Recommendations on 1 or 2 subs
Discussion in 'Audio & Video' started by masg293, Jan 27, 2017.
  1. Jan 27, 2017 at 7:42 PM
    masg293
    masg293 [OP] Well-Known Member
    Mikael
    2014 Tacoma
    I am installing a jl audio he 900/5 and was wondering if I should run 1 or 2 10' tw3 with custom box in 2014 Tacoma. New to stereo installation
  2. Jan 28, 2017 at 9:16 AM
    jv_74
    jv_74 Well-Known Member
    Jesse
    Filthadelphia
    2015 DCSB Silver Sky Metallic
    All about preference. I'd assume with the 5 channel amp you'd run the 2 subs as 1 speaker...assuming the other 4 channels are for your doors?
    Just running a sub with a 5 channel amp would be interesting lol
    For me, 1 10" Kicker 250watt w/ JL250.1 really thumps and fills up the cab.
    19o4Taco likes this.
  3. Jan 28, 2017 at 7:46 PM
    Raincity
    Raincity Half man, half amazing.
    Lowermainland, B.C.
    '13 Mica Spruce DC.
    '12 DC TRD-RIP
    Don't know much about the amp but if it were me(I like bass) I'd be installing two and see if the amp could manage to power them.
  4. Jan 29, 2017 at 4:19 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Might not be much of a difference since you'll split the power. 500W to one or 250W to 2. I'd expect a ~3 dB difference for much more effort and money. Or do a single SD3. I've never compared the 2 side by side (although I have heard both), but I've read about folks who have used both and the SD3 always wins if you can fit it - it's a little deeper. I can vouch for the SD3...have one in my truck - outstanding sub with excellent output as well as SQ.
  5. Jan 29, 2017 at 7:30 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Sadly, double the cone area with half the power will most likely result in much less of a gain. Id be shocked if its much more than 1 db louder.
  6. Jan 30, 2017 at 6:08 AM
    MtnBiker831
    MtnBiker831 Well-Known Member
    Santa Cruz, CA
    17 Trd Pro
    Audio, lots of it
    It would be the same in volume as the single with double the power. Every time you double your cone area, you gain 3db. Every time you double your power, (if the speaker can handle it and does not reach its mechanical limit) you gain 3db. Those subs want 400rms each, so you will have some left on the table in capability, but it will sound cleaner with the 2 vs the single. And the tw3 is a great sub choice.
  7. Jan 30, 2017 at 4:40 PM
    rob feature
    rob feature Tacos!
    Colorado
    Yeah, there's that. Less cone movement will mean reduced distortion. Some (most?) don't like distortion-free or low distortion bass though. True story.
  8. Jan 30, 2017 at 5:28 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    I'm well aware of how things work, but Real world results vs theoretic results are completely different but what do i know. In theory a 3 db gain is possible but in reality id say 1-1.5 db would be the gain attributed to this notion especially in our trucks in the setup that its in.
    now lets complicate matters and toss in 2 sealed vs 1 ported keeping the same 500wrms power :)
  9. Feb 28, 2017 at 6:46 PM
    Knwilson
    Knwilson Well-Known Member
    Please continue... I am currently pondering whether I should switch up my current setup do to a problem with my current sub (link to thread). I am interested in your thoughts as I don't want to change up amp (HDP5), but I am tempted to switch to (2) 10s or (1) 12" preferably in a ported box.
  10. Mar 1, 2017 at 7:40 PM
    ECTacoma
    ECTacoma Re-member
    Josh
    Chesapeake, VA
    2014 TRD Offroad
    4" barrel running boards OME lift Icon uni UCA 33" mt bfg km2 Relentless fab cross bars JL audio system Black oak ditch led CBI brackets Rola rack
    I made my box and installed a 12 JL Tw3 and love it. If you have 2 subs like others have said you only increase your db by a few and for the money to me isn't practical but if your serious about some spl then go for it. Also having 1 allows for more storage. All food for thought
    Oldman808 likes this.
  11. Mar 1, 2017 at 7:50 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    If you're only ever running a single 5 channel amp then my vote is for 1 sub. I did it in my old Ranger with a Kicker Kx800.5, the ancient model that literally went across the whole back wall. If...*IF*... you plan to run a 2nd amp at some point then I'd lay the groundwork & get the 2nd sub rolling. I just don't think the cost/benefit is in your favor with a single amp.
  12. Mar 1, 2017 at 7:54 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    your best bet would be a single 12
  13. Mar 1, 2017 at 7:58 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I have 2 10" I like it! 4 channel amp for the doors and a 2 channel for the subs. Suits my needs for definitely apperent and commanding bass, but not overpowering or distorted. I listen to everything from classic rock to pop to a bit of rap.
  14. Mar 1, 2017 at 7:59 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    This or nothing...
    Bought the box on Amazon.
  15. Mar 1, 2017 at 8:00 PM
    Sterling_vH111
    Sterling
    socal
    Also as a thought, has anyone tried or heard of having one ported and one sealed sub?
    I had ported subs in my last vehicle and liked it, but also apriciate the tight sound sealed subs have.
  16. Mar 2, 2017 at 7:00 AM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    no don't port + sealed.
    As for ported vs sealed sound... if you know what your doing you can make a ported box sound very close to a sealed box in relation to response but louder
  17. Mar 3, 2017 at 3:43 PM
    masg293
    Mikael
    2014 Tacoma
    Thanks guys for the info, decided on going with two jl's. I will post pics when I am done
  18. Mar 3, 2017 at 10:15 PM
    fergsonfire
    fergsonfire Electrical Guru
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    Single will be more than enough... I run a single Morel Ultimo SC off a JL HD 900.5 and I can get it to bump as much as I want
  19. Mar 4, 2017 at 1:02 PM
    masg293
    Mikael
    2014 Tacoma
    You were able to squeeze a Morel behind the seat? Any chance you can snap a pic
  20. Mar 6, 2017 at 11:33 AM
    Doc Jr 8156
    Doc Jr 8156 Well-Known Member
    Rancho Cucamonga
    2013 DCLB Pyrite Mica 4X4 TRD Sport
    King 2.5 Shocks w/ resi front and rears Total Chaos UCA Icon AALeafs SCS SR8 Wheels BF Goodrich TA KO2 tires All Pro Apex Sliders K&N Air Filter TRD Seatbelt Straps TRD Hubs DeZee Bed mat Extang Trifecta Viper 5904 Alarm Antenna X Ultra Gauge AFE Stage 2 Intake TRD Exhaust OEM Roof Rack HID Headlights and Fogs Weather tech laser mats Alpine CDE 149BT Headunit HAT Clarus 6.5 components front and JL Audio C2 650x for rear 2 Alpine SWP T-10 shallow 10-inch subwoofers Alpine PDX V9 main amp, Alpine PDX M-6 mono sub amp Dual 10 inch sub box Pop-Lock Anytime fog mod Differential breather mod KB Vodoo Bed Brackets KB Vodoo Tailgate protector Midland Portable CB Firestick CB Antenna Osram Headlight Bulbs and Rallyelights harness
    Hello,
    I say 2 10-inchers. I am running 2 shallow Alpine SWR-T10 powered by the sub amp of 2 Alpine PDX- V9 enhanced by Audiocontrol Epicenter. I like the performance. Godspeed.
