Recommend lamps to brighten up the cab
Discussion in '3rd Gen. Tacomas (2016-2023)' started by porterx, Feb 6, 2019.
  1. Mar 4, 2019 at 10:27 PM
    #41
    deAutoLED.com
    deAutoLED.com Well-Known Member Vendor
    Thanks for the support.
  2. Mar 4, 2019 at 11:37 PM
    #42
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Definitely white and very bright though it's not a huge deal to install an inline resistor to drop output. Sounds like you'd like the reds more. I'm just fed up with interior lighting that is grossly inadequate and these do the trick.
  3. Mar 10, 2019 at 5:30 PM
    #43
    coyota19
    coyota19 Member
    19 Quicksand SB OR
    I have a 2019 Tacoma OR, and I ordered LED bulbs for the interior lights (map and dome). When I installed them, they work independently, but when the switch is set to "turn on when the door is open", they will not come on. You can turn any of them on independently however, and when you flip the switch to turn them on they work fine. Since I really want the interior lights to come on when a door is opened, I put the original bulbs back in. Now, even THEY won't come on when a door is opened.
    Anybody have any suggestions on what happened? I've looked at the fuses (both boxes) but can't tell which fuse might be running a 'door open' switch.
    Do you have interior LED lights for a 2019? Thanks.
    PS. The vendor from whom I bought the LED's provided excellent service, completely refunding my money and not requiring me to return them.
    AxisCab likes this.
  4. Mar 10, 2019 at 6:01 PM
    #44
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    we needs a volt meter, precioussss
  5. Mar 10, 2019 at 6:22 PM
    #45
    deAutoLED.com
    Yes, it was most likely a resistor issue with the other set you had and they might've even looked similar to the deAutoLED but are not. I mention this because I have seen this a lot. Please email Support@deAutoLED.com or please send me your email here. I will let them know to give you a deep discount on this kit.
    Thanks
