Recommendations on upgrades
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hawaiitacoguy, Jul 2, 2020.
  1. Jul 2, 2020 at 2:16 PM
    Hawaiitacoguy
    Hawaiitacoguy [OP] New Member
    2018 Midnight Black Tacoma
    N/A currently
    I want to lift my 2018 Taco about 6 inches and get some larger tires, mid/smaller size rims. So far I've only done work on the inside. What would you guy recommend that I supercharge and upgrade the exhaust before lifting and adding the larger sized tires? I definitely know I want to put the rims and tires on at the same time as the lift I dont want chicken legs on my truck. Thank you for reading
  2. Jul 2, 2020 at 2:38 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Well welcome to TW and I'm sure you will get a lot of input, 6 is a pretty big lift im sure someone will post some picks for you also.
    Chew likes this.
  3. Jul 2, 2020 at 2:44 PM
    tcjacado
    tcjacado Well-Known Member
    Fabtech, bds or rough country if you are 4wd.
    Hawaiitacoguy[OP] likes this.
