Recommend 5 lug brake pads and rotors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saugus, Sep 3, 2022.
  1. Sep 3, 2022 at 12:35 PM
    saugus
    saugus [OP] Well-Known Member
    It's about time to change the brakes again. I hear a clunk when coming to a stop probably once on each 7 mile trip for work. I don't know what it is, but the brakes don't seem to work as good as new. They will shake some when tested. I changed the brakes and rotors in 2011 with 135k to bembo rotors (I think) and Hawk performance pads. It never really wowed me though. I now have 208k, and I'm thinking of saving some money and just buying Powerstop evolution kit.
    https://www.amazon.com/gp/product/B008WH45ZE?smid=ATVPDKIKX0DER
    Does anybody care to correct me on this? I see suggestions of OEM brakes and aftermarket rotors but I don't really know what is good.
  2. Sep 3, 2022 at 11:13 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Clunking may be bad control arm bushings or ball joints. For brakes, get semi metallic for braking power or ceramic for longevity and quietness.
  3. Sep 5, 2022 at 5:50 AM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
  4. Sep 5, 2022 at 9:07 AM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    I would get the OEM. They have lasted many up to or beyond 100k and not all that expensive.
  5. Sep 5, 2022 at 9:35 AM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Stay away from drilled and/or slotted rotors. The only thing they improve on besides looks is adding brake dust to your rims and decreasing longevity. I fell for those Powerstops and they were garbage. I removed them after about 6 months. Get a mid priced rotor with a name you recognize. I have used Wagner with great results and they have good pads also, but I would go with Akebono pads.
  6. Sep 5, 2022 at 2:29 PM
    saugus
    ok, so I bought the dealer parts. Cost $215. I just hope my oversized tires aren't going to be an issue.
