Recommendation on loose toilet repair
Discussion in 'Off-Topic Discussion' started by TnShooter, Aug 30, 2022.
  1. Aug 30, 2022 at 2:46 PM
    TnShooter
    TnShooter [OP] The TacomaWorld Stray
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    In the process of purchasing a home. The home inspection stated the toilets where loose at the floor. So I had the inspector show me the problem.
    One of the toilets is loose. But it takes a good bit of twisting to get it to move. It might move 1/32” left to right. And you really have to grab the bowl and twist it. It DOES NOT rock.
    The inspection stated to remove toilet, replace seal, and secure toilet to floor.
    My question is, can I just tight the bolts up and calm it good?
    The toilet doesn’t leak. And to get the toilet to move, you really have to twist it by hugging the bowl and turning fairly hard.
    wilcam47 likes this.
  2. Aug 30, 2022 at 2:51 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Id do as instructed. You want to make sure the mounting platenin the floor is ok, either way, an easy enough thing to fix. But if it came up in the home inspection, and thats the worst thing, make the seller have it repaired.
    It WILL leak, just a matter of time. How do i know? Same thing happened to my spare bathroom, toilet had a little wiggle, that was enough to make it leak.
    Also, dont think that just because you had a home inspection the inspector didnt miss anything. Mine was a pos.
  3. Aug 30, 2022 at 2:54 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    it is an easy fix but still has to be done right. Typically the bolts rust and need new bolts and wax seal. Id just have the owners fix it.
    It will leak eventually. Not a major issue though unless the flange is broken
    boston23 likes this.
  4. Aug 30, 2022 at 3:05 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    I agree with all other posts also don’t crank them down super hard they can crack toilet
    Depending on how old the house is could be rusted/frozen
  5. Aug 30, 2022 at 3:08 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Remove the toilet, Clean all the old wax off the bowl and toilet flange. you might need to put some screws throught the flange into the floor so it stops the turning of the flange Just be careful not to crack the tank or bowl in the process.
    All you need is a wax ring with the horn and a new set of Jonni bolts. and reinstall. Use a large sponge or toilet sucker to get the remaining water out of the tank or it makes a mess everywhere.
    wilcam47 and Brianz1001 like this.
  6. Aug 30, 2022 at 3:10 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I'm the last person to be giving plumbing advice. I can do electrical and mechanical all day, but plumbing seems to be a challenge for me. That said, I've replaced wax rings and toilet guts without an issue, it's not a big deal. But, I'd try to have the owners do it anyway. If they won't, probably not the end of the world.
  7. Aug 30, 2022 at 3:13 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I’d just tighten the bolts. If they are still loose after, replace the wax. I’m sure YouTube has how-to vids but it’s easy. Just try to avoid sloshing water everywhere.
  8. Aug 30, 2022 at 4:10 PM
    TnShooter
    Deogee
    STOCK
    If I were a betting man, I’d say tightening the bolts will stop it from moving.
    I mean, it’s only loose if you physically grab the bowl and twist it. And it ain’t easy to get it to move.
    Truth be told, I doubt any normal person would ever know it was loose. Because I have no idea why anyone would try and twist the toilet. Let alone with enough force to make it move.
    I just hope this yahoo inspector isn’t the one that made it “loose”. Because I couldn’t make it move, not until he told me to bear hug the toilet and twist it.
    Who TF does this:confused:
    Bivouac and wilcam47 like this.
  9. Aug 30, 2022 at 4:20 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    1/32"?
    That inspector was bored and need to put something on paper...I could fart on my toilet and move it .031"
    Rock Lobster, usmc2msu and wilcam47 like this.
  10. Aug 30, 2022 at 4:24 PM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    Tightening it will either stop it from moving or crack the porcelain, if it was installed correctly it wouldn’t move.
    tacofish and Mark77 like this.
  11. Aug 30, 2022 at 5:01 PM
    TnShooter
    Deogee
    STOCK
    It’s been installed since 2007.
    That’s when the house was built.
    It was a one owner. The man and woman that owned it were in their 90s. He died and she is now in assisted living.
    As for being installed right?
    I can’t say. All I can say is, that to me that toilet would have been tight. As I would never have considered checking in the manner he did.
    For reference, I just checked the toilet in my apartment. And good thing I did, as I can literally lift/rock it up and down off the floor. How it isn’t leaking is beyond me. But I’m definitely letting maintenance know about it.
    I can honestly say, I have never checked a toilet. Not unless it was loose when I went to sit on it. And then, those normal rock back and forth. So it’s obvious. :rofl:
  12. Aug 31, 2022 at 5:36 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Now I gotta go check all the toilets and hope nobody sees me so I don't have to explain why I am toilet-hugging.
    TnShooter[OP] likes this.
  13. Aug 31, 2022 at 5:52 AM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Raised or "T" Foundation...or concrete? If the former, could be rot in the subfloor panel allowing movement. Experienced it many a time and generally leads to a bath renovation.
  14. Aug 31, 2022 at 6:07 AM
    John43
    John43 Well-Known Member
    Dallas
    07 PreRunner
    They make shims to level them.
  15. Aug 31, 2022 at 9:58 AM
    TnShooter
    Deogee
    STOCK
    Tile over concrete slab.
  16. Aug 31, 2022 at 10:00 AM
    TnShooter
    Deogee
    STOCK
    It doesn’t rock. It turns like you left and right. And again, you really have to shove it hard to get it to move.
    I think the inspector had nothing else to find other than 1 shrub touching the house. Other than that it was all good.
  17. Aug 31, 2022 at 10:07 AM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    Could be corroded fasteners into the concrete. Probably just loose bolts.
    Personally, I would replace the 15 year old toilet anyways so I wouldn’t sweat it.
    TnShooter[QUOTED][OP] likes this.
  18. Aug 31, 2022 at 10:24 AM
    TnShooter
    Deogee
    STOCK
    I would probably keep the toilet.
    Only because it is NOT a low flow. I hate these new low flow toilets. You have to flush before you wipe. And then after you wipe. :rofl:
    b_r_o and tacofish like this.
  19. Aug 31, 2022 at 11:26 AM
    rleete
    rleete Grumpy old man - get off my lawn
    Roger
    Rochester, NY
    Base DC, SR5, TRD Sport
    Billet grill
    My recently installed toilet is a low flow, and it works just fine. You need to buy name brand with these things.
    OP, if you can't reset a toilet, home ownership is going to be hard and expensive. Watch a couple of youtube vids, and do it yourself.
  20. Aug 31, 2022 at 2:18 PM
    TnShooter
    Deogee
    STOCK
    I understand that bud.
    And I applied the advice.
    I’ve set 1 toilet in my entire life.
    And that was about 20 years ago.
    I was in high school and had to do it myself.
    I remember having a hell of a time getting the bolts to line up with the toilet.
    Things haven’t changed any.
    I’m still all by myself. Maybe I can talk a buddy into giving me a hand with the toilet. Mostly getting the bolts started as I sit the toilet down.
    My question was more about trying to tighten the bolts vs pulling the toilet.
