recommended leaf for kings 2.5 extended w/ compression adjusters
Discussion in '3rd Gen. Tacomas (2016-2023)' started by potmilkz, Jan 14, 2019.
  1. Jan 14, 2019 at 2:21 PM
    #41
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    Not sure who makes the Icon RXT springs (deaver)...?
    But at least you can arrange it in three different configuration's depending on lift height and or load carrying capabilities...!
    I have a set that I haven't installed yet so can't give any feedback but thought I'd throw that out there.
  2. Jan 14, 2019 at 2:51 PM
    #42
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    I would call deaver and let them know you want something similar to j66, maybe add an overload leaf for height/firmness. Call them they will point you in the right direction.
    descartesairplnne and Willbeck like this.
  3. Jan 15, 2019 at 7:04 PM
    #43
    potmilkz
    potmilkz [OP] Well-Known Member
    luis
    17 Tacoma 4x4 longbed
    alright ill check with deaver.. maybe their light load series
  4. Jan 15, 2019 at 7:20 PM
    #44
    potmilkz
    luis
  5. Jan 15, 2019 at 7:38 PM
    #45
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I'm not sure why this is so misunderstood but every leaf pack is capable of being configured to support different capacities. It's literally just adding or a removing a leaf.
    Willbeck likes this.
  6. Jan 16, 2019 at 4:37 AM
    #46
    yotafiend
    yotafiend Sup Dawg!
    Detroit, MI
    2024 SR5 DCSB 4x4 Underground
    TRD OR Wheels Falken Wildpeak 33s C TRD OR Struts Trailhunter Skid Toyota Mudguards Toyota Integrated Dashcam Toyota Rocker Bars CH Ceramic Paint Coating Costco 91 Octane
    I am running the J66 Deaver, seems to be fine, not bottoming out with the 8100s. Softest Deaver offers other than custom pack. The extended Kings will give more droop than the 8100s. Although, the J66 claims 1.75”, but looks like 3”
  7. Jan 16, 2019 at 7:05 AM
    #47
    fxrman
    palm springs
    Yep....
    It's just that the RXT springs come with that leaf allowing for three different setups...
    Not sure if they are as good or better then other brands but they give choices that are included with purchase.
  8. Jan 16, 2019 at 7:08 AM
    #48
    JoeCOVA
    Joe
    Colorado Springs
    They all do. The difference is Icon marketed it. Deaver, OME can be adjusted by removing a leaf.
    I just want to make sure people are aware that this isn’t a benefit or a feature not offered with other leaf packs simply because they don’t understand.
  9. Jan 16, 2019 at 7:20 AM
    #49
    fxrman
    palm springs
    Wasn't aware the other brands came with the extra leaf...
    Might have gone with deaver had I known that.
    Good to know as it's great to have choices.
    JoeCOVA[QUOTED] likes this.
  10. Jan 16, 2019 at 9:06 AM
    #50
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Deaver packs come with 8+ leaves. And all leaf packs, including the factory ones can be disassembled and leaves added or taken out.
    paleh0rse likes this.
  11. Jan 16, 2019 at 9:22 AM
    #51
    fxrman
    palm springs
    Ok just to clarify, you say leafs can be added or taken out this we already know but do the other brands come with an extra leaf to add or do you buy one if you need it...?
    I know you can buy the heavy spring pack or standard pack and remove springs but if you want to add one you have to then buy it...?
    RXT springs include this already.
    Not saying there better just that to me it seems easier.
  12. Jan 16, 2019 at 10:21 AM
    #52
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    "included" is just a marketing ploy. ALL Leaf packs "include" extra leaves. Yes you'd have to buy extra leaves if you want to increase the capacity.
    Or you can call Deaver and tell them what you're looking for and they'll assemble a pack to your specs from day one.
    fxrman[QUOTED] likes this.
  13. Jan 16, 2019 at 10:34 AM
    #53
    JoeCOVA
    Joe
    Colorado Springs
    You can buy added leafs. A single leaf from Deaver is $100 I think. When I went from Stage 1 to Stage 2 they sent me a single leaf to add to the pack.
    The other option is buy the whole pack and take out what you want.
  14. Jan 27, 2019 at 11:57 PM
    #54
    potmilkz
    luis
    im conflicted between icon rxt and dekars..
    i dont haul much.. so having a stiff leaf pack isnt a must.. i want a smooth ride with a 3 inch rear lift.. which one will be the best for me? is there a light rear pack that gives 3 inch lift?
  15. Jan 28, 2019 at 11:39 AM
    #55
    advan7
    advan7 Buy once, cry once!
    Orlando & Duuuuuuvalllll!
    2018 Cav Blue Pro
    V2.2021
    Icon AAL and leave the overload spring in if you want the 3" height. Mine rides smooth as butter.
  16. Jan 28, 2019 at 12:01 PM
    #56
    thecoloRADoinferno
    thecoloRADoinferno Well-Known Member
    2017 Tacoma Inferno TRDOR DCSB
    I have the Toytec Boss leafpack which is essentially a Deaver 10-leaf leafpack (I believe). It rides fairly well without weight, although rides much better with a couple 60lb sand bags in the bed. Outside of a little noise, which is remedied by power washing usually, they have been great. Seem completely bullet proof!
    Link: You can reach out to Carsen @Toytec Lifts for more details if you want them, great group of people!
