Recommendation minimum floor Jack rating /compact Jack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Newtacoma19, Nov 17, 2024.
  1. Nov 17, 2024 at 6:15 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    +1.
    speaking as someone that once spent parts of a family vacation changing 9 flats, and i see no reason to go beyond the oem jack. definitely curious as to the reasoning for that.
  2. Nov 17, 2024 at 6:24 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Ah these comments are funny. Try lifting a 75 lb 3 ton jack into the back of your Tacoma. Let me know how that goes.
    A 2 ton aluminum jack is perfect for lifting 1 (ONE) corner of your Tacoma. For instance replacing 1 tire or fixing a cv axle on that corner.
    Save the 3 ton+ jacks for the house. Bring 1 jack stand with you. I also recommend a jack stand with a locking pin as someone suggested. I also do recommend bringing a 6 ton jack stand. Daytona or Big Red. The 3 ton are too short.
  3. Nov 17, 2024 at 6:24 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    People make combination jack/jackstand. A central cylinder jack that you lock when at height like a jackstand.
    I cannot comment on their effectiveness but people mention they exist.
  4. Nov 18, 2024 at 5:57 AM
    545
    545 Well-Known Member
    2015 Access Cab
    I have one of those, works fine
    Less weight and size than a floor jack or high lift, and can be used on stuff a high lift would damage (also less chance of loosing teeth)
    https://www.amazon.com/Powerbuilt-620471-6000Lb-Unijack/dp/B00GJJZ5NI/
    Op, whatever you get, do not put any of these large heavy objects in the cab with you without securing them very well
  5. Nov 18, 2024 at 6:47 AM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    I do the same, even when working on brakes. Always put a tire under the car.
    Oil and coolant changes are done on the ramps rates at 6,500# per pair/3,250# each. And chokes at the rear wheels.
  6. Nov 18, 2024 at 7:02 AM
    guaco.supreme
    guaco.supreme Fk around and find out
    MN
    Something that I didn't see mentioned;
    Pay attention to the maximum lift height, especially the cheaper jacks or low profile ones. A lot of those jacks won't get a Tacoma high enough to get the tires off the ground when lifting from the frame, especially if you are lifted. And when checking those measurements remember it's not just frame to ground, add suspension droop as well.
  7. Nov 18, 2024 at 9:29 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    I have an old craftsman that fits in the sunken space behind the drivers seat. It lifts enough to change a tire.
    Newtacoma19[OP] likes this.
  8. Nov 18, 2024 at 10:08 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    Sears used to sell a small floor jack that came in a blow molded plastic case. I bought one years and years ago and I throw it in the bed when I'm taking a road trip, especially if I'm towing a trailer.
  9. Nov 18, 2024 at 10:36 AM
    Greg-tacoma
    Greg
    2016 Black 4cyl 4wd
    Exactly the one I have in my truck.
  10. Nov 18, 2024 at 7:13 PM
    I-Give-Up
    I-Give-Up Well-Known Member
    West Phoenix, AZ
    2023 Ice Cap Tacoma TRD
    Meso spare fuse holder. Aluminum gas cap holder. Genuine Toyota bed lights. Bed molle racks. Ammo case storage under hood. In-bed spare tire. Automatic underhood lights. Gooey glurp on frame.
    Yes. This. I only carry my HF lightweight 2 ton floor jack when I'm going into bad places. Under the rear seat, I always have the OEM jack, plus a HF 3 ton hydraulic jack, just in case.
    Newtacoma19[OP] and Barsoom like this.
  11. Nov 18, 2024 at 7:40 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Floor jacks work splendidly on a floor. Anywhere else you want the bottle jack that Toyota gave you.
    I’ve used the stock bottle jack to get off a hill of mud I was high centered on and when changing wheels in a rough parking lot where the truck kept slipping off my (cheap) floor jack because it wouldn’t roll properly. The stock bottle jack works, is lightweight, and fits nicely under the back seat.
    Floor jacks have be able to roll, because the lifting surface rises in an arc, not straight up like a bottle jack. Depending on the type of wheels and the surface they might not roll well. I’ve been there.
    Floor jacks are awesome for the garage.
    Coopsdaddy, fmb, BC Hunter and 5 others like this.
  12. Nov 18, 2024 at 8:47 PM
    MagicToolbox
    MagicToolbox Well-Known Member
    2022DCSB MT TRD OffRoad in Lunar Rock
    Purchased Toyota Certified, with Vijay bumpers, additional lights, and Falken Wildpeaks on Fuel rims. Prev owner apparently painted the grill.
    I had a suspension squeek that I wanted to get some fluid film on. I jacked the truck up with my 3 ton Daytona floor jack and discovered that I couldn't use my 3 ton stands to hold the frame up high enough to sag the springs.
    I bought a pair of 6 ton stands and had no troubles.
    Speaking of which, my suspension squeek is still silent, so I'm happy with that as well.
    Pray4Mojo and Newtacoma19[OP] like this.
  13. Nov 18, 2024 at 9:11 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    do you work at harborfreight ? can you get me a family member discount bro?
  14. Nov 18, 2024 at 9:17 PM
    RIX TUX
    just wondering if the low pro model is too low for a 4x4 truck?
    Squirt[QUOTED] likes this.
  15. Nov 18, 2024 at 9:17 PM
    #35
    MGMDesertTaco
  16. Nov 18, 2024 at 9:18 PM
    #36
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    I carry sometimes an Arcan 3 Ton Aluminum floor jack in the bed when I am on the road or in remote areas. But it is heavy and I don't really like lifting it in and out. I may just try the bottle jack on a sunny Sunday so I am familiar with it should I ever need it. I do have an extra Hercules long anvil impact so maybe this should live back there too.
    I saw someone mention a smaller more compact version of the Badlands jack is in the works. This was at SEMA. Perhaps this would be a good one to carry regularly.
  17. Nov 18, 2024 at 9:51 PM
    #37
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    My truck lifted 1.8" and the low profile is able to lift the front tires off the floor with 1-1.5" available. Make sure to get one that is close to 20" of lift hight
  18. Nov 19, 2024 at 3:08 AM
    #38
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Since no one has mentioned it. Look into Safe Jack, compact bottle jack with a bunch of lifting attachments. The duffle will fit in relatively small spots and the attachments can grow with your lift. It's not cheap though.
    If you're not lifted and don't plan on it, the factory bottle jack will get the job done. Safe Jack also has a ton of attachments that could possibly work with any bottle jack.
    bottle-jack-accessories
  19. Nov 19, 2024 at 3:24 AM
    #39
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    Mine handled the f150 quite well lifting it from the pumpkin
    RIX TUX[QUOTED] likes this.
  20. Nov 19, 2024 at 4:15 AM
    #40
    InThePlains
    InThePlains Well-Known Member
