Recommendations Please
Discussion in 'Suspension' started by CoolHandLuke, Jul 13, 2013.
  1. Jul 13, 2013 at 9:42 AM
    CoolHandLuke
    CoolHandLuke [OP] Member
    Luke
    Bay Area, CA
    1997 SR5 4x4
    Hello,
    I have a 97 Tacoma SR5 4x4 with a 3" Revtek lift. I am looking to replace the rear shocks and front struts. Does anyone have any recommendations? I mostly commute with the truck but take it camping and hunting throughout the year. Obviously I would like to save where I can, but am open to any ideas.
    Thank you!
    Luke
  2. Jul 13, 2013 at 9:45 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    I would ditch that whole setup and invest in a set of 5100's at 2.5" and 5125's with AAL but if you must keep the spacers and blocks then you can get 5100's set at 0" and 5125's for the rear.
  3. Jul 13, 2013 at 10:16 AM
    CoolHandLuke
    Luke
    Bay Area, CA
    1997 SR5 4x4
    Thanks for the recommendation! For what reason would you ditch the setup? I am not too familiar with lifts and all that, and this one was put on by the original owner...
  4. Jul 13, 2013 at 10:40 AM
    sirsaechao
    Tim
    CA
    It's a spacer and blocks. You are replacing the shocks anyways so you have to either rent the spring compressor or take it in and have it done. You might as well just run the 5100's at 2.5" and a AAL in the rear.
