Recommend Off Road Shop (S.D.)
Discussion in 'Southern California' started by wolfman05, Apr 16, 2010.
  1. Apr 16, 2010 at 12:34 AM
    wolfman05
    wolfman05 [OP] Well-Known Member
    Seattle, Washington
    05 Prerunner
    Working on it
    Looking at dumping about 5K-6K into my first build on a 05 prerunner. To save money and buy more shit I'll most likely be doing the install my self. The question is where to buy from. ORW, Down South, The Truck shop, ect. I'm looking at the best deal on parts don't care about labor. Looking at icon res on all 4 corners, UCA, Total Chaos 3.5 spindle, denver 1.5" 8 or 10 pac AAL, 17" wheels on 285's. Right now I'm thinking ORW, my boy is saying fuck ORW and go the Down South or The Truck Shop (i think its called?). What do you say?
  2. Apr 16, 2010 at 12:40 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Wheelersoffroad, Down South Motorsports are the 2 companies I would go with. Probably get the camburg spindles over the TC ones also, they are cheaper. :thumbsup:
  3. Apr 16, 2010 at 1:04 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    What he said. :p
  4. Apr 16, 2010 at 1:15 AM
    wolfman05
    Seattle, Washington
    05 Prerunner
    Working on it
    Thanks bro, I'll check out the camburg.......Well after about a half hour or so I found some interesting comments about Camburg vs TC. I like the price of the Camburg but after a little reading I might just to with the TC after all. My first build....still researching, but thanks for your inputs and advice.
    http://www.toyotanation.com/forum/archive/index.php/t-173282.html
    toku58
    01-04-2007, 11:49 PM
    THought I'd throw this in from Scott at Camburg.
    It's great to see so much interest in our Camburg products. I'm a little dissappointed that some mis-information is going around though.
    Total Chaos makes great products, but here are the reasons why our upper arms are a better product and value than theirs.
    1) We use a higher quality Aurora 1.00" teflonlined uniball. It is both made and assembled in the USA. The next best bearing is a mil-spec NHBB
    that is about 4x the cost and no one supplies with a kit. In our little world we don't need anything stronger, unlike the aerospace industry.
    2) We were the first to offer zerk grease fittings on the a-arm that are used in conjuction with thicker walled 7/8" CNC machined sleeves and energy
    suspension polyurethane bushings. This offers less deflection in the arm and keeps the geometry more accurate.
    3) We use a smaller 5/8" F-911 bolt compared to TC's 3/4". Since we're using a smaller diameter bolt we're able to get more mis-alignment out of the uniball. Strength is not compromised since we're using an aircraft grade F911 bolt. Your spindle will break way before that bolt does.
    4) All our mis-alignment spacers are machined from 17-4 stainless steel. We use nothing but the best. One of the huge differences is how our lower uniball/spindle insert is. It is considerably stronger and costs a lot more to machine. TC and others do it as two pieces which isnt as strong and costs less to make. We have a ton more shear lateral strength because of our design.
    5) We put more castor into the arms which gives better straightline stability both on and off-road.
    6) The design and geometry TC has will cause the spindle to hit the frame/coil bucket on full compression. We have plenty of clearance. Sprindles or any suspension components coming into contact with anything is a design flaw and shouldnt take place.
    7) We use a high-gloss steel gray powdercoat, not black. It holds up very well and we've had ZERO problems or complaints.
    8) I'm not sure if TC supplies you with polyurethane grease, we do. We also supply you with zinc-plated washers, just like TC.
    - Scott Zindroski
    1) I can't answer don't know what TC uses?
    2) Camburg uses straight Zerk fittings that you will need a special
    ....fitting to grease once it is installed.
    ....TC uses a 90* zerk fitting make more sense, and is easier to access!
    3) Bolt size? Not a big deal?
    4) Misalignment spacers? The TC appear to be much more heavy duty,
    ....and better fitting.
    5) Ask any professional that sells both the TC give more castor!
    ....[Qoute] "Wheelers off road" Camburg about 2* TC about 3* of castor.
    6) This is probably true! But this is why it screwed up my alignment! It
    ....gave Too much clearance. 1/2" too much.
    7) Color?? Who cares? Color doesn't matter!
    8) TC doesn't come with Grease. But your the Camburg does have
    ....washers like TC's But TC's washers are Milled not Cheap stamped
    ....like Camburg. And TC's bushing sleeves are precision milled. Camburg's are simple tubing steel cut to length.
    I understand that Camburg Or TC could tell you anything they want to make their product seem better than the other?
    But I am Only talking from experience? I have owned both! And I am more than willing to pay a bit more for the quality and piece of mind that these TC will give me!
