Recommendations for at-home alignment tool
Discussion in 'Suspension' started by jamestcurran, Sep 3, 2025 at 3:27 PM.
  1. Sep 3, 2025 at 3:27 PM
    jamestcurran
    jamestcurran [OP] Well-Known Member
    Looking for advice on what folks are using for home alignment these days.
    I've hear good things about the camber/caster/toe plates, but also those magnetic camber/caster gauges seem to get good reviews. I see there are also some crazy expensive iPhone apps with a 3D printed attachment.
    Or I could bring it to the shop every time I meddle with the shocks.
    What do people recommend?
    Plates:
    https://www.vevor.com/toe-plate-c_10328/vevor-wheel-alignment-tool-camber-caster-toe-gauge-toe-plates-measuring-tapes-p_010857275524?adp=gmc&utm_id=22902081074&ad_group=183991288237&ad_id=769655194954&gad_source=1&gad_campaignid=22902081074&gbraid=0AAAAACq8bLUNkyvKX2AfY4gVJBcTOT31N&gclid=Cj0KCQjwzt_FBhCEARIsAJGFWVmRxj-rBg_u8aCaBivS2oqd6Vqbu2UT9QtXuKfxovyMpWylVmdJ5PAaAjicEALw_wcB
    Gauges:
    https://www.summitracing.com/parts/...ITK3-KUypi3vVsCm2uU871yghlxhkarsaAkJSEALw_wcB
    App:
    https://gyraline.com/products/the-c...DfQP4R5f5CXr51niHRwu16rt6OGfu8UQaAmldEALw_wcB
  2. Sep 3, 2025 at 3:52 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You don't really need an alignment every time you do something with the shocks unless you're changing the ride height a large amount. Small changes in ride height won't make a huge difference
    Ive had my coilovers out several times for small stuff like changing the lower height joints and I haven't had any noticeable changes in alignment. Also my LCA cam bolts are frozen in place anyway haha
  3. Sep 3, 2025 at 4:00 PM
    jamestcurran
    Thanks @b_r_o!
    My wheels were rubbing on full lock and over bumps (285/70R17) so I've temporarily put in some 2" spacers up front and a 1.5" lift block at the back.
    So, yeah, worried I might eat through my tires in the time being, and probably going to adjust the height again in a moth or so when I get some new shocks.
    I'm thinking to go for some adjustable coil-overs and maybe an AAL or replacement leaf spring, likely 5100s and a Torch 2" AAL.
    Looking at the price of alignment around here (NorCal) I it would pay for half my parts list, so I'm keen to DIY it.
    Also curious if I can actually do it right....
  4. Sep 3, 2025 at 4:33 PM
    scocar
    scocar Patron of the Farts
  5. Sep 3, 2025 at 4:42 PM
    jamestcurran
    jberry813 likes this.
  6. Sep 4, 2025 at 6:09 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Suspension lift isnt how to solve rubbing. Get out a grinder and a hammer and start cuttin
