Recommend me a reman caliper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thyces, Apr 9, 2018.
  1. Apr 9, 2018 at 7:46 PM
    Thyces
    Thyces [OP] 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Boots are intact. No leakage either. Fresh fluid from 6 months ago when my drivers side seized and I replaced that one.
    tacoma16 and Bebop[QUOTED] like this.
  2. Apr 9, 2018 at 7:48 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Shitty caliper.
  3. Apr 9, 2018 at 7:49 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    What would you deem as maintenance? I visually inspect and clean at least every 4-6 months... Alot more often in the summer.
  4. Apr 9, 2018 at 7:51 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    This is what I'm guessing but would like to have as much input/info as possible to correct anything I may be doing wrong.
    Bebop[QUOTED] likes this.
  5. Apr 9, 2018 at 7:52 PM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    lol i thought about doing this months ago. get outta my head
    need to ctrl + s for a just in case scenario
  6. Apr 9, 2018 at 7:53 PM
    Bebop
    Nick
    Tacoma calipers are simple. Grease the slide pins and the back of the pads. Sand the rust off the hubs to make a smooth mating surface between the rotor and the hub and torque the wheels to spec.
  7. Apr 9, 2018 at 7:57 PM
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    how about drums? what do i look for? how do i know when to change, im learning to take better care of my truck day by day
    Biscuits likes this.
  8. Apr 9, 2018 at 7:58 PM
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    WAIT DONT DERAIL THE TOPIC! classic Manfred
  9. Apr 9, 2018 at 7:58 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
  10. Apr 9, 2018 at 7:58 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Napa, Cardone, blah blah blah. They're all rebuilt in some third world country (not that there's anything wrong with that). My only advice is get them from a place that is close by, well stocked and has a warranty! It is hit or miss..
  11. Apr 9, 2018 at 7:59 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I did just that. They lasted 2 months past the warranty.
  12. Apr 9, 2018 at 8:01 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Napa calipers are awesome, they are powder coated so they dont rust and they have always worked great for me when ive used them.
    Bebop and Thyces[OP] like this.
  13. Apr 9, 2018 at 8:05 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I think I disagree. Some companies do better work than others.
    http://www.nugeon.com/company.html
    This is the company that does the ones I linked. Remanufactured in the US.
  14. Apr 9, 2018 at 8:08 PM
    evoviii1220
    evoviii1220 Well-Known Member
    Dan
    NJ
    05 4x4 DCSB
    Silver touch up paint
    I had the same problem as you. Got a reman one off rock auto. Painted it. Seized in less than a year. Went and got Napa lifetime (so if it happens again I just go get a new one no questions asked) black powder coated calipers and they’ve survived two northeast winters. Holding them in hand you can see they’re much better made.
    Biscuits, tacoma16 and Thyces[OP] like this.
  15. Apr 9, 2018 at 8:08 PM
    #35
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Shoe wear and might as well do the rebuild kit (a bunch of springs) apperantly they last very close to forever.
    tacoma16 likes this.
  16. Apr 9, 2018 at 8:08 PM
    #36
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Bebop likes this.
  17. Apr 9, 2018 at 8:08 PM
    #37
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Thanks. Good know.
  18. Apr 9, 2018 at 8:10 PM
    #38
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I'm sorry. I don't do fill in the blank. What is it you were trying to say?
  19. Apr 9, 2018 at 8:12 PM
    #39
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    There are huge differences between nessecary and good practice. Is it nessecary to lube (rust protect) a brand new piston in a caliper with a brand new perfect boot? No not nessecary. But a good practice. I am talking literally wiping the piston as if you were greasing a muffin pan. No extra globs but enough to give a coating which is mostly wiped by the seal leaving a mostly insignificant ring of lube at the base of the piston and seal. In doing so I get a chance to inspect the parts for issues while brand new which is also good practice on any new parts.
    When you speak of maintenance that is another good time to inspect the boots and pull them back to check for rust on the piston. We tend to power wash everything including rims which can push water past the boot and guess what? I hate power washers as they do a shit ton of damage down the road.
    Now as far as good and bad reman anything. I would have to see what is considered the quality part vs the inferior part side by side and have someone explain the differences. I have bought reman calipers and watched as the guy pulled parts and assembled them in front of me. This was one of the suppliers for just about every local parts store in the province. I have also rebuilt calipers a number of times myself (motorcycle). Unless the piston has rough machining or some other defect or the seals are inferior quality or simply you got a bad core that slipped past QC and shouldn’t have been rebuilt in the first place I am not sure what is meant by bad reman parts. Any part new or rebuilt / reman can be defective right out of the box.
    Thyces[QUOTED][OP] likes this.
  20. Apr 9, 2018 at 8:23 PM
    #40
    Thyces
    Ontario
    2009 DCLB TRD Sport
    So this, I do. When I installed them I figured it won't hurt to lay a nice film of grease along the outside of the boot and coat the piston on the brim and inside the hollow. As for the remanufacture of a part I think you answered your own question with all the variables you listed. Those are the things that can go wrong with a reman part. I would imagine it happens more in some companies and less in others depending on the employer, employees and a host of other factors. I don't think looking at them you would know. Totally agree with the power washer remark and that is something I will be taking into account in the future. Thanks bud.
