Recommendations for a 4" lift on a 2013 Stock Taco TRD Sport.
Discussion in 'New Members' started by ThatE0Dguy, Dec 25, 2014.
  1. Dec 25, 2014 at 9:11 PM
    ThatE0Dguy
    ThatE0Dguy [OP] Member
    Honolulu, HI
    2013 4dr. Short Bed TRD Sport
    So I'm trying to figure out what kind of lift I want for my '13 taco. I'm totally brand new to all this mod-ing and such and just wanted some more expert and experienced advice from fellow Taco owners. The thing is is that I live in Hawaii so I don't go off roading at all. I'm mostly looking at a lift for looks. And I've done a meager amount of reaserch into them and it seems that having a 6" susp lift like I originally wanted will require me to cut into the frame and void my warranty which I don't want to do. I've also heard terrible reviews about body lifts and block lifts (I'm guessing they're the same thing), so naturally I'm trying to steer away from those. I've also been told that to do a lift will require more outside work than just the lift itself, requiring like re-gearing, and sometime new axles and so on and so forth. So really what I'm asking is, if I were to go for a lift, what one(s) would you recommend and what all would be required for installing them from start to finish. Any and all advice is appreciated. Mahalo.
  2. Dec 25, 2014 at 9:30 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Welcome to TW. This link is a good starting point for understanding what kinds of lifts are out there and which is recommended:
    http://www.tacomahq.com/66/tacoma-leveling-lift-kit/
    As far as recommending lifts go, what is your budget? 3" seems to be the route you are looking to go, correct?
  3. Dec 25, 2014 at 9:37 PM
    ThatE0Dguy
    Honolulu, HI
    I can have a pretty big budget if I wanted too. Thanks for the link I'll be sure to check it out and try to understand it all.
  4. Dec 25, 2014 at 9:45 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    4x4 or prerunner?
  5. Dec 25, 2014 at 9:54 PM
    ThatE0Dguy
    Honolulu, HI
    Yeah it's just the 4x4, no prerunner.
  6. Dec 25, 2014 at 10:00 PM
    Casey05Taco
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    this will be your choice then with a 4x4
  7. Dec 25, 2014 at 10:29 PM
    ThatE0Dguy
    Honolulu, HI
    That's what I've heard for the body lifts, is to not get them. I'm still trying to obtain a good 4" lift though if possible with out the body lift
  8. Dec 25, 2014 at 10:31 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Why is 4" of lift a requirement?
  9. Dec 25, 2014 at 10:38 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    You can't get 4" of lift out of the suspension on a Tacoma. If you try you'll end up with a CV angle that'll end up wrecking the CV's fairly quickly. So without a body lift or drop bracket lift there isn't any way to get a 4" lift that will be reliable (the body lift is a terrible idea and the DB lift involves cutting some of the front of the frame cross member as already mentioned).
    If money is not a problem why not go for the 3" lift with a Toytec or OME kit and see if you like it? With either you can get 3" of lift with just the suspension and a good ride. If you don't like the look you can sell that kit and get a 6" Pro Comp drop bracket lift that will look the way you want it but require some frame cutting. It's really not a big deal to do a drop bracket kit with a good installer but it is harder to reverse a drop bracket lift if you don't like it.
  10. Dec 25, 2014 at 10:39 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Anything over 3" of only suspension lift is probably going to cost you 1K at the very least if you're a 4x4. Got to cut that crossmember.
  11. Dec 25, 2014 at 10:46 PM
    ThatE0Dguy
    Honolulu, HI
    A 4" lift was a requirement because I didn't know until after reading these posts that only a 4" would mess up the CV joints, and that a standard Tacoma suspension was not possible to accommodate a 4". After reading this I realize I might have to settle for a 3" or upgrade to a 6" with shop installation and warranty void.
  12. Dec 25, 2014 at 10:49 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I hate to break it to you but any lift could potentially void some of your warranty. IF the dealership can reasonably prove that whatever damage you are trying to have warrantied was caused by your lift kit than they can refuse the warranty work. If they can't prove it you can take them to court. Keep in mind going to court can take time and, in general, is no where near as good an option as people make it out to be.
    In theory, a Pro Comp lift kit with drop brackets will actually do less to take your CV's out of there proper angles than a suspension lift will... and a lot of dealerships will install either lift but at a much higher cost than an independent shop.
  13. Dec 25, 2014 at 10:59 PM
    ThatE0Dguy
    Honolulu, HI
    Ok, so if I were to do a drop lift on the standard 4x4 TRD sport, I've heard there would be some re-gearing I would need to do, and possibly get stronger axles, with a better Dana(?) rating?
  14. Dec 25, 2014 at 11:11 PM
    ThatE0Dguy
    Honolulu, HI
    Much larger tires? What are we talking? I'd like bigger tires but the size would depend on if I'd need a regear and its cost. Thanks to everyone who have offered their advice thus far.
  15. Dec 26, 2014 at 4:06 AM
    geekhouse23
    All the research I have done when moving to a bigger tire is you can go up to 33's before you would have to regear. I guess it is personal preference though.
