Recommendations on tires
Discussion in 'Wheels & Tires' started by Wixo, Dec 21, 2018.
  1. Dec 21, 2018 at 10:54 AM
    Wixo
    Wixo [OP] Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Howdy,
    I'm about to hit 60K miles on my stock tires. I want to get a new set in the 285/75r16 which is what I understand to be taller than stock, but not wider. This truck is my daily driver and it gets light off road use every now and then. I do drive it a lot compared to other apparently. Ive had it two years and already hit 60K, so gas mileage is a bit of factor and the reason Im not going with 67lb Wildpeaks which I might get later when I dont drive this truck as much.
    I will be putting in a lift to fit these tires on. Im debating on the following:
    Mickey Thompson ATZ P3
    Good Year DuraTrac
    Open Country A/T2
    They would all be P rating and A/T not M/T since I mostly drive on the road and only O/R lightly every once in a while (driving on the sand where most vehicles can, cruising around a ranch type stuff).
    Let me know your recommendations.
  2. Dec 21, 2018 at 11:15 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    285/75s are significantly bigger than stock and will rub short of a cab mount chop and fender well trimming. Both wider and taller. Also I'm not sure there's any P-metric A/T 285s available. Almost all are LT with E loads or the occasional C or D.
    Whitetail Assassin and gilligoon like this.
  3. Dec 21, 2018 at 12:50 PM
    JayTee
    JayTee Well-Known Member
    Lynn Ranch CA
    I just put 285 70 17 ridge grapplers on mine and super happy.
    Not much more road noise than OEM tires and look way better and im sure will be way better in dirt
    Rilo2448 likes this.
  4. Dec 21, 2018 at 12:53 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    I usually go with round tires. Always do me pretty well.
    Fye123, TacoManOne and BillsSR5 like this.
  5. Dec 21, 2018 at 12:55 PM
    Ravnikar610
    Ravnikar610 Well-Known Member
    Minnesota
    2016 OR DCSB
    I have 285/75 26 atz p3's. Okay tire, but they are really loud when turning. It got even louder with the removal of the sway bar.
    My next tires will be less aggressive tread as I don't off road enough to justify p3's. Probably 35" K02's as they are silent and bigger is better!
  6. Dec 21, 2018 at 12:57 PM
    la0d0g
    running for the hills
    For crawling not hauling
    You have more miles on your truck than I have on my 2010 :D
  7. Dec 21, 2018 at 12:58 PM
    EnduroWeekly
    EnduroWeekly EnduroWeekly Founder
    Drake
    Southern California
    2017 Quicksand DCSB Offroad 4X4
    US Racks "Craddle" Motorcycle Bed Rack Clazzio Covers (Black w/ Tan Stitch) Weather Tech Floor Mats (Black)
    Tried out some trapezoid tires the other day, not my cup of tee... will try round next set
    In all seriousness, look into he 255/85/16 "Pizza Cutters" They are true 33" tires and have a lot less rolling resistance (less power loss/hit to MPG) and you don't need to cut anything to make them fit! I will be going with Dick Cepek Extreme Country 255/85/16 when mine wear out. EDIT: And they are the lightest 33" tire I could find... and load range E so you can pop them
    DevTom, Wixo[OP] and JayRolla[QUOTED] like this.
  8. Dec 21, 2018 at 1:11 PM
    Pirate1975
    Pirate1975 “What do you do with a drunken sailor...?”
    Steven
    Statesville, NC
    2017 Silver TRD Off-road
    3rd bedrail.32”duratrac tires.CaliRaised bed stiffeners,rear ditch bracket for cb antenna .SOS Concepts sliders,3skids,bedrails.curtis rack.cobra 75 cb.HAM license.887 coils,Bilstein 5100’s,medium Dakar leaf pack,extended rear brake lines,wheeler’s superbumps bumpstops.carrier bearing drop bracket.sway bar delete
    Been running Duratracs for 10k miles and ok with them surprisingly..
    My next set may be 285/75R16 KM3’s though.
    Recommend a cab mount if you do this!
    20mm wider and about an inch taller 265/75-285/75..
  9. Dec 21, 2018 at 1:50 PM
    I.eat.tacos
    I.eat.tacos Well-Known Member
    Steve Rogers
    '18 TRD 4x4 Sport
    I hear square tires are more fuel efficient.
  10. Dec 21, 2018 at 1:56 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Everything looks round when you spin it fast enough.
    Rockefelluh likes this.
  11. Dec 21, 2018 at 1:56 PM
    trackdaybro
    trackdaybro Well-Known Member
    I’m interested in those, how much do they weigh? Iirc Cooper ST (non Maxx) are among the lightest 255/85/16 with a D rating.
  12. Dec 21, 2018 at 1:58 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Pneumatic tires are awesome, sorry couldn’t resist.
  13. Dec 21, 2018 at 2:00 PM
    YF_Ryan
    Kent, WA
    I'm still waiting on these to come out in a size that fits the Taco
    Pirate1975 likes this.
  14. Dec 21, 2018 at 2:09 PM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    Once the trolls are done f’ing with you maybe you can get some legit info.
    I would search some previous threads for insight as to people who have already switched their tires out and what pros and cons they have experienced.
    I haven’t switched mine out yet, but I have gained tons of info from other members who have had good and bad experiences with the brands you mentioned. Best of luck man. Keep us posted with what you end up with.
    Wixo[OP], Swampdog2019 and YF_Ryan like this.
  15. Dec 21, 2018 at 2:30 PM
    Wasatchrider
    Wasatchrider Well-Known Member
    5100 front and rear set to second from top add a leaf and you will be fine
  16. Dec 21, 2018 at 4:33 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    OP there are entire threads on this forum dedicated to those tires you listed. Recommend going to those as they will have the most information .
    Wixo[OP] likes this.
  17. Dec 21, 2018 at 4:43 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    YF_Ryan[QUOTED] likes this.
  18. Dec 21, 2018 at 11:53 PM
    Wixo
    Hank
    Tint, LED interior
    Will look into them, thanks!
  19. Dec 22, 2018 at 12:37 AM
    Kingkoopa
    Kingkoopa Active Member
    Mario
    S.Cali
    17 PRO
    Where do the claw tires and wheels
  20. Dec 22, 2018 at 7:48 AM
    Mr-Paul
    Mr-Paul Well-Known Member
    Paul
    2017 Qucksand Tacoma SR5 4x4 V6 Access-Cab
    For a daily driver and limited off-road, Falken AT3W in P265/75R16. I have them and love the tire. I commute 100 miles a day on the highway and they are pretty darn quite for an aggressive all terrain tire.
