Recommend a Bluetooth obd2
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rusty1606, May 22, 2016.
  1. May 22, 2016 at 11:58 AM
    Rusty1606
    Rusty1606 [OP] Active Member
    Looking at getting a Bluetooth obd2 for my android phone. Can you guys give me some recommendations from ebay or Amazon that you've used. Checked reviews and some seem hit or miss.
    Thanks
  2. May 22, 2016 at 12:06 PM
    armyoffoo
    armyoffoo Scrotie McBoogerballs
    Houston, TX
    2018 Tundra CM TRD Sport
    I have used PLX Kiwi 2 for about 10 years now on multiple vehicles, works great, thinking about getting the Kiwi 3 since it takes up less space.
  3. May 22, 2016 at 3:49 PM
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    I use the kiwi 3. Damn good device but for $100 I probably would have looked elsewhere if I had an android. With my iPhone, the Kiwi 3 was my only option for Bluetooth
  4. May 22, 2016 at 4:22 PM
    Pigpen
    Dan
    Northwest Montana
  5. May 22, 2016 at 4:46 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Save the money and just buy a ultragauge, I've used both the blue tooth and wifi OBD scanners. The ultragauge is the best and easiest to use.
  6. May 22, 2016 at 4:54 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Im in agreement with usethesecond. I've tried a bunch of the BT transmitters. Some work good, some not so much. I like the dedicated units. The best are Ultra Gauge and Scan Gauge. Less hassle and easy to use.
    I do keep a BT unit on hand to check codes for others. In addition, these are cheap, usually less than $20 for app and BT transmitter.
  7. May 22, 2016 at 4:58 PM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    I just use the you that came with my truck.
  8. May 23, 2016 at 8:08 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    I use this as well. Nice thing is that it can be moved from vehicle to vehicle. I paired it with OBDFusion. I used it this weekend to check my AT Temp after doing a fluid flush. OBDFusion has a great interface.
  9. May 23, 2016 at 8:12 AM
    Pigpen
    Dan
    Northwest Montana
    I've got Torque Pro and it does what I want. I don't use it often. Initially I used it a lot to see how long it took to get to certain engine temps on warm up, battery voltage during winching and engine start up, actual speed with 33s... This thread reminded me that I can remove the reader. I'm sure it's not much draw, but if I'm not using it...
