Recommended Jack Stand Strength?
Discussion in 'Suspension' started by cfree5119, Nov 14, 2014.
  1. Nov 14, 2014 at 9:55 AM
    cfree5119
    cfree5119 [OP] Well-Known Member
    What is the recommended jack stand tonnage? Thanks
  2. Nov 14, 2014 at 10:14 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Mine are 3.5 ton. Jack stand overkill is permitted.
  3. Nov 14, 2014 at 10:17 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I have a pair of 6 tons and a pair of 3 tons
  4. Nov 14, 2014 at 11:18 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Total height is also worthy of consideration.
  5. Nov 14, 2014 at 11:18 AM
    T4RFTMFW
  6. Nov 14, 2014 at 11:34 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I have 3 sets.... 2 (tall) 6 ton and 1 (short) 3 ton.
    The tall sets are too tall for the cars & sedans. The short sets are too short for the trucks & SUV's. Depends on what you're using them for.
    I use the short ones all the time on the truck when I rotate my tires. They go under the rear axle.
