Recommendations for portable tire inflator
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaboDawgs, Aug 18, 2020.
  1. Aug 18, 2020 at 2:38 PM
    aozer
    aozer Well-Known Member
    Dallas
    2020 Tacoma TRD OR Cement
    i also have a viair and it has been very reliable and effective.
    i used it to add air to my tire everyday for a month (long story) and it was a life saver.
    tonered likes this.
  2. Aug 18, 2020 at 5:18 PM
    Harmon
    Harmon Well-Known Member
    Jacksonville
    2020 Tacoma SR V6 4X4
    265/75/16 BFG KO2's Front ARB Air Locker
    I bought the Smittybilt 2781 Compressor and changed the air chuck to standard air chucks.
    That is the only drawback to these japanese air compressors they come with a non standard air chuck.
    I bought a Rolled 1/4 hose and use a ARB digital tyre inflator/deflator.
    Works great. I really wanted the ARB portable dual with the 1 gallon tank. But 800 bucks.
    Maybe for christmas lol.
    pop.tremuloides likes this.
  3. Aug 18, 2020 at 5:30 PM
    Virginian
    Virginian Well-Known Member
    Raleigh, NC
    2017 Tacoma Double Cab TRD Off Road
    Hard to beat this portable compressor. Just research the ratings.
    VIAIR - 40045 400P-Automatic Function Portable Compressor
    44-16 Taco, ORtoCOTaco and tonered like this.
  4. Aug 18, 2020 at 5:32 PM
    Harmon
    Jacksonville
    Just remember with these Amazon Compressors the Air Chuck is basically proprietary. It will not work with standard air chucks.
  5. Aug 18, 2020 at 6:00 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Eh, I disagree. ARB is proven to withstand the elements and also has great specs as far as it’s duty cycle and CFM.
    That said, I ditched my dual arb for a tank of CO2 and no compressor can even remotely compare to it. But that’s apples to oranges.
  6. Aug 18, 2020 at 7:02 PM
    MedTechBrew
    MedTechBrew Well-Known Member
    NC
    2017 Quicksand TRD Sport DCSB 4x4
    Love these forums. Always looking for recommendations. Just a casual offroader, camping mostly. Does the viair 88 compare to the single arb? Worth under hood mount setup?
    tacoman45 and tonered like this.
  7. Aug 18, 2020 at 7:15 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have not looked much at the ARB. I know the Viair site gives flow rates at various pressures and dimensional details. I would imagine that ARB does also to compare.
    The 300P is the next step up in flow rate from the 88P. It is fast.
    For a hard mount you do want automatic operation. See my thread about that if you go with a non-automatic model.
    :cheers:
    MedTechBrew[QUOTED] likes this.
  8. Aug 18, 2020 at 7:18 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Are you talking about the Viairs or another brand?
    The Viair has a standard industrial pneumatic male fitting that worked with all my existing stuff. The chuck end itself was a bit wonky and not my preferred connection.
  9. Aug 18, 2020 at 7:21 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No, but to be fair it’s also 1/4 of the price. The 88p is the best bang for the buck inflator when it comes to duty cycle and CFM. I’d say it’s good up to 33” tires.
  10. Aug 18, 2020 at 7:27 PM
    Harmon
    Jacksonville
    50
    I am not sure tbh
    I know most of the Amazon compressors use the Japanese fitting. There easy enough to swap out but some of them don't even run a 1/4' hose.
    I have a 60 dollar GSPSCN sitting next to me that I got on Amazon and it doesn't even have a air chuck on it. It's all air stem screw on.
    The Smittybilt I got did come with Air Chuck connectors but they were non standard. As I said there easy enough to change out as long as the hose is 1/4".
    tonered[QUOTED] likes this.
  11. Aug 18, 2020 at 7:32 PM
    JSmith501
    JSmith501 Well-Known Member
    San Antonio, TX
    2017 Off Road 4x4
    I had the Viair and now the Dual ARB. The Dual ARB is plenty fast for the amount of times I need to refill my tires. ARB ran just fine in 110 degree heat.
  12. Aug 18, 2020 at 7:36 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Ah! I see.
    I am very careful with the Amazon stuff. There's a few of the international brands that seem to sell compatible stuff that I can semi-trust.
    The Viair are made here.
  13. Aug 18, 2020 at 7:45 PM
    Shellshock
    Iowa
    I’ve used the viair 400p automatic, arb single portable and arb twin portable. All of them are great choices, depending on what you want and budget.
    I like the portable compressors because I can use them with any vehicle.
    I also use my inflate / deflate kit, link in my signature.
    Tim v and tonered like this.
  14. Aug 18, 2020 at 7:47 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The inflate / deflate kit is kickin'. Mine gets a lot of use.
  15. Aug 19, 2020 at 7:30 PM
    #35
    lag7
    lag7 Well-Known Member
    Central Arkansas
    2019 Tacoma TRD Pro Super White
    I bought the Viair 400P and love it. Definitely get the automatic since it keeps me from running to turn off the compressor. Mine fit in the cubby behind the rear seat back.
  16. Jun 27, 2021 at 12:42 PM
    #36
    P4NDEMONIUM
    P4NDEMONIUM Well-Known Member
    Adam
    2019 TRD Off-Road
    Milwaukee boy here, but absolutely. This one lives behind my seat 20210209_105059.jpg
    tacoman45 and AmateurTaco1313 like this.
  17. Jun 27, 2021 at 3:36 PM
    #37
    RebleAZ
    RebleAZ Well-Known Member
    Troy
    AZ
    2020 Cement TRD Off Road
    Fox Performance Elite, RRW -25 RR7H, 295/70/17 Yokohama Geo MT. Alcan Leafs. Much more...
    Can you please explain the CO2 tank. Did you got a tank from a welding shop or something and put a line and fitting on it and just turn on the valve to fill?
  18. Jun 27, 2021 at 3:46 PM
    #38
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I have a powertank system. It’s a tank of co2 with a regulator on it with quick disconnects to hook an air hose up to. I get mine refilled at a welding supply store.
    https://powertank.com/pages/faq
  19. Jun 27, 2021 at 10:11 PM
    #39
    Otto-x
    Otto-x Well-Known Member
    Seattle, WA
    2021 Cement DCLB OR
    Holy crap those are expensive
  20. Jun 27, 2021 at 10:19 PM
    #40
    Spidicus
    Spidicus Well-Known Member
    Nevada
    19' DCSB TRDOR 4x4
    +1 on the Viair 400P. Luv mine. Use it alot. Luv that I can throw it in my buddies truck 8f he us driving also.
