Recommended Aftermarket Catalytic Converters
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hank0604, Apr 20, 2022.
  1. Apr 20, 2022 at 12:46 PM
    hank0604
    hank0604 [OP] Member
    Hank
    '21 DCSB SR5
    Hey all,
    I've got a 2021 4cyl., the factory cats were stolen. Dealer was saying 6+ months for a factory replacement, so I ordered a cheap direct fit off eBay and put it on. Also had to splice in a new wiring harness for the O2 sensor cause they cut that off. I'm getting a P0420, which I understand to be because the cheap cat isn't good enough. So, does anyone have a recommendation for a better aftermarket cat that my truck will like? Maybe a Magnaflow (and which one, as their site doesn't get any results for my truck)? RockAuto has one from AP/Eastern that's direct fit, does anyone know anything about those?
    I'm moving soon and at this point just need to sell the truck, but I want to get rid of the P420 first.
  2. Apr 20, 2022 at 12:52 PM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    Test pipe and URD simulator.
  3. Apr 20, 2022 at 1:09 PM
    hank0604
    Hank
    '21 DCSB SR5
    Unfortunately I don't think URD still sells that simulator. I had one on my old 2nd Gen so that was the first thing I looked for.
  4. Apr 20, 2022 at 1:16 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Depending on how much the 'cheap' unit was, you might consider putting 2 of them end to end (as close as you can) and that MAY fix that code. It's a matter of efficiency with enough reactants to do the job. Just a thought.
