Recommendations for Replacement Headlight assembly from Amazon?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ScrippsRanch67, Jul 30, 2022.
  1. Jul 30, 2022 at 10:33 PM
    ScrippsRanch67
    ScrippsRanch67 [OP] Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Any recent headlight assemblies purchased from Amazon for my 2006 Toyota Tacoma Pre-Runner.
    Clear lenses, not interested in otherwise
  2. Jul 31, 2022 at 4:31 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    If you're looking for headlights that actually perform, Amazon (or eBay) is not your friend. Almost everything there is designed for looks first and actual performance way down the list. If you're planning on keeping your truck, I'd highly recommend OEM.
    Naveronski, lynyrd3 and JGO like this.
  3. Jul 31, 2022 at 4:46 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Forget it. Get OEM. Save yourself time, $, and a ton of grief.
    ScrippsRanch67[OP] likes this.
  4. Jul 31, 2022 at 6:22 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    If you live anywhere near Santa Cruz California, you may have my old Depo replacement headlight assemblies for free. I took them off and went back to OEM.
    ScrippsRanch67[OP] and Raylo like this.
  5. Jul 31, 2022 at 6:56 AM
    Raylo
    MD, USA
    ^ This. If you're close to DC metro area come get my Eagle Eyes set... before I toss them in the dump. One had mounting points that were off a bit dimensionally, bad enough to require workaround. Both leaked. And the light pattern wasn't perfect. Unfortunately I didn't install them until a year after I bought them so couldn't send 'em back.
  6. Jul 31, 2022 at 9:29 AM
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    Always trust Amazon!
    [I hope a "sarc" is unnecessary.]
  7. Jul 31, 2022 at 4:32 PM
    lynyrd3
    Bill
    East Central Upstate NY
    X2
  8. Jul 31, 2022 at 6:24 PM
    TacoTuesday1
    SD CA
    Depo black smoked like the TRD Sport
    good higher watt bulbs
    headlight services upgraded harness
    more expensive if you want to blow money is OEM and maybe Alpharex
    still gonna cost you to put LED's inside like Diode Dynamics
    /thread
    throw a silica gel pack inside
  9. Aug 1, 2022 at 5:45 AM
    Raylo
    MD, USA
    LOL... the way one of mine leaked it needed a pump, not a desiccant. In one bad storm it took on over a cup of water. Get the OEM units without the bulbs and install the Ultimate Headlight Upgrade. Best light pattern and brightness, won't blind other drivers. Easy peasy. Won't leak.
    charles08tacoma likes this.
  10. Aug 1, 2022 at 9:12 AM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    oem all day. I know oem can get a little expensive. If the ones you have are oem and are hazy, there’s nothing to loose and do the headlights polish threatment. Cheers!
  11. Aug 1, 2022 at 11:54 AM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    OEM unless you want to play around with sealing aftermarket yourself. The only thing aftermarket are really ok for is doing a proper LED ore HID retrofit. (PROPER being the key word...)
  12. Aug 1, 2022 at 12:41 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    I concur. Pricey, but the TRD Pro units are nice.
  13. Aug 1, 2022 at 12:45 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    OEM or nothing!
