Recommendation for first welder
Discussion in 'Garage / Workshop' started by goldentaco03, Nov 24, 2018.
  1. Nov 25, 2018 at 5:45 PM
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    The 211 will do 3/8" for a skilled welder however I personally would not use it doing 3/8" for structural work because I never liked the penetration of the 3/8" on butt welds unless time is spent grinding angles and time is valuable.
  2. Nov 25, 2018 at 9:56 PM
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    $500-$900 no need for over quarter inch. Strictly hobby more or less. Been looking at the Hobart handler 140 seems like most people say it’s more than adequate more most/all armor
    mynewtoy and m603holden like this.
  3. Nov 25, 2018 at 9:58 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Bingo
  4. Nov 26, 2018 at 12:53 AM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    I like buying cheap HF crap or no name tools for most things but when welding and your life might just depend on it I say save up and buy the best. Lincoln or Miller.
  5. Nov 26, 2018 at 7:13 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    FWIW I took my Hobart tig welder apart out of curiosity, and almost every part under the hood was blue and said miller on it. Biggest difference between the Hobart 140 and the miller is the autoset feature, where you select wire size and amperage, and the machine automatically adjusts wire speed. The 180 and maybe 211 units are dual voltage, which is a cool feature I think.
    shakerhood likes this.
  6. Nov 26, 2018 at 8:18 AM
    goldentaco03
    Liam
    NJ
    Isn’t Hobart a subsidiary of miller? It’s like their hobby/diy line vs professional. Like craftsman vs snap on (although those two companies aren’t related).
  7. Nov 26, 2018 at 8:27 AM
    m603holden
    Marteeen
    New England
    Same. But different
  8. Nov 26, 2018 at 8:53 AM
    cory02taco
    Cory
    Maine
    They're both owned by the same parent company.
  9. Dec 17, 2018 at 10:50 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I noticed stuff stamped Miller on my Hobart also.
  10. Dec 19, 2018 at 7:48 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I've been using a Hobart Handler 150 for over 20 years. Performed flawlessly so far. I'd agree with someone above who recommended 190 or a little bigger if you plan to weld anything 3/8 or larger.
  11. Dec 20, 2018 at 12:59 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    always get a machine that is higher amperage then what you think you will use, you will always end up wishing for just a little bit more... And getting something that can both run on 110 voltage but at a lower output and 220 for when you really need it. I have a miller xmt 350, dynasty 210 and a millermatic 141 and there are plenty of times when I'm using my 141 where i only have 110 power and wish i could use my 350 for even 1/4".
  12. Dec 23, 2018 at 10:18 AM
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    Check factory rebates. I got $300 back on my Miller Multimatic 215. It does more than what your asking for but the rebates were on a whole bunch of models. I think they have a new sale every three months or so.
    I’m not sure if you made a decision buy here is $200 off the 211 and some other current rebates.
    https://www.millerwelds.com/build-with-blue-rebate
    shakerhood and tacotunner06 like this.
