recommendation for front pads and rotors ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DDay, Mar 17, 2024.
  1. Mar 17, 2024 at 1:43 AM
    DDay
    DDay [OP] Member
    Dirk
    Tigard Oregon
    2014 Tacoma 4x4x4
    new, none yet, going to lift it, and get wheels and tires, small dent in tailgate
    2014 Tacoma 4x4x4 6 cyl (50,100 mi)
    Amazon ? ($125-210) Autozone ($230) Partsgeek ($210) for same names
    Ceramic ? brands to avoid or be recommended.... I havent done a brake job in 25 years, back when you turned the rotors and now replace, apparently? I got in a terrible accident and cannot do the majority of my own work anymore, although my son (37) will help with this, sparing me labor charges. Jeez, any advice appreciated. My last brake jobs? A '68 Camaro and '88 Supra. Been a bit.
  2. Mar 17, 2024 at 2:32 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Factory OEM is the best,you can them for a good price from a Toyota dealership on ebay.
    Jakerou, DDay[OP] and Micbt25 like this.
  3. Mar 17, 2024 at 2:36 AM
    TacoTuesday1
    SD CA
    Two threads on this
    TRD ceramic pads
    Stoptech cryo slotted rotors
    Or similar
    or that in bigger size with 4runner BBK
    Tundra master cyl
    avoid Autozone
    My stock rotors warped twice
    Still running above 1st setup. Never warped. On second set of TRD pads.
    Just started bed in procedure after break in. Without a trailer and on the street, still able to slide tires on 35’s.
    rather have tundra master cyl and 4runner BBK but that’s a lot of work. Buying rotors, again, when my current Stoptechs are still fine.
    DDay[OP] likes this.
  4. Mar 17, 2024 at 2:50 AM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    If the rotors are good and not warped, I’d keep the originals. I used and recommend using Toyota parts, this is for the front pads:
    Pads kit: 04465-04070 x1
    Disc Brake Anti-Rattle Clip Set: 04947-0C010 x 1
    Clip Pin Hold: 47743-04093 x 2
    Disc Brake Pad Shim: 04945-0C030 x 1
    Disc Brake Caliper Pin: 90240-06158 X 4
    I didn’t replace the rear shoes, but would recommend original Toyota parts. Make sure you grease the caliper pins so you have even wear on your pads, you can use the following grease:
    Super Lube-21030 Synthetic Multi-Purpose Grease, 3 Oz. https://www.amazon.com/dp/B000XBH9HI
    It’s a very simple job and not difficult to do yourself and it sounds like you’ll have your son there to help, which you guys shouldn’t have a problem.
    I recommend using Toyota parts and once on there I would select
    Conicelli parts in PA as they have great prices and I’ve been ordering from them for years.
    https://autoparts.toyota.com/?partn...da4w9QNpPNGXhMCqfXMaAiqHEALw_wcB&gclsrc=aw.ds
  5. Mar 17, 2024 at 3:21 AM
    cmoore
    cmoore Well-Known Member
    Charlie
    Dallas, Texas
    PreRunner
    Be very wary of any auto parts on Amazon and Ebay. There are Lot's of cheap chinese fake parts on those sites. I recently purchased some Denso plugs on ebay that turned out to be fake. Ended up going to the dealer to make sure I was putting the real deal in my truck.
  6. Mar 17, 2024 at 3:33 AM
    Micbt25
    TM
    I agree, I originally bought a 6 pack of WS transmission fluid off of Amazon, it was probably ok. However, I thought about how much a new transmission cost and I repurchased the fluid from a Toyota dealer.
    CrazyCrewChief and DDay[OP] like this.
  7. Mar 17, 2024 at 9:28 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Advics are the OEM pads, if you want to save a few bucks.
    I went with a package deal from PowerStop myself.
    Musubi3 and DDay[OP] like this.
  8. Mar 17, 2024 at 10:10 AM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
  9. Mar 17, 2024 at 10:42 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Online dealer direct you can get all the oe parts for about $200 bucks, pads, rotors, shims etc.
    Williston and DDay[QUOTED][OP] like this.
