Recommended lift for my situation
Discussion in 'Suspension' started by bigmooze, Jul 12, 2009.
  1. Jul 12, 2009 at 2:31 PM
    bigmooze
    bigmooze [OP] Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Hi guys and gals.
    I want to start researching properly how to lift my truck. But to do that effectively, I'd like some input.
    I don't wheel my truck that much. When I do, it's on trails that lead to fishing spots. It's nothing I can't do in my stock setup. But I'd like to install the lift for looks and more clearance/bigger tires.
    I'm thinking that I need to stay away from spacer lifts. I've read about the poor ride quality in some cases. I've looked a little into Bilstein 5100's all-round, with the AAL in the back. I'd like eventually to run 265's, possibly 285's, for tires and with the adjustable Billies I think I can do that. I'd replace the UCAs for alignment purposes, but would I need the front diff drop spacers and rear axle shims too?
    If I need the spacers and shims, I'm thinking I may as well hold out for the Toytec ultimate system, but I wanted your guys' input before I continued. Is the Toytec overkill for what I want the lift for?
    Richard.
  2. Jul 12, 2009 at 2:54 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You can lift for less than the Ultimate kit. The 5100's set to the highest with UCAs and an AAL will get the job done if you are just trying to do some light wheeling and clear some bigger tires. The diff drop and shims are a case by case sorta kinda thing- I haven't had any vibes are anything from my lift...but you might.
    Going with the 5100s over the full toytec kit will save you a few bones towards your tires. And if you decide it's necessary- You can buy the coilovers without the shocks and upgrade then...
  3. Jul 12, 2009 at 3:02 PM
    bigmooze
    Richard
    Belle River, ON
    Thanks for that.
    Has anyone had vibration issues as a result of installing the billies and an AAL?
  4. Jul 12, 2009 at 3:06 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    all ive heard is good things about the billys
  5. Jul 12, 2009 at 3:11 PM
    bigmooze
    Richard
    Belle River, ON
    Right on... I haven't seen too many complaints about vibrations after installing them, which is encouraging. There does seem to be some varied opinion as to whether you need to replace the UCA's though. I'd like to set the fronts at 2.5", so that probably warrants the new arms for alignment reasons eh?
  6. Jul 12, 2009 at 3:13 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    If you have the $ and the desire- It is the "right" way to do it. Upgrade all the parts to make sure you get peak performance.
    Will your truck implode if you don't do it...No It won't, but at 2.5 you might have some wandering issues. I'd recommend doing it just for piece of mind.
  7. Jul 12, 2009 at 3:13 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. I have 5100's all around but I also have OME 885 coils and a 2" rear AAL. Rides great IMO!!!;)
  8. Jul 12, 2009 at 3:15 PM
    bigmooze
    Richard
    Belle River, ON
    Just curious - why did you swap out the factory coils?
  9. Jul 12, 2009 at 3:19 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Well the 5100's in the front are set at 0" height. The coils and top plate spacer do the full 3" of lifting. I just wanted to upgrade to some better shocks.;)
  10. Jul 12, 2009 at 3:25 PM
    bigmooze
    Richard
    Belle River, ON
    So the top plate spacer "boosts" the lift to reach 3" (from 2.75")? And one more thing, there's no problem with using the factory coils right? I hadn't planned on replacing those unless I put an ARB (or similar) bumper on the front. Then I realise I need stiffer coils. And that's a ways away just yet.
  11. Jul 12, 2009 at 3:29 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I believe the top plate spacer raises it another 1/2"-1/4" to get the full 3" lift out of it. No there shouldnt be a problem using your stock coils with the 5100's set at 2.5". I have yet to hear anything bad about them.:rolleyes:
  12. Jul 12, 2009 at 3:32 PM
    bigmooze
    Richard
    Belle River, ON
    Awesome, thanks for all the help so far. I can't wait to lift my truck. Just need to be a bit patient for a while longer :cool:
  13. Jul 12, 2009 at 3:37 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah your going to love the new look once you get it done! I sure did!!! Well good luck on your truck and dont hesitate to ask any more questions if you got em!;)
  14. Jul 12, 2009 at 6:10 PM
    bigmooze
    Richard
    Belle River, ON
    Is there a disadvantage to using the stock coils and using the Billies for lift, as opposed to keeping the Billies at stock and ordering larger coils (like OME 886's)?
  15. Jul 12, 2009 at 6:29 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I guess you could argue that using the stock coils and bumping up the preload on them will make them react in a way that is not intended...but the stock setting with longer coils will be the way everything is designed.
    But I don't think you are going to hear anyone complain about either way...or they wouldn't still be making them this way...ya know??
  16. Jul 12, 2009 at 6:47 PM
    bigmooze
    Richard
    Belle River, ON
    True enough... I was searching around to see if anyone has complained about the stock coil/2.5" pre-load setup and couldn't find anything major. I guess its OK - my main concern is damage to the truck. With my intended setup hurt?
  17. Jul 12, 2009 at 6:50 PM
    bigmooze
    Richard
    Belle River, ON
    There's a line in the lifting FAQ page that says no-one recommends using the 5100's with aftermarket coils, so I guess that answers my question - it won't hurt (someone please correct me if I'm wrong though)
  18. Jul 12, 2009 at 9:39 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    You can only use your Bilsteins at stock height with aftermarket coils. The coils will do the lifting, and not the shocks. ;)
  19. Jul 13, 2009 at 12:51 AM
    Kmoney
    Kmoney Well-Known Member
    Kelly
    Bend, Oregon
    '17 DCSB TRD OR
    White dog
    Ok... so let me interject with a question. Can you run the 5100's at 2.5" and then add the top plate spacer to get the ""full 3" of lift""" with no problems?
  20. Jul 13, 2009 at 7:14 PM
    bigmooze
    Richard
    Belle River, ON
    I'm thinking of installing the 1" diff drop from Toytec, just for piece of mind for the CV joints. But I just read that doing that you might run into issues if the diff shifts etc. during the install. Is that something I should be really concerned about?
