Recommendations for head unit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by risethewake, May 11, 2021.
  1. May 13, 2021 at 5:15 AM
    rageman
    rageman Well-Known Member
    Keith
    2018 Barcelona Red Tacoma TRD Off-Road
    Meh. It's OK, but not great. I listen to sports talk via iHeartRadio.
  2. May 13, 2021 at 7:37 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    I don't know about you but my bass is over compensated by the OEM head unit until I turn up the volume to around 25. So if i'm listening to music at 15 - 25 (below 15 the whole system is pretty quiet) my bass is like way out of whack and is booming. Then I turn it up to 25 (or higher) and you can audibly hear the bass tone down as the head unit is no longer compensating. I have a full system (minus the head unit) so maybe that issue is exaggerated.
  3. May 16, 2021 at 7:44 PM
    risethewake
    risethewake [OP] Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    Yep, this is exactly my problem. I set the bass properly at low volume, but when I wanna rock out and crank it up, it dials the bass waay down. So I basically cranked the sub amp up to compensate and used the remote volume knob to adjust the amp on the fly. Because when I'm done car-moshing and turn the HU back down, the bass is ridiculously disproportionate. Made it impossible to get ANY semblance of consistency between volume levels. I presume it's to protect the pathetic stock speakers and their quarter-sized drivers. But god is it infuriating. I just want to set the EQ and set up my system accordingly.
    gkomo[QUOTED] likes this.
  4. May 16, 2021 at 7:50 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I'd suggest scoping the FS threads here. Personally I don't have a backup cam and don't care about nav or Apple so my personal experience would be of little use.
  5. May 17, 2021 at 4:56 AM
    GRNT4R
    GRNT4R Well-Known Member
    NC - Triad
    2010 TRD Sport DCLB 4WD Silver
    TBD
    OP, you dont need the Maestro for the ILX 650 to maintain steering wheel controls. You can use the Axxess ASWC-1 Unit. That Alpine unit doesn't support Idata Link info so the Maestro will be overkill for it. Maestro is used to provide info from the Cars ECU for and not all radio's have that function built in. You can get steering wheel control with the alpine for under $70. I think the Axxess unit is around $50 and then the other harness to prevent any cutting which may be $15 Metra 70-8114. I do agree the Alpine would be the best bet in that price range.