    But the Biggest Factor is that Camburgs own Rep here admitted that the TC were made better? He had nothing to gain because I got them from Wheelers Off road. And I do all my own work on my truck. So he would have nothing to gain by backing one over the other.
    He was just giving his professional opinion. He is one of the best fabricators in the state. IMHO!
    I have 7 yrs. experience as a welder and fabricator myself. Designing hydrolic lifts and Modifying cars and trucks. Although I am no longer in the business I do know the difference in quality when I see it.
    Although this is just MHO!
    I am simply giving my opinion on these to products because I have first hand experience with both.
    Both of these UCA's are of good quality! But TC's are clearly on a different level. IMHO!
    SCEXPLORER
    01-05-2007, 12:00 AM
    Definitely Noted. I like you wished I went with TC over Camburgs. I only went with Camburgs cus I bought it used for a good price. I just wanted to include the facts from Camburg so people understand what their getting. I'm trying to find one from TC so that everyone can read both the company's and your opinion.
    So does this mean you're not getting the replacement camburg UCA to measure for us poor folks who got camburg??
  5. Apr 16, 2010 at 7:49 AM
    vitang
    vitang Well-Known Member
    diamond bar
    07 TRD Sport 4wd
    Engage Front Long Travel, Giant Rear Long Travel, KR Fab rear bumper, tire gate and Jerry Can cage.
    I have a set of TC uca's that are sitting in my garage that I want to get rid of. If you're interested let me know $350 and I'll post pics later.
  6. Apr 16, 2010 at 8:01 AM
    peejay
    peejay Yep im that Peejay..
    PJ
    San Diego
    Running a tricked out rzr xp 4
    Rollin a Hemi, and wheelin a sick xp4
    Hey bro, before you spend any money, Roll up to the Truck shop and just talk to james and tell him what you want to do, he'll sit down with you and lay it all out. Especially if your going to spend that amount of money, he'll take care of you..
  7. Apr 16, 2010 at 9:38 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    X10, I've never met James , or been to his shop, but I HAVE seen his work. Very Clean, Very Professional, not hacky & every9one I've talked to has nothing but good things to say about him & his operation, He's also the one who caged this: ( & I mean caged inside & out, picture doesn't do it justice ).....:cool:
  8. Apr 18, 2010 at 6:55 PM
    wolfman05
    Seattle, Washington
    05 Prerunner
    Working on it
    Thanks for the help. Getting ready to buy next week installing should be interesting. wish me luck.
  9. Apr 18, 2010 at 6:58 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    Bro, check your email,just sent you some links on tires.
  10. Apr 18, 2010 at 7:06 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
  11. Apr 18, 2010 at 7:08 PM
    ToucanV13
  12. Apr 18, 2010 at 7:25 PM
    wolfman05
    Seattle, Washington
    05 Prerunner
    Working on it
    I'll take a look at the pic.
  13. Apr 18, 2010 at 9:11 PM
    singlefin
    singlefin Well-Known Member
    Hood River, OR
    Syncro
    I use The Truck Shop and ORW. Wouldn't say screw ORW (Jason @ Balboa is who you want to deal with) cause I'm pretty sure a few shops that people rave about on here use them as a distributor for SOME things. ORW can get you good deals on parts. However if your looking for all in one, parts and labor then I'd suggest calling The Truck Shop. But just shop around if you want a good deal. Kartek and Wheelers offroad are good as well. Don't think DSM stock IVD stuff.
  14. Apr 18, 2010 at 9:18 PM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    I like The Truck Shop. I have never dealt with the others but I know James has been good to me and has help a few others here on the forum. I like to deal with him cause I am local. Go in there and tell him you are from TacomaWorld, and "Tree" said he recommended him. Talk to James he is the owner. He has always given me prices that are very good. Good luck. Shop around I am sure there are a lot of good places.
  15. Apr 18, 2010 at 10:39 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    I have almost the same setup(minus spindles) and you might want to rethink those Icon rear shocks.. I regret not having bought an adjustable type one, they are really bouncy without 200+ lbs in the back
    but good luck.
    and yeah deal with sonny at downsouth or kartek was good for me.
  16. Apr 19, 2010 at 1:51 AM
    wolfman05
    Seattle, Washington
    05 Prerunner
    Working on it
    If I did I didn't mean to slam ORW. Actually I might be going through them for the parts, Junior over at ORW really seems to know his shit.
  17. Apr 19, 2010 at 10:02 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  18. Jun 4, 2010 at 11:11 AM
    teeoffdang
    teeoffdang Member
    2005 tacoma sr5 sport
    I am interested. Please let me know. thank you
    danny
  19. Jun 6, 2010 at 6:45 AM
    TRICOMA
    Tri
    Carlsbad, CA
    Dude those UCAs have been gone for a while
