Recommendations for Best All Season Tire replacement for 2019 Tacoma SR5
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cmar, Nov 19, 2019.
  1. Nov 19, 2019 at 11:37 AM
    BBPSR54X4
    BBPSR54X4 Well-Known Member
    2017 SR5 DCSB 4x4
    The wider tires (265/70/R16) give the wheels a more substantial look without changing the 'size' of the tire. If you look at the OR tires vs the SR/SR5 tires you will see what I mean.
    The 265/70/16s have the exact same circumference as the 245/75/16s, so your speedo etc. works correctly. They just look bigger (and better IMO).
    2002Tacoma4x4 likes this.
  2. Nov 19, 2019 at 2:20 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    I've had Michelin LTX tires in the past and they're great tires, but Kumho Crugen HT51's are basically the same tire at a much lower price point (~$110/ea). We've have a set on our SUV for a couple years now and they've been great so far.
    EDIT- Kumho Crugen HT51 also have the three-peak mountain snowflake (3PMSF) symbol
  3. Nov 19, 2019 at 2:30 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Michelin Defender LTX M/S is the best of the best for what you’re asking for.
    Stick to stock size or +1 (3%) at largest.
    Have had the Michelin’s and their predecessors on every manor of vehicle and they’re great, but I will say not the best if you spend a considerable time in ice/snow.
    MoneyMan55 likes this.
  4. Nov 19, 2019 at 2:40 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I'd stay away from anything that came with the vehicle (lowest bid) or Firestone.
    BFG, Mitchell, Bridgestone and a couple other brands should treat you well. I would also go with a 265/70R16
    Good luck
  5. Nov 19, 2019 at 4:10 PM
    DRM
    DRM Member
    So after lots of research, I also took the advice and lucky me made 4 return trips to balance my new Michelin 265 65 17defender ltx m/s on 2017 sport AC. Including and eventually replacing 2 with the hunter road force balance.
    But after a week it slowly returns to a balance/bounce issue above 45mph and wheel shake, we had snow and cold temps last week.
    Always smooth rolling below 40mph, hard breaking with hands off steering wheel truck stops straight. Checked alignment, adjusted the usual suspects torque and pressure.
    No history of balance shaking issues with the OEM A30 Toyo and wheels.
    Dealer just called and Michelin is honoring the 60 day customer satisfaction and will install any brand of my choice, no additional charge unless the new set is higher priced.
    Any serious recommendations much appreciated.
  6. Nov 19, 2019 at 4:17 PM
    ANTupLIFE
    ANTupLIFE Well-Known Member
    Anthony
    Chester, VA
    '16 TRD Sport 4x4 DCLB SW
    Maybe a Hankook?
    I'm running the AT2 and road noise is minimal and balancing at a larger size was no issue. I can imagine the highway tires are just as nice and possibly even better.
  7. Nov 19, 2019 at 4:24 PM
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
    Thinking your size are not made in the USA and have had quality issues.
  8. Nov 19, 2019 at 5:13 PM
    DRM
    DRM Member
    All marked made in USA, not Thailand.
  9. Nov 19, 2019 at 5:19 PM
    ANTupLIFE
    Anthony
    Chester, VA
    Friday before a holiday?
    Jk aside. It's always a hit or miss with all mass-produced items. Like with the Falkens. Some balance, some don't. 3 of mine did, one did not. They were made in Malaysia. The Hankook AT2s I run now were made in Korea. Some are made in TN. They balanced well, but I'm sure there's some that will not.
  10. Nov 19, 2019 at 5:33 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Michelin>Yokohama>Cooper>Pathfinders
    I went geolanders last time but Michelin all terrain was my first choice, too much money though.
  11. Nov 19, 2019 at 5:37 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    End thread.
    MoneyMan55[QUOTED] and ANTupLIFE like this.
  12. Nov 20, 2019 at 6:27 AM
    DRM
    DRM Member
    thanks for all the recommendations
  13. Nov 20, 2019 at 5:32 PM
    Cmar
    Cmar [OP] Member
    for you guys that recommended the Michelin Defender XTS, are they quiet? and what air pressure did you find best. and did you get an alignment? thanks
  14. Nov 20, 2019 at 9:51 PM
    BBPSR54X4
    2017 SR5 DCSB 4x4
    Michelin Defender LTX MS. No road noise. I run mine at 32 psi. I did not need an alignment.
    Thegenerik1 likes this.
  15. Nov 21, 2019 at 2:59 AM
    #35
    MoneyMan55
    Doug
    South Central PA
    Yes rides quiet and smooth as glass on the open road. I run 38# in the winter, 36# in summer.
  16. Nov 21, 2019 at 4:46 AM
    #36
    Markc1024
    Markc1024 Well-Known Member
    As others have said, very smooth and they track well without wandering. New tires don't require an alignment per se, but if it's been a while since you've had one, it's a good investment to make sure it's within spec and to prolong the life of your tires.
