Recommendation for replacing leaking headlight assembly, 2nd Generation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dakbigdog, Sep 25, 2022.
  1. Sep 25, 2022 at 2:12 PM
    Dakbigdog
    Dakbigdog [OP] New Member
    Joe
    08 Tacoma SR5
    Hello, I just bought an '08 PreRunner SR5 that is in pretty good shape. But was disappointed to recently discover water (a lot!) in the passenger side headlight assembly.
    Any recommendations on good quality aftermarket headlight assemblies? Dark-colored assemblies would be good too if anyone has a recommendation.
    Thanks!
  2. Sep 25, 2022 at 2:49 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Use the Search function or even go to the Lighting sub-forum. The answer you will quickly find is that for headlight assemblies that actually put usable light on the road in front of you, look decent and last the longest, OEM is the only way to fly. If you want something cheap that looks "better" (that's a personal decision), oxidizes quicker and leaks water faster, aftermarket is the only way to fly. The answers to all of your questions are here:
    The ultimate headlight upgrade H4 (not LED or HID) | Tacoma World
    Key-Rei, Pnwadventure and BKinzey like this.
  3. Sep 25, 2022 at 3:26 PM
    daluvian
    daluvian Well-Known Member
    San Diego
    2005 Tacoma
    Long travel
    Aftermarket ones need to be sealed with silicone before installed. Maybe u can silicone your current one I’m sure there is posts showing how to do it
  4. Sep 25, 2022 at 4:51 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Check am-autoparts, good prices & 10yr warranty.
  5. Sep 25, 2022 at 6:33 PM
    SJC3081
    SJC3081 Well-Known Member
    Wappinger NY
    2011 DCLB 4x4
    $35 from Rockauto. I have them for three years and 50,000 mile still look brand new.
    Edit now they are $40 range.
  6. Sep 25, 2022 at 11:57 PM
    TacoTuesday1
    SD CA
    got aftermarket DEPO smoked housing maybe a year ago. Left front just started letting in condensation. I guess that means I need to take it out, wash the outside + let dry, then apply a bead of silicone around it, which I have extra leftover from home. If not, home depot has it.
    At least bathroom/sink clear waterproof silicone to apply with a caulk gun.
    Not sure if anything else should be used instead, such as butyl type, which is usually what the lens itself adheres to the housing with
    Was thinking of trying to throw a dessicant pack inside the housing (silica gel) to dry it but IDK if there's even room...
  7. Sep 26, 2022 at 5:27 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Use an air compressor to blow dry it out.
    Key-Rei likes this.
