Recommendations for suspension Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoholix, Aug 20, 2024.
  1. Aug 20, 2024 at 9:10 PM
    Tacoholix
    Tacoholix [OP] Active Member
    Will
    2014 Tacoma TRD sport
    In the market to get a 2.5" or possibly 3" lift. Purpose of the lift is to clear 285 tires. Little to no off roading and prefer to keep the ride quality comfortable as possible. Prefer to do things right the first time, budget is $2000.00.
    What is the maximum height i can lift without affecting the ride. I keep hearing some 2.5" while others are saying 3". Which is it?
    Or if you could direct me in the right direction to learn more about lifts, that would be great. There are just too many threads with overwhelming and conflicting testimonials. Thanks.
  2. Aug 21, 2024 at 6:37 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    Tacoholix[OP] likes this.
  3. Aug 21, 2024 at 6:52 AM
    mtntacoVA
    mtntacoVA Member
    13 Taco, 24 4Runner
    It’s a right of passage - go headlong down the rabbit hole (it helped me put off doing anything to the suspension for 8 years until stock was worn out.
    Here’s what I’ll recommend - you need to figure out how much extra weight you have/ plan to add soon (armor, roof rack, sliders, etc). That will help you figure out the correct spring - generally, the higher weight rating, the harder the ride will be on pavement. Same principle applies to the rear leafs (more packs/ layers, can handle more weight, but going to ride a little harder).
    next, shocks - they’re complicated- need to look at a bunch of shuff that I’ll butcher (I’m not going to look that up - that’s for you to do). Basically, if they’re valved (like Kings), it’ll be a softer ride than say 6112s/ 5100s.
    third, tires - probably more understated for ride quality (E rating can feel pretty hard - especially on terrible pavement at slower speeds).
    For me, I have KO2s (love them/ have always gotten them - but they feel like work boots vs running shoes)
    I went with 6112 in the front; Dakar medium leafs in the back (they’re controversial on this board - I have the newer model and zero issues with noise - I also dealt with the oem leafs for 8 years so make of that what you will. Then 5100 rear.
    If you’re not doing serious off roaring, don’t need to worry about the extension of the rear 5100.
    I got around 2.5 front/ 2 rear once it settled. Happy with it overall - again, stiffer on Oahu’s shit roads at slow speeds, but feel great on rocky trails/ highway speeds.
    Next time I do the suspension, I’ll likely steer towards Kings/ whatever has a valved system.
    hopefully someone far more knowledgeable than me also jumps in to correct what I said - good luck (buy once, cry once - but also do your research).
    GilbertOz, Tacoholix[OP] and SethM like this.
  4. Aug 21, 2024 at 8:43 AM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    If no offroading, and no extra flex or travel are required. I believe a spacer lift would keep the geometry of drive shaft the same. Keep the stock feel, I'm running 3" toytec 285/75/17 mpg is horrible and cutting and trimmed necessary. Maybe a 265/75 would fit with minimal cutting with the spacer, maybe body lift. Don't waste money on a suspension that your not gonna offroad. 285 is tire width, ur looking for height which is the 70, 75 for example.
    Tacoholix[QUOTED][OP] likes this.
  5. Aug 21, 2024 at 8:53 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Feel free to give us a call over here at Hotshot Offroad. We've worked with a bunch of TW members over the years, and are happy to answer whatever questions you might have as well.
    Colton - 406-936-0206
    P4x4 and Tacoholix[QUOTED][OP] like this.
  6. Aug 21, 2024 at 9:58 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
  7. Aug 21, 2024 at 11:06 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I’ll assume this doesn’t include tires and wheels
  8. Aug 21, 2024 at 12:21 PM
    MSgt O
    2013 Tacoma
    265/75 will fit with no trimming at all...
    FishaRnekEd and Tacoholix[OP] like this.
  9. Aug 21, 2024 at 12:28 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    If the purpose of the lift is to clear 285's don't get a lift. Do the work to clearance the wheel wells and enjoy the luxury of the factory suspension comfort. A lot cheaper, but that's just my .02 cents
  10. Aug 21, 2024 at 1:43 PM
    Tacoholix
    Will
    No, i already got the wheels and tires. $2000 more or less strictly for the lift.
  11. Aug 21, 2024 at 1:45 PM
    Tacoholix
    Will
    Clearance and a better look lol. I got 285/70/17s right now and wanting to lift now.
  12. Aug 21, 2024 at 1:56 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Everyone has different opinions. Check out the regional threads and see if someone will give you a ride with different kits.
    For about 2k you can go a few different routes.
    unless you want to eat through CV boots, stick with about a 2.5” lift.
    Cheapest would be 5100s all the way around and an add a leaf or blocks for the back. If you have 2k and want better, you could go 6110/5160 and maybe an UCA. Reach out to @memario1214 for help there.
    Another good option ( so I’ve read) is the Dobinsons MRA/MRR but for 2K you can only get the fronts. Might be able to pair them with 5100 rears and a block/aal and be good. @Crikeymike is the one to ask about the Dobinsons.
    I have the Ironman Foam Cell Pros, and my only complaint is they are on the stuff side, but most kits sound like they are. It’s still a good ride. You can get the complete kit with leaf packs and UCAs for about 2k.
    Here is a pretty good thread testing the higher end kits, but they are closer to 3K to get what you need. https://www.tacomaworld.com/threads/blind-shock-tests-season-2-starts-today.799472/
    Crikeymike and Tacoholix[OP] like this.
  13. Aug 21, 2024 at 1:59 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Tinkerers Adventure on YouTube has a pretty good series of informational videos you can go through. Currently at work and don't really have time to type out and get into the nitty gritty.
    https://youtu.be/_68Hc8GtLko?si=yWuxcIUHYQoGPp3-
    https://youtu.be/l1tTelhdEiM?si=qb1GaPI8sD4eKe5f
    https://youtu.be/huMztKaHsUE?si=S7wP6Bxs4akMWtoB
    https://youtu.be/InQnp42pfts?si=xIpup2HNgktii3AB
  14. Aug 21, 2024 at 8:09 PM
    P4x4
    P4x4 Well-Known Member
    Pascal
    2015 Dark Gray Tacoma 4x4
    Strictlytoyz[QUOTED] likes this.
  15. Aug 21, 2024 at 8:34 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    285's dont fit the wheel wells stock or lifted period. (unless we talking drop bracket / spindle drop lift up front). There simply isnt enough area in the wheel well to clear a 285 without trimming or flattening.
  16. Aug 22, 2024 at 5:20 AM
    FishaRnekEd
    New Orleans, LA
    Yes, this is reasonable and easy.
  17. Aug 22, 2024 at 5:23 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
