Recommendation on new shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nirav2011, Nov 9, 2020.
  1. Nov 9, 2020 at 4:30 PM
    nirav2011
    nirav2011 [OP] Well-Known Member
    2011 Tacoma TRD Sport
    Hi all,
    I have a 2011 DC TRD Sport with about 45k miles which is pretty much in stock condition. While it doesn’t have a lot of miles it has been in service for over 9 years and I’ve noticed the suspension isn’t as good as it should be...gets a little too bouncy over relatively small obstacles.
    I am starting to think about replacing the shock absorbers on all four corners and am wondering if you all would recommendation one brand over another? Are OEMs the way to go? I saw a post recently by someone who replaced with 3rd gen parts.
    I’ll probably try to do the work myself.
    Thanks in advance for the guidance.
    N
  2. Nov 9, 2020 at 4:33 PM
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
    Check out your sway bar links. Those thing snap sometimes.
  3. Nov 9, 2020 at 4:35 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    You could probably pick up some 3rd gen Sport shocks for cheap off of someone here, they will work fine.
  4. Nov 10, 2020 at 1:40 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Tacoma13_NC likes this.
  5. Nov 10, 2020 at 2:36 AM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT); Yaesu FTM-150 GMRS/Ham radio; Viofo A229+ Dash Cam
  6. Mar 5, 2021 at 6:30 PM
    nirav2011
    Finally getting around to the shocks. I don’t want any lift but I do want a more stable ride. From my reading I understand the bilstein 5100s can be set such that there is no/minimal lift. I’m torn betweeN OEM and the 5100s.
    Also, any recommendations on where to get this done in Delaware/south eastern PA?
  7. Mar 5, 2021 at 6:38 PM
    badger
    badger Well-Known Member
    07 SR5
    I wouldn't waste my money on OEM shocks. Bilstein is a far better option.
  8. Mar 5, 2021 at 6:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    Me too.
    While they may not be the best for the aftermarket lovers, you'll get the same result as you did with the originals. Another 45k and 9 years. And they'll be budget friendly (as in cheap)
    DavesTaco68[QUOTED] likes this.
  9. Mar 5, 2021 at 6:46 PM
    Bishop84
    Bishop84 Well-Known Member
    4600's are similar to 5100's slightly cheaper if you want to retain stock height.
    Those old TRD sport shocks are tired and you'll be surprised at the ride quality with a fresh set of shocks from any make.
    nirav2011[OP] likes this.
  10. Mar 5, 2021 at 6:50 PM
    Spizike231
    Spizike231 Pickin’ & Grinnin’
    Jesse
    Sacramento, CA
    2011 MGM DCSB TRD Sport 4x4
    FWIW the stock shocks on his truck are Bilstein. Just not 5100’s.
    henryp likes this.
  11. Mar 5, 2021 at 7:09 PM
    badger
    07 SR5
    I know, but they are junk IMO
  12. Mar 5, 2021 at 8:55 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    What load rating tires are you running? Have you checked your psi lately?
