Recommendations for plugging holes in bed?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FunkMasterFlex, Oct 13, 2021.
  1. Oct 13, 2021 at 6:13 PM
    #41
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    gsubioguy likes this.
  2. Oct 13, 2021 at 6:18 PM
    #42
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    I'm building a winter camping set up and while I don't want NE road crap coming in, I know try as I might I'm never going to fully waterseal my bed. I might look into some sort of flush mounted tubing of a couple inches to keep spray from coming in but still retain their draining function. Hell, ¼" aquarium air hose siliconed in place through the hole then cut flush with bed once silicone cures.
  3. Oct 13, 2021 at 6:38 PM
    #43
    Clearwater Bill
    Billy
    Largo Florida
    It's magic I tell you, pure magic!
  4. Dec 26, 2022 at 9:25 AM
    #44
    patty trick
    patty trick Member
    21 Tacoma OR 4x4
    Everybody is saying don’t plug them but nobody says why. If there’s any water buildup it will just flow out the back. But with the drain holes there, water just drips all over the struts and drive shaft when otherwise they would be a bit dryer just sitting there. So, WHY not plug them?
  5. Dec 26, 2022 at 10:08 AM
    #45
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Water will still accumulate in that area and won’t necessarily dry depending on your climate or if say you park on an incline with the nose of the truck downhill. Leave them open and run some fitting/tubing off them to route the drainage, if water on your shocks is a concern.
  6. Dec 26, 2022 at 10:17 AM
    #46
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    Common sense
    stftaco likes this.
  7. Dec 26, 2022 at 10:20 AM
    #47
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    unless you're part of the carolina squat crowd, the water is going to drain to the front of the truck, and will get stuck there without a way out. those holes are the waters way out of the front of the bed.
    so you really have 3 options.
    1. leave them. truck works as intended from toyota
    2. plug them and let the water fester at the front of the bed
    3. plug them and install carolina squat suspension setup to drain the water to the back while also being humiliated at every hardware store while trying explaining why you spent thousands altering your suspension for drainage reasons.
    maineah and Kilo Charlie like this.
  8. Dec 26, 2022 at 2:16 PM
    #48
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Why do you think Toyota went to all the trouble to drill them? Maybe they thought it might just help keep thing a little dryer? You don't suppose they put the ridges in the bed to keep things out of the water also? Gee mine are on out side edge of the bed you got extra hole from Toyota? I'm tickled sh--t less to have a bed that won't rust out!
    ABA180 and soundman98 like this.
  9. Dec 26, 2022 at 2:44 PM
    #49
    Clidarv
    Clidarv Well-Known Member
    Clinton
    2020 OR DCLB white
    Bed mat
    If they could could come up with a frame it might be perfection!
    soundman98 likes this.
  10. Dec 26, 2022 at 3:51 PM
    #50
    weeksz
    weeksz Well-Known Member
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    I plugged my bedholes thinking the same thing, they were a way for water to get in. I run a bed rug and a soft topper. I keep dry clothes, tools and supplies tucked at the front of my cab to keep them away from the elements. I noticed my little duffel bag and tool bag was wet last summer and I figured it was because of the rain. I realized that water was pooling at the front of my cab and wicking up into all my stuff, soaking everything up there...like soaked. I unplugged those holes and it’s be 90% drier up there. Soft toppers aren’t totally weather proof, but plugging those drain holes made it way worse.
    bornxbackwards and soundman98 like this.
  11. Dec 26, 2022 at 4:00 PM
    #51
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    On mine, there are three 5/16" drain holes at the front of the bed, plus a couple in the storage cubby. If you have a camper shell, you definitely need to plug them. Water will splash up through the drain holes. Use off-the-shelf 5/16" plugs available at Lowe's, Home Depot, or Ace Hardware.
  12. Dec 26, 2022 at 4:04 PM
    #52
    Brex69
    Brex69 Well-Known Member
    2023 Lunar Rock DC LB Off Road
    You better do it quick before Meso reads this
    .jake and soundman98 like this.
  13. Dec 26, 2022 at 4:16 PM
    #53
    patty trick
    patty trick Member
    21 Tacoma OR 4x4
    I’ll probably keep only the passenger side open as that one does not splash all over the frame and drive shaft. It drains directly to the ground. I don’t want all the crap I carry in my bed to end up all over the undercarriage. And yes, as Clidarv pointed out, it’s the Tacoma frame that is issue. Not the bed. Plastic doesn’t rust.
  14. Dec 26, 2022 at 4:17 PM
    #54
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    As Long as it doubles as a gas cap holder I’m in
  15. Dec 26, 2022 at 4:18 PM
    #55
    patty trick
    patty trick Member
    21 Tacoma OR 4x4
    My plastic doesn’t rust. Does yours? Tacoma frames do, though.
  16. Dec 26, 2022 at 4:18 PM
    #56
    Tacosha
    Tacosha Well-Known Member
    Andy
    Calgary, AB, Canada
    2019 Black Tacoma TRD OR ACLB 6MT
    minor, TRD skid plate, front recovery points, Regken mud flaps, rear diff breather, AC drain pipe extended. Upgraded sound with active sub woofer, tonneau cover, CB radio.
    My experience:
    In our hot dry summer (AB, Canada, Eh?) I'm driving a lot on gravel/just dry dirt prairie roads. Before trips like that I'm placing pieces of Gorilla tape over this
    drain holes, otherwice all in my box will be covered in finest white or red dust. Cheap way, but with tailgate seal rubber strip it keeps my stuff more or less dust-free.
    Back to town, in rainy months peeling tape out for drainage. Works for me.
  17. Dec 26, 2022 at 4:30 PM
    #57
    RobotTheDog
    RobotTheDog Well-Known Member
    AZ
    21 TRD OR DCSB CEMENT
    All encompassing layer of dust
    I make sure to ream her holes regularly.
  18. Dec 26, 2022 at 4:38 PM
    #58
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    This!
    During warmer months when I wash my truck...out comes the bed mat so I could wash off the underside where the bed mat rested.
    Low and behold...there's drain holes at the front!
    I've seen trifold tonneau videos showing how tubes are installed using the same holes at the front for drainage.
    Apparently, earlier model 3rd Gens did not have pre-drilled holes (unless someone can refute this) so the drain tubes can be routed to them.
    I'd have to get under my Sport to see where the water drains but I imagine it's closer to the gas tank & muffler.
    Vmax540 and shakerhood[QUOTED] like this.
  19. Dec 26, 2022 at 4:51 PM
    #59
    CountofQ
    CountofQ Well-Known Member
    Duluth, MN
    2017 'Old Man Tan' AC OR
    Just park under a tree. They will plug themselves with twigs and leaves. All your questions will be answered....
    Is it Friday already? I thought today was Monday.
  20. Dec 26, 2022 at 5:06 PM
    #60
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    So fresh water in the bed dripping on the frame worries you more than salt spray from the road? Maybe the bed fresh water helps wash it off.