  10. Mar 17, 2024 at 11:02 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    At the recommendation of a auto tech at a popular performance/repair shop I went with Brembo Rotors, he suggested looking for ones specifically made in Europe and staying away from anything Chinese based on some of the materials they use. The Brembos weren't cost prohibitive and I've got about 40K on them with no issues, pulsing or detectable warpage. Both my MCs have Brembo's so I have a history with them and they've been great in that application. All that being said the chinese are capable of making good stuff as long as they also use good materials and that's sometimes the problem, esp with some of the China autoparts you find in the chain auto parts stores. If you've bought rotors from Autozone or O'Riley's in the past 10 years you've probably see how cheap chinese rotors perform.
    Stoptech is very popular on here so they're obviously decent also. I doubt you'd go wrong with OEM rotors if they've retained OE quality.
  11. Mar 17, 2024 at 1:19 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Why do you think you need to replace rotors at 50,000 miles? You should get a lot more mileage out of them. Getting them turned is still a thing. If you have a set of measuring calipers you can see how worn they are or aren't.
    I changed my rotors at about 140,000. Not because I had to, I went with TRD pads and slotted cryo rotors as I wanted better stopping power.
    JMcFly and DDay[OP] like this.
  12. Mar 17, 2024 at 3:44 PM
    Micbt25
    TM
    I agree, changing the rotors should be unnecessary.
  13. Mar 17, 2024 at 4:25 PM
    TacoTuesday1
    SD CA
    Rotors can be turned. FSM should list specs. Sometimes rotors list the spec on the part. You can measure thickness with digital caliper.
  14. Mar 17, 2024 at 5:36 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Resurfacing rotors is a disappearing service in my area. The only place that does it near my area is OReillys, and I have to call around because the nearest ones don't always have the Toyota adapter. I believe they charged me $35/rotor about a year ago. If you don't have a micrometer, you can take the rotors to them to resurface, they will measure them before accepting them to ensure they have sufficient material to resurface. They accepted my slotted & dimpled EBC rotors and did a good job.
    Williston and DDay[OP] like this.
  15. Mar 17, 2024 at 5:49 PM
    TnShooter
    Deogee
    STOCK
    If you are doing the brakes for yourself, you can measure and skip the rotors if they are with in spec.
    If they squeal when you’re done, it’s your fault. You can live with it.
    If you are doing them for someone else, ALWAYS have them turned or get NEW rotors.
    If they squeal, pulsate, or feel “funny”, you’ll know about it. And you’ll get to do them again.
    With the way parts are now, you’ll be lucky if the new pads “fit” the old rotor if you don’t turn them.
    I say, spend the money and get rotors.
    DDay[OP] and Williston like this.
  16. Mar 17, 2024 at 5:50 PM
    DDay
    DDay [OP] Member
    Dirk
    Tigard Oregon
    2014 Tacoma 4x4x4
    Thank you to everyone for the recommendations, and good information.
    Williston and TnShooter like this.
  17. Mar 17, 2024 at 6:09 PM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [TO] V6 Tow Package [ED] Entune Audio Plus
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    Purchase new OEM rotors and pads from a dealer. You can find the rotors online for about $60 each and the pads for around $45. Free shipping or pick-up at dealer for many of them. Resurfacing thins them out, they are more prone to warping afterwards, and you'll be doing them again. Prices vary on the dealer sites, so shop around
    ridefreak and DDay[OP] like this.
  18. Mar 17, 2024 at 6:22 PM
    Williston
    Welcome to TacomaWorld! :thumbsup:
    DDay[QUOTED][OP] likes this.
  19. Mar 17, 2024 at 6:22 PM
    DDay
    DDay [OP] Member
    Dirk
    Tigard Oregon
    2014 Tacoma 4x4x4
    i got some great direction from everyone, again really appreciate it. It is a great Tacoma world! Tnshooter-funny and true.
    Tacoma notes -Moving to Oregon 10 years ago form SoCal I had rare opportunity to buy a new vehicle outright. Telling my high school girlfriend and wife of 30 years I would get an all wheel drive vehicle of her choosing. She announced we would be purchasing a 4 door 4 wheel drive truck and that the Tacoma seemed right. Gotta love her. Beautiful and smart. Full disclosure we had a 1981 SR22 Toyo truck with 270k miles on it. She would often leave her Volvo and my Supra to drive it to work "because sometimes I like shifting", and "I can drive through the field to hit the main road when traffic gets busy" I sold that 82 truck to a friend and regret it still.
    Williston and Micbt25 like this.
  20. Mar 17, 2024 at 7:19 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I have about 115,000 miles on my stock pads and am only considering replacing them in the next month or two.
