Recommendations for alignment on lowered car
Discussion in 'Hawaii' started by 808veedub, Oct 3, 2019.
  1. Oct 3, 2019 at 12:51 AM
    808veedub
    808veedub [OP] Well-Known Member
    Brent
    Hawaii
    2016 4x4 tundra crewmax 2016 trd sport tacoma
    Looking to get an alignment on my wrx. I know some places specialize in doing lowered vehicles. Lmk if any of you have any experience with some hop here.
  2. Oct 3, 2019 at 1:01 AM
    Sasquatchian
    Sasquatchian Well-Known Member
    Kind of a weird place to ask about your WRX, but the same principles apply pretty much no matter. First, you need to define what you're going to do with the car and what your goals are. If you've lowered a WRX, probably means you're interested in handling, but how far you want to go with it depends on what's important to you. If you're going to autocross it, you'll want a lot of negative camber front and rear and maybe even a tick of toe out in front. If you're just driving on curvy roads, then you might want to be a bit more conservative, but really, a WRX forum will likely be your best bet, and then find a great alignment shop that knows what they're doing - easier said than done but still doable. And then be prepared to have an alignment done, drive it for a while and then decide how you want to change it the next time. It's taken half a dozen alignments on my '88 911 to get it where I like it for how I like to drive it. The last one was after upgrading to high performance camber plates and racing ball joints, all for more negative camber in front. There are some great suspension books on Amazon as well, and I wish I had a link to the one I have. You can probably figure out a good one by the reviews.
  3. Oct 3, 2019 at 1:11 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Try island brake and alignment or auto customs. They both handle a lot of lifted and lowered vehicles
    pinktaco808 likes this.
  4. Oct 3, 2019 at 2:19 AM
    808veedub
    Brent
    Hawaii
    Thanks! Will check them out
    El Duderino[QUOTED] likes this.
  5. Oct 3, 2019 at 2:20 AM
    808veedub
    Brent
    Hawaii
    Nope. Just trying to get it within spec for recon.
  6. Oct 3, 2019 at 10:13 AM
    Sasquatchian
    Then any decent alignment shop should be able to do that. But do remember that being "in spec" doesn't mean much as there is always a range to whatever the "spec" is. You want a shop that will know which end of the range is best for you and why just being "in spec" is not good enough, even if that's your stated goal.
  7. Oct 3, 2019 at 11:03 AM
    El Duderino
    Jeremy
    HI->PNW
    Hawaii is a bit different. Some shops won’t touch a modified suspension for an alignment in this island cause of the vehicle reconstruction permitting here.
  8. Oct 4, 2019 at 1:07 AM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    Check out Scotty’s. He’s been doing all my lifted and lowered vehicles since the 90s.
    808veedub[OP] likes this.
  9. Oct 4, 2019 at 1:55 AM
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    Toytec Ultimate lift Coilovers Toytec AAL No diff Drop 5% Tint all around Morimoto 2Stroke LEDS High and Low Morimoto Fog Lights MESO Key FOBs
    Must explain why you posted this thread in the "HAWAII" reigonal discussion? :rolleyes:
  10. Oct 4, 2019 at 2:13 AM
    El Duderino
    Jeremy
    HI->PNW
    Some people don’t know our crazy asinine laws
    inksin likes this.
  11. Oct 4, 2019 at 2:23 AM
    El Duderino
    Jeremy
    HI->PNW
    I forgot to add that Goodyear in Kaneohe has done my alignment back to specs on modified vehicles for recon
