augmented after final inspection. The Blaze King is a bit oversized for the house and I think even the Blaze Princess will do 2000sf, but the selling point for me was a 40 hour burn time on the King set to low. Leave the cabin all day and come back to a warm house without the heat pump ever being used.
    There are many brands, but the hands down favorite for my area even with the old timers.
    Link to the website: http://www.blazeking.com/
  11. Sep 7, 2013 at 1:27 PM
    RideFast
    Jesse
    Tacoma
    I'm not sure about the old stove and if it was even functioning correctly but this new stove is rated to 1500 sq ft and its smaller than the old stove rated at 1000 sq ft. I thought the stove was slowly takin the oxygen from the house and thsts why he was feeling funny when the house was closed up. Yes he has a carbon monoxide detector in the hall way. Never goes off, he replaces batteries every year.
    We will see in a few months how the new stove does. I'm curious how the blower kit is going to work. It has a sensor that turns the blower on once the stove reaches a certain temp.
  12. Sep 7, 2013 at 1:30 PM
    OZ-T
    Peter North
    British Columbia
    Unless you have a brand new , super tight house , the negative pressure exerted on the house by a woodstove won't ever drop the oxygen levels
  13. Sep 8, 2013 at 6:54 AM
    motorcycle07
    Middle of somewhere
    After quite a bit of research I decided on the Osburn 2200. It is to be delivered tomorrow. If money was no object I probably would have bought the Jotul Rangely. Thanks for everybody's input. Also if anyone else is looking at this stove let me know and I will post up what a think of it, if it ever gets cool enough to use it that is (Damn near 100F for the next two days :( ).
