Recommendations for best Synthetic Oils for 2014 6cyl?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kingcmo, Jun 27, 2019.
  1. Jul 11, 2019 at 8:04 AM
    #41
    Locoluna825
    Locoluna825 Well-Known Member
    Garrett
    San Diego, CA
    2008 Tacoma TRD sport 2x4
    URD TCAI and MAf Calibrator, Lexus front GX470 big brake swap, TRD Baja Suspension, 3 leaf progressive AAL.
    When I was a Lube Tech for Honda, Honda and our neighboring dealers, Nissan and Toyota, all used Exxon Mobile's motor oil. Unless you bought the "GENUINE" bottles of Honda, Toyota and Nissan fluid from the parts counter. You were getting your car filled with Exxon Mobile Full synthetic and Sythenitc blend fuilds from the barrels that fed our over head pumps. Even with the Genuine engine oils, I had suspicions that the "Genuine" bottles were filled and packaged by Exxon Mobile for Honda. The same might have been true for Nissan and Toyota.
    This is the best damn deal, can't beat this ANYWHERE, I ned to go get me some.
  2. Jul 11, 2019 at 9:18 AM
    #42
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    There is no best oil. They are all great. Here’s the deal, if you want the best oil you need to define what “best” is. What criteria defines best? Let’s see a list of 5 things that for you define best oil. I think there are going to be very few if any that can or will do that. Then tell us what the 5 criteria are and what oil meets those criteria. Then for you personally you’ve found what is best to you.
    So let’s hear your definition of best oil. Best is a vague term without defining it.
    Hook78 and lx708 like this.
  3. Jul 13, 2019 at 10:40 PM
    #43
    jtaco11
    jtaco11 Well-Known Member
    I use supertech synthetic people can knock it never had any issues. Any major brand is fine all preference
  4. Jul 13, 2019 at 10:49 PM
    #44
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Any API approved oil in your specified weight will work fine. Be harder to fine one that wouldn't be fine.
    I do the oil on five vehicles in our household. I use Castrol or Mobil 1, depending on which one.
